× Forum Header
Light Machines Company Mill
28 Jul 2010 05:17 #3501 by rexhunt
Light Machines Company Mill was created by rexhunt
Here at school we have an old light machines comppany super spectra light mill that has a shady stepper. We also have a lathe by the same company that has been converted to a mill that I am planning to get a replacement stepper from. The only problem is the computer with the software on it doesnt work anymore, but I am trying to get emc to drive it...does anyone have any idea where i can find the pinout?
thanks
Rex
28 Jul 2010 06:12 - 28 Jul 2010 06:13 #3504 by cmorley
Last edit: 28 Jul 2010 06:13 by cmorley.
16 Aug 2010 03:14 #3770 by rexhunt
Replied by rexhunt on topic Re:Light Machines Company Mill
does anyone know what information needs to be put into the feilds in the images...i have it stepping but i think the timing is a little off, the motors will move but there will be a big pause between steps
16 Aug 2010 03:15 #3771 by rexhunt
this is the other place where i need the info for
thanks
17 Aug 2010 21:37 - 17 Aug 2010 21:38 #3795 by shaworth
Replied by shaworth on topic Re:Light Machines Company Mill
Hello, I built and maintain build.spaceopera.org/ . The EMC configuration was incomplete, this was an oversight that has been fixed. The correct values can be found on the site under "EMC2 Configuration".
Cheers,
Shannon
Last edit: 17 Aug 2010 21:38 by shaworth.
18 Aug 2010 03:05 #3797 by rexhunt
Ok thanks for that.
I will update as soon as there is any news
23 Aug 2010 01:07 #3846 by rexhunt
Ok I have now got it all set up to move as in your configuration, however the steppers make a lot of noises that sound like gears grinding in a manual gearbox and may move a little but will only move in one direction and will still make a whole heap of extra noise while moving...any ideas?
23 Aug 2010 10:08 #3851 by Rick G
Replied by Rick G on topic Re:Light Machines Company Mill
It sounds like you might be trying to drive the steppers too fast. Try making a drastic reduction in your velocity and adjusting your acceleration.
Rick G
23 Aug 2010 21:58 #3856 by BigJohnT
Replied by BigJohnT on topic Re:Light Machines Company Mill
and or increase your step timing...
24 Aug 2010 23:00 - 24 Aug 2010 23:17 #3863 by rexhunt
ok I will try that and tell you how it goes
How much would I need to change the numbers by? Or would that be too machine specific to my machine?
Last edit: 24 Aug 2010 23:17 by rexhunt. Reason: Poor spelling
