  • Muftijaja
  • Muftijaja
19 Nov 2025 13:07
problems with Y-Axis, elliptic deviations after several changes -Probe Basic V.5
Category: QtPyVCP
Thanks, Hakan. Yes, yesterday I cancelled my Air-path as I could see the motor is going into alarm. I don't know if there is a following error as a reason for this, Iwill pot my serial connection to the motor today to read the logs and reproduce the error.
What I can say, mechanics are not the reason, because - what I changed just before were the entries at FERROR and MIN.FERROR to 0.1 and 0.01, exactly what is in the x-axis, which is running fine with these settings.
  • JT
  • JT's Avatar
19 Nov 2025 12:07
Replied by JT on topic Remaped Toolchange
Remaped Toolchange
Category: Flex GUI
I can't test without the files you are using or a sim config containing all the files you're using.
  • unknown
  • unknown
19 Nov 2025 12:06
realtime log position to txt use python script
Just an idea.
The last position that will be recorded will be the last data that that was successfully written to the hardware from the file buffer.
Now the power going out will be for all intents and purposes a random event, there is no guarantee that any particular data will be successfully written to hardware before a power outage.
The only way I can see everything happening gracefully is with a UPS, that once detects a mains outage is able to shutdown gracefully. But the machine itself may not be in the exact position you expect due to inertia and any other unknown factors mechanical or electrical.
So basically data not being written the disk is more of a limitation of an OS when power is removed suddenly.
Also one would hope the file being written to is not stored in tmpfs (ram) then written to disc during the shutdown process of Linuxcnc.
  • Hakan
  • Hakan
19 Nov 2025 10:41
Replied by Hakan on topic AX58100
AX58100
Category: EtherCAT
Haha, that brings back memories
There are two products here in the picture
www.aliexpress.com/item/1005001579853052.html STM32F407VET6 dev board
www.aliexpress.com/item/1005007182508975.html LAN9252 slave dev board
The STM32's pins on the LAN93252 dev board are limited to those in the pin header, which wasn't enough.
For test it can work if the needed pins are available in the header.
One can use the LAN9252 of the kit, which is what I did and hooked it up to the STM32 dev board
where I had access to all pins.SPI+sync0,syc1,irq lines.
I now see in some searches there are other LAN9252+STM32 development boards which are better suited, maybe this one?
It can pay off to do a search. You want access to the Timer's encoder inputs, which
are different for different models so it's a puzzle.
Schema for STM32F407ZGT6 on the LAN9252 dev board
  • MaHa
  • MaHa
19 Nov 2025 10:32
Replied by MaHa on topic Remaped Toolchange
Remaped Toolchange
Category: Flex GUI
The remap is done with a simple .ngc routine, for adjustable toolchange/probing position, from a spinbox value. change.ngc completes without error., then it crashes. So the problem must be with  epilog=change_epilog.  I did not modify   stdglue.py  . The manual tool change option from .hal file is working
[RS274NGC]
REMAP=M6  modalgroup=6 prolog=change_prolog ngc=change epilog=change_epilog
  • andypugh
  • andypugh's Avatar
19 Nov 2025 10:29
Replied by andypugh on topic ISEL CNC/IMC4 programming language
I think you might be misunderstanding what LinuxCNC does. If the machine responds to low-level commands through the serial port then I think that the CNC controller is on the machine side of the serial port. LinuxCNC is a CNC controller, so that is where half of LinuxCNC would go too.
  • Fixenty
  • Fixenty
19 Nov 2025 10:22
Touch resizing of gcode preview was created by Fixenty
Category: Gmoccapy
Hi, I have an issue in Gmoccapy.When I try to click on “Clear Toolpath” or “Jog Speed –”, the cursor automatically grabs the edge of the preview window. Instead of clicking the button, it starts resizing the preview window.It feels like the preview window border has priority over the buttons, so I can’t reliably click them. Has anyone experienced this, or knows how to fix it?
  • vibram
  • vibram
19 Nov 2025 08:59
Replied by vibram on topic AX58100
AX58100
Category: EtherCAT
@Hakan certainly a stupid question but I did not understood why you did not managed to get the encoder work on the ethercat devboard here?
I wanted to test the encoder on the devboard before doing a custom board
Thank you for the clarification
  • unknown
  • unknown
19 Nov 2025 06:26
Replied by unknown on topic program exceeds machine maximum
I have my MAX-Z-LIMIT set at 20mm & MIN-Z-LIMIT set at -255
Usually when I run a program, as I set home and stuff like that manually I'd home to a mark on the column, then bring the tool down to a height of 6.35mm above the stock, set by a pin, touch off at that height. Which sets the Z zero on the stock.
  • unknown
  • unknown
19 Nov 2025 06:16
LinuxCNC 2.9.3 .xz image for RPi 5 is not available in the ISO directory
Unfortunately the 2.9.3 image you refer to has been removed from the server.
There is a new image that has 2.9.7 and is much more raspios like.
The thread is here which has one image suitable for both the 4 & 5:
forum.linuxcnc.org/9-installing-linuxcnc...trixie-images#338181
As this is an experimental image I would be very interested in feed back.
If you need to install probe basic there are 2 extra packages to install after following the Probe Basic install instructions:
forum.linuxcnc.org/38-general-linuxcnc-q...-launch-issue#338654
If you are not installing Probe Basic there is no need for these packages.
  • farmer_mike
  • farmer_mike
19 Nov 2025 05:06 - 19 Nov 2025 05:10
program exceeds machine maximum was created by farmer_mike
Hi, this is my first post outside of the Ethercat section.
I'm getting beat up by a z axis travel limitation, although I did somehow get the program to run once. My understanding of the problem is that my g54 is in the wrong spot.
Fusion 360 says the max Z height is 0.6", so I moved my Z axis almost all the way up, then set the G54 Z position to 0.6". I did have the program run once, but then I stopped the program. When I go to re run the program I keep getting the same z axis error.
I've attached some phone pictures.
  • gravedigger
  • gravedigger
19 Nov 2025 04:55
Replied by gravedigger on topic 7i73 MPG Input MaxVelOverride
Category: PnCConf Wizard
And one more question. Can I use the same encoder for both feed and MaxVel? I don't really like the two-button operation for feed control
  • gravedigger
  • gravedigger
19 Nov 2025 04:52
7i73 MPG Input MaxVelOverride was created by gravedigger
My maxveloverride isn't working. It's on enc3, and spindle override and feedrate override work there, but not maxveloverride. Is this due to gmoccapy? The entries in the HAL file look the same as for spindle and feedrate.
  • Hakan
  • Hakan
19 Nov 2025 04:51
Category: QtPyVCP
Ok 500 is fine. I knew it is 1000 for 1 ms but not how it scaled.
I was looking for a reason for the following error.
Since the feedback comes from the step generator and not the actual machine,
it seems to me the step generator is to blame.
You get following error even when running in air, right?
Basically linuxcnc, or perhaps the step generator, generates the wrong tool path in Y.
Unfottunately I don't know how to fix it.
  • 4ashishkr
  • 4ashishkr
19 Nov 2025 04:40 - 19 Nov 2025 04:40
This image was previously available, but when I tried to reinstall it, I couldn't find the specific "
.xz" file anywhere in the ISO index.
Displaying 11056 - 11070 out of 11531 results.
Time to create page: 0.624 seconds
