  • Digger011
  • Digger011
10 Oct 2025 18:45
Replied by Digger011 on topic Strugling with installation
Category: Installing LinuxCNC
I believe you referred to this to run
# rm /etc/{initramfs/post-update.d/,kernel/{postinst.d/,postrm.d/}}z50-raspi-firmware
# apt purge raspi-firmware
What should I do after that? I apologize Tommy, but I have no idea what should I do.
Thanks.
  • Dragan
  • Dragan
  • Aciera
  • Aciera's Avatar
10 Oct 2025 18:26
NEW BUILD, need help with e-stop in tklinuxcnc
Category: Basic Configuration
If you select 'Utilities' > 'HalMeter' in the tklinux menu and select 'iocontrol.0.emc-enable-in' does it show TRUE ?
  • richcolvin
  • richcolvin's Avatar
10 Oct 2025 18:05
Replied by richcolvin on topic Stepper Motor Speed is too slow
Peter, thank you for the guidance.  Once I re-enabled the PID stuff, things worked as expected.
I used the auto tuning steps and from there have been able to get to a good state.
  • Dragan
  • Dragan
10 Oct 2025 17:37
i did and its not working, when i start sim tklinuxcnc its working
  • Aciera
  • Aciera's Avatar
10 Oct 2025 17:34
Have you clicked on the 'ESTOP' button in the tklinuxcnc gui to set 'Estop off' and 'Machine on'?
  • Aciera
  • Aciera's Avatar
10 Oct 2025 17:26
Button on Linuxcnc interface that switches an output on Mesa 7i76e on and off
Category: GladeVCP
Note that you can use either a handler or the postgui halfile to make the connections.
  • Aciera
  • Aciera's Avatar
10 Oct 2025 17:25
Category: GladeVCP
That does not work because you have forgotten to give a signal name after the 'net' command.
I entered the command in postgui. This does not start linuxcnc. Do I have the correct command from Halshow for postgui.hal?
Not sure I understand this correctly but halshow does not make any distinction between postgui and regular hal files.
The regular hal files are read before the gui has loaded so if any gui related halpins are used in these files you will get a startup error because those pins are missing. The postgui halfile is read after the GUi and the custom panels have loaded.
  • Dragan
  • Dragan
10 Oct 2025 17:25
thank you for the quick answer it is not working i tried everything its super strange.
  • yaska
  • yaska
10 Oct 2025 17:13
Replied by yaska on topic Flex Gui Keyboard jog error
Category: Flex GUI
It seems to be fixed now 10.10.25
  • DerKlotz
  • DerKlotz
10 Oct 2025 16:58
Category: GladeVCP
I only became a Glade user today... so I don't have any experience yet. Please take a look at the attachments. I have the following questions:
Do I have to enter something in Glade -> Light Button -> Signals -> Handler? Do I enter this handler in postgui?
  • marcelovx23
  • marcelovx23
10 Oct 2025 16:57
Replied by marcelovx23 on topic XHC-WHB04B-04 Got it working
We have very similar goals. In the future, I also want an ATC and a fiber laser machine for metal cutting. I’ll be keeping an eye on BidSpotter as you mentioned, but I think I’ll end up buying the resonator and all the necessary parts for the fiber laser from some affordable Chinese supplier. Thank you so much for your support with the MPG, you’re a legend!
  • Aciera
  • Aciera's Avatar
10 Oct 2025 15:12 - 10 Oct 2025 15:15
Category: GladeVCP
You'll need to make the hal connections in the postgui_hal file. Have a look at the millturn sim confi, (uses an xml instead of a glade file but the setup is the same.
github.com/LinuxCNC/linuxcnc/tree/master...xis/vismach/millturn
  • DerKlotz
  • DerKlotz
10 Oct 2025 15:05 - 10 Oct 2025 15:06
Category: GladeVCP
Hello,
I would like to have a header on my Linuxcnc interface that switches Pin17=hm2_7i76e.0.7i76.0.0.output-00 on and off on my Mesa7i76e. So far, I have created an LED and a button in Glade. This already appears on the Linuxcnc interface, but no control content is stored. How do I proceed? I tried to do some preliminary work on the Glade page, but failed. What do I need to do and where?
Thank you
  • RLA
  • RLA
10 Oct 2025 14:28
Replied by RLA on topic AC Servo change to run
OK...so would I still need a new INI file?...I have been trying to make a new configuration by copying original which has 9 axis, but it is not working..was just copying and renaming...missing something....but if that is not necessary even better!!
Thanks again,
Rick
Displaying 12931 - 12945 out of 12952 results.
Time to create page: 0.384 seconds
