  • rodw
  • rodw's Avatar
07 Jan 2025 11:32
Replied by rodw on topic Black Friday Deal got me :)
Category: Plasma & Laser
You could make up some machined blocks for your 4 jaw to hold rectangular tube centrally. eg 3" x 2" would need 2 x 1/2" blocks to make it a square.
  • machinedude
  • machinedude's Avatar
07 Jan 2025 11:26
Replied by machinedude on topic Black Friday Deal got me :)
been looking into this and i think it can be done but it is not cheap project :) off the shelf options are either through the roof in price or yet to be discovered. even making the stuff myself is going to be expensive by my standards and could see costing around $400 per chuck. So that being said i think i will start with a rotary union to see if i can pull that off and go from there :) without that the whole idea goes out the window :)
  • JT
  • JT's Avatar
07 Jan 2025 11:20
Replied by JT on topic Flexible GUI
Flexible GUI
Category: Flex GUI
I installed the new deb from releases but it doesn't seem to be adding anything new. I don't have qabstractproperties on the pushbutton whether I set it inside the stacked widget or not. Do I have to do anything special when upgrading flexgui?
I'm not sure what qabstractproperties is, what are you trying to do with that?
If you download the deb from the latest release and install it with gdebi or your favorite way you have the latest.
I'll add a screenshot to the docs.
JT
  • MacKaye
  • MacKaye
07 Jan 2025 10:56
Replied by MacKaye on topic Weiler DZ26 Millturn Conversion
Category: Turning
Finally came around to start implementing everything. Freshly installed linuxcnc doesn´t recognize the mesa card though. I've set W5 down to load basic configuration in case the eeprom firmware has some issues. I can only see the Texas Instruments PCIE bridge when i list all connected PCI hardware in terminal
  • TooTall18T
  • TooTall18T's Avatar
07 Jan 2025 08:17
Replied by TooTall18T on topic Handrad xhc-whb04b-6
Category: Deutsch
Zuerstmal egal ob die Leitungs- oder die Funkvariante, die Verbindung über USB ist nicht sicher. Heißt, die Funktionen können, müssen aber nicht funktionieren.
Ich persönlich wollte aber die zusätzliche Unsicherheit mit der Funkverbindung nicht haben.
Vom Handrad gibt es jeweils eine 4- und 6-Achsvariante.
Ich denke nicht, dass da unterschiedliche Hersteller hinter stecken. Die werde alle aus der gleichen Fabrik kommen.
  • Aciera
  • Aciera's Avatar
07 Jan 2025 07:43
Replied by Aciera on topic MB2HAL write
MB2HAL write
Category: HAL
Have you tried
MB_TX_CODE=fnct_16_write_multiple_registers
  • onceloved
  • onceloved's Avatar
07 Jan 2025 06:41
Exercise: Turn on output led on EL2809 when machine is turned on
Category: EtherCAT
You can set it directly via setp, for example, setp lcec.0.1.output-pin 1. For detailed instructions, see this link linuxcnc.org/docs/stable/html/hal/basic-hal.html#sub:hal-setp
  • rodw
  • rodw's Avatar
07 Jan 2025 05:29
Replied by rodw on topic THCAD 10 question
THCAD 10 question
I wouldn't use the 50:1 voltage divider. a THCAD5 with a 5 volt full scale would be more suited to use with it. Instead just calibrate the THCAD to read 200 to 300 volts full scale with a resistor.
  • gblcody
  • gblcody's Avatar
07 Jan 2025 03:15
Probe basic Install errors was created by gblcody
Category: QtPyVCP
Hey guys, I'm struggling. I am beyond frustrated with trying to get Probe Basic to launch fully. I have been trying to get this to work since a few days before Christmas.
Here is what I know.
I can launch the Dev with the sim on the PC.
I figured out that one of my issues was the screen size. I now have a compatible screen installed.
I have reinstalled the bookworm iso and followed the instructions several times.
I have cleaned and wiped the system at least 6 times and always come back to an error launching.
i was having the issue of probe basic not launching due to a ini dual hal file error but after a wipe and reinstall and apt repair it seems to have gone away.
I am still getting can not start display probe basic. I have gone through the configs several times and started fresh with my ini and hal files and still can not get it to launch via Linux CNC launcher with my setup files.
Any advice? I would greatly appreciate it.
  • ric812
  • ric812
07 Jan 2025 03:13
THCAD 10 question was created by ric812
THCAD 10 question
I have a Mesa 7i96s card with a THCAD - 10. Do I need a voltage divider for this? I purchased two resistors - 2.4M OHM 1/2W 1% AXIA ( digikey ) as well as a 50:1 voltage divider ( CNCpc ). Do I need both?
  • vre
  • vre
07 Jan 2025 02:57 - 07 Jan 2025 11:44
MB2HAL write was created by vre
MB2HAL write
Category: HAL
I have got this modbus 16 I/O module 485io.com/io-isolation-protection-board-...relay-led-p-373.html
This is the manual 485io.com/eletechsup/N4D3E16-1.rar
I have used this config to mb2hal and i can read in hal all 16 inputs with success
[TRANSACTION_00]
LINK_TYPE=serial
SERIAL_PORT=/dev/ttyS0
SERIAL_BAUD=9600
SERIAL_BITS=8
SERIAL_PARITY=none
SERIAL_STOP=1
SERIAL_DELAY_MS=500
MB_SLAVE_ID=1
FIRST_ELEMENT=129
PIN_NAMES=mb1,mb2,mb3,mb4,mb5,mb6,mb7,mb8,mb9,mb10,mb11,mb12,mb13,mb14,mb15,mb16
MB_TX_CODE=fnct_03_read_holding_registers
But i can't write 16 outputs.
How can make it to work ?
How can i send custom command with mb2hal like this?
(slave address)0x01 (function)0x06 (number of output)0x0001 (command)0x05 (delay time)0x00 (2Bytes CRC)
  • cmorley
  • cmorley
07 Jan 2025 02:07
Replied by cmorley on topic QTDesigner PATH issue
There was nothing else printed in the terminal after the code change?
Can you give more background? Has this ever worked?
  • blazini36
  • blazini36
07 Jan 2025 00:50
Replied by blazini36 on topic Flexible GUI
Flexible GUI
Category: Flex GUI
  • dogsop
  • dogsop
07 Jan 2025 00:04
Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
Category: Installing LinuxCNC
Yes what is there is 2.9.2.
Downloaded 2.9.3 and it makes a huge difference for me on the Pi 5.
I wasn't getting 1080p on the display and axis was always clipped and wouldn't show me the status area at the bottom of the screen.
Switched to the newer build and I've got 1080p and can see the full screen.
Thanks!
  • rodw
  • rodw's Avatar
06 Jan 2025 23:43
I think so but it seems that 2.9.3 may not be  on the downloads page.
Displaying 20476 - 20490 out of 21723 results.
Time to create page: 0.452 seconds
