Lathe Macros
- Thank you received: 7465
08 Dec 2024 00:22 #316226
Replied by tommylight on topic Lathe Macros
This is the only one i could find that resembles what you describe, but no GUI is visible, just lathe doing it's thing
The following user(s) said Thank You: besriworld, slowpoke
- slowpoke
- Thank you received: 28
08 Dec 2024 18:27 #316265
by slowpoke
Replied by slowpoke on topic Lathe Macros
I had the link for that one. Perhaps I wandered off this thread when I found it. It was a compilation of I think all of the macros showing the actual operation on a lathe much like the video you referenced, just for all the different operations quite a good video, no idea where I found it and can't seem to find it.
08 Dec 2024 18:46 #316270
Yeah, i wasted 20 minutes last night looking for it, but all i could find was some very short videos of it, so either my serach-foo is failing me or google has gone completely off the rails. I am rooting for the latter:)
The following user(s) said Thank You: slowpoke
- slowpoke
10 Dec 2024 07:57 #316380
by slowpoke
Perhaps it's my imagination but it seems like Google in the past was better at searching out general information, lately it seems to favour merchandise over information.
- vibram
10 Jan 2025 07:44 #318621
by vibram
Replied by vibram on topic Lathe Macros
Hello
Thank you for all the work done
is there a way to open a tab (for example facing) directly with a physical button?
I tried to do so but without luck yet
- besriworld
- Thank you received: 91
24 Jan 2025 09:44 #319753
by besriworld
Replied by besriworld on topic Lathe Macros
I have a question. Is it possible for the machine not to start when I press the Play button, but instead to load the G-code?
- GeckoWorks
- Thank you received: 8
06 Feb 2025 13:26 #320829
by GeckoWorks
Replied by GeckoWorks on topic Lathe Macros
I think this video does a good job of going through the macros but I don't know if it's the one you had in mind:I had the link for that one. Perhaps I wandered off this thread when I found it. It was a compilation of I think all of the macros showing the actual operation on a lathe much like the video you referenced, just for all the different operations quite a good video, no idea where I found it and can't seem to find it.
- slowpoke
06 Feb 2025 20:06 #320839
by slowpoke
I'm a bit clueless regarding the available lathe type GUI's (I'm starting with axis), what version is this fellow using?
Are those the "lathe macros" he is using?
That is a different video, however somewhat similar. For a small lathe he sure is getting good results.
- GeckoWorks
07 Feb 2025 03:41 - 07 Feb 2025 03:58 #320875
by GeckoWorks
But also, I feel like I saw and bookmarked posts about succesfully getting Andy's lathe macros into Probe Basic, which is a really swank looking UI. But I can't find that info now or perhaps it was a dream;). Anyone...?
I could be wrong as I am very new - only ever got my first Mesa cards the other day - for my little mill. Cnc lathe is still in planning stages.
So, someone will correct me if I am wrong, but I think the UI used is Cmoccappy indeed with Andy's Lathemacros.
Last edit: 07 Feb 2025 03:58 by GeckoWorks.
- Chriss26
02 May 2025 12:48 #327496
by Chriss26
Replied by Chriss26 on topic Lathe Macros
Hello,
I'm new to Linux CNC. I've installed the macros and can also enter inputs in the mask. When I start the machine, the spindle starts rotating, but nothing else happens.
Both axes aren't moving.
Can anyone give me a tip as to what might be causing this?
LinuxCNC 3.4.6
LinuxCNC 3.4.6
Time to create page: 0.267 seconds
