  • emresensoy
  • emresensoy
13 Aug 2026 03:44 - 13 Aug 2026 03:44
Replied by emresensoy on topic Beckhoff EL2522 lcec xml file
Category: EtherCAT
Dear Mr @hakan, I want to get your mail address if possible,
mine is This email address is being protected from spambots. You need JavaScript enabled to view it.
  • viewsat
  • viewsat
13 Aug 2026 03:28 - 19 Aug 2026 02:47
All my positive terminals are connected to the purple cable via a thin wire.
Dirhold isn’t the problem; it really is the voltage that’s coming through – there was a clear difference between 3.3V and 5V.
My connections are like in your image, but with EN connected.
You could use a multimeter to check what voltage is coming through your DIR pin.
I suspect that when the DIR signal starts acting, it might not follow the set dirhold wait time, outputting PULSE before the process is complete. When encountering a motor driver with a slow dirhold response, this results in an invalid PULSE output. It's strange that increasing the dirhold value doesn't solve the problem; this is a problem I don't understand.
You can check that Dirhold is working using Testbench and by monitoring it on an oscilloscope or logic analyser.
It worked for me with the default settings, but it’s certainly better to set it to the manufacturer’s specifications to be on the safe side.
(cd riocore/plugins/stepdir/ ; make)
In my tests, the problem only occurred at 3.3V;
if you Google ‘DM542 problem’, you’ll find lots of reports of the same issue.
I apologize for asking so many questions. I always use 5V to power the 74HC245 and the driver. If there's a problem, usually adjusting the DirHold time is all that's needed. When I use a Mesa 7i92 + 74HC245 (5V) + DM542 (pulse=10, DirHold=25), everything works perfectly, and it correctly returns to the zero position. However, when I switch to a Tang Nano 9k+ + Riocore + 74HC245 (5V) + DM542 (pulse=10, DirHold=25), it fails to return to the zero position, and adjusting the DirHold time doesn't help.
DIR/PULSE issue resolved, thank you!! (2026-08-19)
  • Edi_48
  • Edi_48
13 Aug 2026 02:51
5/2 -Wege Magnetventil was created by Edi_48
Category: Deutsch
Hallo ich möchte gerne ein 5/2 Wege Magnetventil  an eine  Mesa 7i76e anschliessen.
Ich habe folgendes in meine Hal-Datei geschrieben:
net werkzeug-auf <=motion.tool-release
net werkzeug-auf => hm2_7i76e.0.5.output -00
Vedrahtung: TB5 Ausgang 00(Mesa TB5 pin 16)
Linuxcnc meldet  unbekannt  motion.tool-release
 wo ist mein Fehler
mfg
Hilton
  • meister
  • meister
13 Aug 2026 02:26 - 13 Aug 2026 02:28
if you Google ‘DM542 problem’, you’ll find lots of reports of the same issue.[/quote]
  • viewsat
  • viewsat
13 Aug 2026 02:12 - 19 Aug 2026 02:46
  • viewsat
  • viewsat
13 Aug 2026 01:23 - 19 Aug 2026 02:45
Hi tuxcnc
I tried increasing the dirhold (PULSE=10, DIR=25) but it still didn't return to the origin correctly. When using a stepper motor, I pay attention to the Sequence Chart of Control Signals. If I use a Leadshine DM542 uses HCPL-063L/15MB high-speed optocouplers for both the DIR and Pulse inputs, so there are no problems using it.
Because increasing the dirHOLD time should have solved the problem, but it didn't. If Riocore hadn't fixed the DIR issue with the cheap DM542 driver mentioned earlier, I could only replace the pc817 with a 6N137. However, I still really hope that Meister will pay attention to this problem.
  • meister
  • meister
12 Aug 2026 23:29
  • tuxcnc
  • tuxcnc
12 Aug 2026 22:37
Gui message while homing with shared home/limit swiches
Category: Qtvcp
Am I the only one using QtDragon?
No. You are only one using your config.
  • tuxcnc
  • tuxcnc
12 Aug 2026 22:32
If I replace the DIR PC817 optocoupler with a high-speed 6N137, it can correctly return to the zero position.
This is wrong way.
By modifying the driver, you risk damaging it and reducing its reliability.
Although the PC817 has a very low bandwidth, the correct solution is to increase the dirhold.
  • tensaiteki
  • tensaiteki
12 Aug 2026 20:13
Replied by tensaiteki on topic 7i97T Analog Output Problem
Category: Driver Boards
Yup, you were right.
I would've thought that since it is a bipolar signal that getting the two wires swapped would just have the effect reversing the sign of the signal. Guess not.
Anyway, it looks like the outputs still work, so massive kudos to PCW for building the card rugged enough to survive a few mistakes.
  • viewsat
  • viewsat
12 Aug 2026 20:02 - 12 Aug 2026 22:13
However, using grbl and mesa 7i92 does not require modifying the DIR pc817.
I may need to use a logic analyzer to observe the timing diagrams of the Tang Nano 9k output pulses and DIR
I'm from Taipei, Taiwan, and my English isn't very good.
  • viewsat
  • viewsat
12 Aug 2026 19:27
From what I see in your video, the connection is like this: PUL+ and DIR+ are not connected.
  • viewsat
  • viewsat
12 Aug 2026 19:21 - 12 Aug 2026 21:19
My DM542 input pins are connected like this. I've used this DM542 driver on approximately 1000 units. I've used it on Linuxcnc LPT, Mesa 7i92, and Grbl 1.1 controllers without encountering any positioning error issues.
  • dang133
  • dang133
12 Aug 2026 19:18
Transparency Question was created by dang133
Category: QtPyVCP
My team is trying to use Probe Basic for some milling functions.  We would LOVE to be able to set transparency effects on different STL files in the MACHINE_PARTS file/variable.  We'd ALSO like to be able to show the models, and the mill paths behind them.  Is this possible?  Whats the best way to do this with the smallest code change possible?
Thanks,
Dan
12 Aug 2026 19:05
Replied by tommylight on topic 7i97T Analog Output Problem
The polarity is wrong, from the looks of it.
And since you asked, no it is not Mesa 7i97T's fault but now it might be, as pulling 80mA from it's outputs can't be healthy.
The max. analog inputs usually draw is 20mA, hence the 4-20mA written on them very often.
Displaying 1906 - 1920 out of 11357 results.
Time to create page: 0.487 seconds
