Forum Header
Light Machines Company Mill
- shaworth
22 Sep 2010 20:08 #4287
by shaworth
Replied by shaworth on topic Re:Light Machines Company Mill
rexhunt wrote:
You do have that controller (The only LMC controller I'm aware of), right?
Shannon
I have no idea. However the cable is only designed to work with the controller photographed on the bottom of this page: build.spaceopera.org/site/reverseenginee...ontroller/index.htmlIs there a difference between the Intelletek and the Light Machines Corporation mils?
Shannon
- rexhunt
12 Oct 2010 00:45 #4631
by rexhunt
Replied by rexhunt on topic Re:Light Machines Company Mill
sorry i was taking a break during the school holidays
yep that is the controler box that I am using... that could have been quite embarassing
printed on the big PCB inside it should be the revision... I am thinking that I may have a different one or the jumpers inside may be configured differently
- rexhunt
14 Oct 2010 00:03 #4665
by rexhunt
on a closer inspection, my controller box has not got a wire guard over the fan... not sure if that means anything though?
hopefully soon i will have a faster machine completely set up to run the software... does it absolutely have to have the 300 odd megabytes of ram?
- shaworth
12 Nov 2010 23:18 #5282
by shaworth
So, did you ever get anywhere with this?
Shannon
Shannon
- rexhunt
13 Nov 2010 09:42 #5286
by rexhunt
sorry I didnt reply sooner, I had exams...
the control box is a different version which means that I am just going to try it with the old software. So untill I can get the windows based one working and seeing the spectracam thing then I will have to install the dos version we have and dos or win 95.
thanks for all your help all the same,
Rex
Rex
- Rhine_Labs
- Thank you received: 11
15 Sep 2015 06:00 - 15 Sep 2015 06:26 #62600
by Rhine_Labs
Replied by Rhine_Labs on topic Light Machines Company Mill
Recently acquired 2 machines and a controller box. Installed LCNC on a box last week for my other machine build but since I got these and they are 80% ready to run what a way to learn LCNC!
Anyone have an archive of the cable plans and Linux cnc file. I did find this is there anything else needed but to just rewire a DB25 Cable? And are these pin-outs correct for both lathe and mill's? The lathe has a encoder on the spindle i do not see it on the pin outs.
Parallel port (Male) Controller box cable (Female) Notes
1 22 Enables the spindle
2 6 X Dir
3 21 X Step
4 18 Y Dir
5 20 Y Step
6 5 Z Dir
7 19 Z Step
8 4 Spindle on/off
13 23 ESTOP Warning: May or may not work, if connecting this causes EMC to stop (thinking the button has been pressed at random times), disable it in the stepconf. Placing a 10uf (and possibly much smaller) capacitor in parallel with this signal and grounding it acts as a filter. Problems with this line were resolved using this technique.
14 17 Mill Amp on/off
25 7 GND
Machines.
2 6 X Dir
3 21 X Step
4 18 Y Dir
5 20 Y Step
6 5 Z Dir
7 19 Z Step
8 4 Spindle on/off
25 7 GND
Machines.
Last edit: 15 Sep 2015 06:26 by Rhine_Labs.
- Rhine_Labs
17 Sep 2015 06:06 #62661
by Rhine_Labs
Wired up the cable figured out what Limit Switches, Spindle, E-stop works but no movement on steppers. I am going to say maybe it is the voltage on the parallel port. Thinking maybe a
C26 - OUTPUT BUFFER BOARD
may work? Any Ideas?
- Thank you received: 4994
17 Sep 2015 06:15 #62663
Wire the p-port to sink current rather than source, and invert the step signals in stepconf.
Replied by andypugh on topic Light Machines Company Mill
Wired up the cable figured out what Limit Switches, Spindle, E-stop works but no movement on steppers. I am going to say maybe it is the voltage on the parallel port. Thinking maybe a C26 - OUTPUT BUFFER BOARD may work? Any Ideas?
- Rhine_Labs
17 Sep 2015 07:02 - 17 Sep 2015 07:19 #62668
by Rhine_Labs
OK, Sink then Source has me lost??? Please explain! I understand invert the step signals!
How I have it Now on the light machines.
PC EPP - Controller
1 -> 22 Spindle CW (Working Turns On Spindle)
2 -> 6 X DIR
3 -> 21 X Step
4 -> 18 Y Dir
5 -> 20 Y Step
6 -> 5 Z Dir
7 -> 19 Z Step
9 -> 4 Spindle on/off (Working)
10 -> 23 E-stop (Working)
12 -> 13 Home (Invert)
13 -> 24 limit (Invert working)
8 -> 17 Amp Enable
15 -> 11 Cover Motor Switch (Working)
18 -> 7 Ground
20 -> 10 UF Cap to 23 for e-Stop to work (Working)
PC EPP - Controller
2 -> 6 X DIR
3 -> 21 X Step
4 -> 18 Y Dir
5 -> 20 Y Step
6 -> 5 Z Dir
7 -> 19 Z Step
8 -> 17 Amp Enable
18 -> 7 Ground
Last edit: 17 Sep 2015 07:19 by Rhine_Labs.
17 Sep 2015 07:17 #62669
My stepper drivers have opto-isolator inputs.
To make them work with a parallel port I had to connect the high-side of the opto to +5V and the low side to the parallel port.
So, P-port @5V = no current flow. P-port at zero volts current flow through the LED of the opto from +5V, through the Led + resistor (in the drive) and then onto the parport to GND.
Some parports can only source 3mA, but most can sink 15mA.
