16 Aug 2024 15:47
Ethercat installation from repositories - how to step by step
Category: EtherCAT
Latency is OK, so the kernel should work just fine.
No idea if it works for EtherCAT though, although in general should work if the same headers are used.
16 Aug 2024 15:43
Replied by tommylight on topic löschen fehlerhafter topics
Category: Deutsch
Was fuhr ein topic, oder welche topic.
  • dave.franchino@gmail.com
16 Aug 2024 15:37
Replied by dave.franchino@gmail.com on topic configuring GPIO for a Raspberry Pi 4B
Category: Configuration Tools
Oh thank you so very much! I thought I was going crazy. Your explanation makes a lot of sense.
Might be nice to add a note to that document to clarify this as it's not incredibly obvious. I'm a LinuxCNC newby and I'm not sure of the protocol for making changes like this but if it's something I can or should do I'm happy to try adding a note. Thanks again!
  • elovalvo
  • elovalvo
16 Aug 2024 15:29
Replied by elovalvo on topic configuring GPIO for a Raspberry Pi 4B
and everything is right!
The fact is that the pin outs of the Raspberry are inputs for the LinuxCNC and vice versa...
You will see that if you configure input pins with hal_pi_gpio, in the halcmd show pin command they will be shown as OUT
  • chernogorsky
  • chernogorsky
16 Aug 2024 15:15
Replied by chernogorsky on topic qtdragonhd / probing
Category: Qtvcp
I think if tool measuring button is pressed it should be set same as for tool height
but again, Im not the real CNC guy,
I can live with manual process, its good enough for me
  • vick.trinity
  • vick.trinity's Avatar
16 Aug 2024 15:15
Re-enable drives after a fault was created by vick.trinity
I am using LinuxCNC to drive a PUMA type robot with brushed DC motors, encoders, and harmonics on each joint.  I have a 7i77 and 5i25 controlling 5 AMD motor drives for control.    Unfortunately, the joints do not have brakes, so every time get an FERROR fault, all drives are disabled and the arm drifts down until I can run over to the computer and re-enable the drives.
Can I alter my HAL file to pause after a fault and then re-enable the drives automatically?  I have found some messages that are on the right track like:
"I would use a combination of a timedelay hal component connected to the amp enable output, then the output of that to an and2 comp combined with the fault input from the drive, then the output of the and2 to motion.axis.N.amp-fault-in. This would essentially disable the amp's fault signal until the timdelay expires after turning on. "  from Todd Z
But, I've got to say - the HAL file is like my grasp of Spanish.  I can read it and get the gist of what is happening, but ask me to actually write something correct and I am illiterate.  I'm going to need some hand holding I'm afraid.
16 Aug 2024 15:12
That is exactly the document I have been using. As a test I tried to configure just one GPIO pin as an output - but when I run Halcmd Show Pins in a terminal that pin is showing up with direction set to "in"
Is there any chance that I don't understand what "Show Pins" is reporting. What does "direction" mean in this context - is there any chance that I do want direction to be "in" for an output? That seems unlikely.
  • PhilipME
  • PhilipME's Avatar
16 Aug 2024 15:06
Replied by PhilipME on topic connecting a soft button to bob pin 17
I will read and try it
  • chernogorsky
  • chernogorsky
16 Aug 2024 14:57
Replied by chernogorsky on topic [QTDragon] blocking in hal_manualtoolchange dialog
Category: Qtvcp
lcnc 2.10-dev (builded from master)
I saw that,
I want to avoid multiple steps,
What I need is run a command from the dialog (by button from a dialog, or by external signal like pendant)
my imaginary flow be like
programm triger TxM6
it goes to change location
shows toolchange dialog
I change the tool by pressing additional button on a dialog / phisical button on a pendant
press OK
and it continue its procedure with qc_autotool_change macro
Im looking for a solution to overcome blocking during dialog or
replace that dialog with my own, without the need of changing dialog_widget.py file (and keep the changes all the time I update the lcnc)
all the rest would be handled by the program itself, including spindle speed, locations, ...
in short I want to have another action during manual change, since I dont need to work with wrenches rather button click
priv I had air release button closeby, but after rewiring all the air contorls goes to the back side of my cnc (
I would consider adding phisical button for tool replace later, but it would be through lcnc logic, not directly, means - I need lcnc be not blocked (
  • AlessandroEmm
  • AlessandroEmm
16 Aug 2024 14:56
Replied by AlessandroEmm on topic Beginners homing woes
Category: Basic Configuration
Thanks Todd for looking over my setup.
Your laying out of the not-so-clear configuration led me to move things where they belong. The Z-Axis Configuration is driven by Joint 3. But since I only added the second Y later, it came after the Z's definition.
When I changed the ordering I realised that my homeing Order wasn't correct either. Which led to the situation that LinuxCNC would try to home an axis that i hadn't attached yet (Z's Joint). Which then in turn would lead to a situation where Y and X would never home and me waiting forever. Having now fixed the priorities, axis do home as they should. Thanks for pushing me to it!
That said for the Gantry: does it make sense to use keep the trivial trajectory setup or would I rather use one of the available gantry components to manage Y? I havent really found pros and cons online. Both side of the gantry should are fixed by leadscrews so theres little to no tilting possible.
Thanks again,
Alessandro
  • G0G53Z148
  • G0G53Z148's Avatar
16 Aug 2024 14:50
Replied by G0G53Z148 on topic Aktuelle hardware mit PCI
Category: Deutsch
danke es läuft schon es werden sicher andere config sachen auch kommen es musste einfach der pci-x adapter gegen einen anderen hersteller getauscht werden
wir sind es gewohnt viele frösche zu küssen bis die prinzessin erscheint :)
danke für die inspiration
  • PCW
  • PCW's Avatar
16 Aug 2024 14:44
  • Aciera
  • Aciera's Avatar
16 Aug 2024 14:36
Replied by Aciera on topic Spindle stop from G-code (M05)
Category: HAL
If you want an M5 gcode to shut your spindle off you would probably want to use an internal motion pin like 'spindle.0.on' and invert that.
linuxcnc.org/docs/html/man/man9/motion.9.html
  • Aciera
  • Aciera's Avatar
16 Aug 2024 14:08 - 16 Aug 2024 14:26
Replied by Aciera on topic How to setup gearbox/reducer
Actually, looking at this more closely, it's probably specific to dmitrys Mechatrolink hardware as 'nyx' refers to his hardware driver:
setp nyx.0.servo-00.pos-scale [JOINT_0]SCALE
Looks like you have an EtherCAT setup so my input is not really relevant after all.
[edit]
I would expect that you need set the gear ratio in the motor drives.
Displaying 23836 - 23850 out of 24348 results.
Time to create page: 0.887 seconds
