  • Mr. Mass
  • Mr. Mass's Avatar
06 Feb 2025 16:38
Replied by Mr. Mass on topic qtdragon additonal buttons
Category: Qtvcp
Quick question: how can I increase jogging linear and angular increment drop-down menu? Is it also in stylesheets like you did for G5x button?
  • Grad
  • Grad
06 Feb 2025 16:00
Replied by Grad on topic LinuxCNC on Raspberry Pi 5
Category: Installing LinuxCNC
I do not know how you guys even got so far: i have a Raspberry Pi 5 Modell B, 4x 2,4 GHz, 4 GB DDR4 and created images of v. 2.9.4 to SD card & USB drive with 3 different burning software including balenaEtcher. When i boot the RPi5 the drives are not recognized (as bootable) at all. With an image of vanilla Ubuntu it works just fine.
  • Aciera
  • Aciera's Avatar
06 Feb 2025 15:57
Kinematics for nutating table rotary was created by Aciera
Category: Show Your Stuff
This is from some recent work on table rotation kinematics
Includes:
- Adjustable nutation angle
- Adjustable table offsets x and y
- Adjustable orientation of primary axis (from XYZBC to XYZAC)
- TCP kinematics
- python remap implementing TWP (Tilted work plane) ie G53.n , G68.n , G69 codes
Sim config including the required xyzbc_tnr_kins.comp   (use halcompile --install ... ) and full documentation can be found at:
github.com/Sigma1912/LinuxCNC_Demo_Confi...able-nutating-rotary
  • PCW
  • PCW's Avatar
06 Feb 2025 15:56
Replied by PCW on topic 7i97t setup problem
7i97t setup problem
Sounds like Mesaflash needs to be updated
github.com/LinuxCNC/mesaflash
(build instructions at bottom of page)
  • Grotius
  • Grotius's Avatar
06 Feb 2025 14:41
Replied by Grotius on topic scurve trajectory planner
Hi Automata,
andrew2085 was very helpfull. It was hard to get his code to work properly.
We have a robust clothoid 2-dimensional library.
For now it lack's the 3-dimensional clothoid implementation.
github.com/ebertolazzi/Clothoids/issues/45
I am unable to create the 3d clothoid from his comments.
A clothoid needs a iteration ~20  to find optimal fit. This is also the case at a runtime interpolation when u
use the clothoid library in a standard way.
The new approach is time optimal. By this i mean the "arc-strip" method for curves of any type.
The new planner's infrastructure makes it easy to add new trajectory smooth algo's. So almost anyone can
add a algo to it. Sinds it also has a algo template.
Using a clothoid is a very good approach, i agree 100% with that.
Downside is that the real deviation is hard to find. Then 2 attached clothoids could do exact deviation.
When optimizing the path at load time, the clothoid is constructed (~20 clothoid iterations are done) and clothoid is
saved as arc_strip to be interpolated as fast as can be later on.
Soon i wil test a clothoid this way.
Julian made a test environment to test multiple cnc files in a loop. The velocity's are extreme.
We had scurve hang's in certain cases early'er this week. After figuring out, we had some isnan values coming up so now and then.
Isnan = is not a number. This can happen when dividing to zero for example.
We decided that the planner has to first pass test bench, before going any further writing smooth algo's on top.
Let's run the test environement for a few more hours.
  • Aciera
  • Aciera's Avatar
06 Feb 2025 14:22
Replied by Aciera on topic G33.1 synchronized tapping problem
Another (somewhat random) thing that came to my mind is that we can also change the 'ferror' values from gcode.
That might come in handy.
Good luck.
  • automata
  • automata
06 Feb 2025 14:06
Replied by automata on topic scurve trajectory planner
Hi Grotius,
maybe the biclothoid library stuff you and andrew2085 developed in a previos thread is awesome.
forum.linuxcnc.org/38-general-linuxcnc-q...ruckig-lib?start=350
Maybe that can be used for filleting. And since we can calculate the length of a clothoid given its start and end curvature, maybe it can be used for the S curve trajectory generator more easily and without approximating the arc length.
Thanks for working on this hard problem.
-automata
  • GeckoWorks
  • GeckoWorks
06 Feb 2025 13:26
Replied by GeckoWorks on topic Lathe Macros
Lathe Macros
Category: Other User Interfaces
I had the link for that one. Perhaps I wandered off this thread when I found it. It was a compilation of I think all of the macros showing the actual operation on a lathe much like the video you referenced, just for all the different operations quite a good video, no idea where I found it and can't seem to find it.
I think this video does a good job of going through the macros but I don't know if it's the one you had in mind:
  • Coyote
  • Coyote
06 Feb 2025 12:28
Replied by Coyote on topic scurve trajectory planner
Great news. Just some clarification: is this planner based on your work or it is based on Ruckig Lib with user @Beef : "That's why Grotius and I have decided to start this new project ...." ?
06 Feb 2025 12:22
Replied by tommylight on topic Voron Life , for anyone going into 3D printing !
Category: Additive Manufacturing
2.4 with round rods on Y and Z, and 10mm belts, not the usual 6mm.
  • spumco
  • spumco
06 Feb 2025 11:39
Replied by spumco on topic G33.1 synchronized tapping problem
Appreciate the effort.
I've had a think, and I've got one more config attempt left in me before I quit trying to have a working C-axis.
Plan is essentially what PCW suggested in my other 'freewheeling' thread.  I'm going to abandon caxis.comp, and instead use orient as a 'bridge' between velocity spindle and position-axis modes so the c-axis doesn't error out upon reconnection.
Flipping between spindle & axis will use M-codes, and I think it can be done without any halui stuff so I can do everything within the same g-code program.
I'll start a new thread when I run in to problems with this attempt.
  • my1987toyota
  • my1987toyota's Avatar
06 Feb 2025 11:19
Replied by my1987toyota on topic GUI Programmer Needed
Category: User Exchange
I  guess riju didn't need one that badly.
  • nc5tom
  • nc5tom
06 Feb 2025 10:29 - 06 Feb 2025 10:32
Replied by nc5tom on topic 7i97t setup problem
7i97t setup problem
Thanks for getting back to me.  I am away from the workshop at the moment but I will do this test as soon as I return.
Since my post I have adopted the default eeprom address 10.10.10.10  I have also set the PC to 10.10.10.11
If I type
mesaflash --addr 10.10.10.10 --device=ETHER --readhmid
The result is
Unsupported ethernet device 7i97T at 10.10.10.10
Thanks for your help
  • my1987toyota
06 Feb 2025 10:03 - 06 Feb 2025 10:57
Replied by my1987toyota on topic Voron Life , for anyone going into 3D printing !
Wait is your big one set up as a 2.4 or a Trident? Eventually I am looking to build a 2.4 version with a 600mm cubed
work envelope (or bigger). Just not this round. LOL
  • Aciera
  • Aciera's Avatar
06 Feb 2025 09:29
Well, I had a good look and compared it to NoJo's config but I'm afraid I can't wrap my head around the problem.
If i understand spindle synchronized motion correctly then it really only depends on the encoder signals connected to the 'spindle.0.' pins.
I think the most likely way figure this out is to diagnose things with hal scope on the machine and find out what is happening to the index-enable signal and z-axis motion.
I'd love to help more but I have no hardware to test any of this.
Displaying 19321 - 19335 out of 19548 results.
Time to create page: 0.432 seconds
