  • gpasotti
  • gpasotti's Avatar
31 Jul 2024 09:56
Can LinuxCNC work on a Rotary Transfer Machine?
By Rotary transfer I mean a milling machine with a rotary table with multiple stations, each station is like higly customized lathe, it holds a working piece and has multiple Units that perform a specific work on the piece.
Each Unit is composed by multiple axis depending on the complexity of the work, for certain a spindle and at least the z axis, but could even have x y z axis.
Something like this:
I also foud this to help define it: en.wikipedia.org/wiki/Rotary_transfer_machine
  • Aciera
  • Aciera's Avatar
31 Jul 2024 09:35 - 31 Jul 2024 09:45
Do you mean something like this:
[edit]
If so, that is not really an application I would choose LinuxCNC for but as a proof of concept why not. Although I would probably much prefer to use a PLC.
  • Aciera
  • Aciera's Avatar
31 Jul 2024 09:33
Planning moves. Lookahead over short vectors and blending vectors.
Category: LinuxCNC Documents
It started to be an issue mainly on very fast routers and plasma cutters, and when CAM started to be more readily available (and, to an extent, when it started being used by novice CNC-ers who assume that the smallest possible path length mush be highest resolution and therefore the best.
Exactly.
Here is a good example of how simply changing the CAM settings may fix slow Gcode execution despite the one line lookahead:
forum.linuxcnc.org/38-general-linuxcnc-q...ving-too-slow#306462
  • gpasotti
  • gpasotti's Avatar
31 Jul 2024 09:31
Hello,
I am new here and overall in the CNC world.
I just wondered if LinuxCNC is suitable for Multi-Station like Rotary and Linear Transfer Machines, that have many Units and Axis, at least many more than what I have seen in the examples.
And if not what would take to make it so?
Thanks in advance,
G.Pasotti
  • Aciera
  • Aciera's Avatar
31 Jul 2024 09:21
Replied by Aciera on topic Is a parport fast enough?
well... thanks for your help
I'm sorry but it's just like last time you asked for advice here:
forum.linuxcnc.org/27-driver-boards/5109...17x0?start=10#288989
You turn up with some hallucination and expect other people to make it come true for you.
  • IronManDylan
  • IronManDylan
31 Jul 2024 09:10
Replied by IronManDylan on topic Simultaneous 4th Axis Cut Moving Too Slow
Wow aciera youre right again. I cant believe that was the issue. But if anyone is seeing this in the future turn up your smoothing and tolerence in fusion 360.
My line segments are about 1 to .5 thou now (they were down at about a 10th before) and i can get up to somewhere about 60-80 percent of my feedrate which is way faster. Theres work to be done if I needed to cut a bunch of aluminum but this is a test cut for inconel, so this speed will work just fine!
Thank you sir!
  • AndriySM
  • AndriySM
31 Jul 2024 09:08
Ethercat installation from repositories - how to step by step
Category: EtherCAT
I tried to reinstall everything from scratch, to no avail, the keys are not updated. I think we should intervene on the image
  • Aciera
  • Aciera's Avatar
31 Jul 2024 09:02
Replied by Aciera on topic SPINDLE USING GPIO
SPINDLE USING GPIO
Joint 0 following error is the difference between 'joint.0.motor-pos-cmd' and ' joint.0.motor-pos-fb'.
If this exceeds the limits defined as 'FERROR' and 'MIN_FERROR' in the [JOINT_0] section a fault is triggered and you get an error message.
If you are getting joint following errors on startup I would suggest to have a look at pins 'joint.0.motor-pos-cmd' and ' joint.0.motor-pos-fb'. Possibly you are simply not connecting 'motor-pos-fb' with a value in your hal.
  • hectormhr
  • hectormhr
31 Jul 2024 08:40
Experience with Moons Industries Ethercat Servo
Category: EtherCAT
I was wondering if anyone could comment on experiences (good, bad, indifferent) on Moons' Industries Ethercat drives, specifically M54S-24A5ECN.
www.moonsindustries.com/p/m54s-series-un...n-000004696351007109
If not, would it be possible to summarise in a general sense what things to watch out for / would need doing to make it work with LinuxCNC.
P.S: first post in this forum - thanks in advance for all the hard work that has obviously gone into LinuxCNC and to the community!
  • Aciera
  • Aciera's Avatar
31 Jul 2024 08:25 - 31 Jul 2024 08:26
Replied by Aciera on topic Simultaneous 4th Axis Cut Moving Too Slow
Two things to note here.
1. Since this involves blending linear and angular joints try using inverse time (G93) instead of G94
2. Generally the CAM/PP will generate 4axis Gcode made up of short line segments. Since the MotionPlanner in LinuxCNC will fall back to one line look ahead for any move involving any other than X,Y,Z axes it is important that the line segments are not made too short. So to speed things up you should also try to get the CAM to generate longer line segments.
  • Aciera
  • Aciera's Avatar
31 Jul 2024 08:11
Replied by Aciera on topic Yaskawa Absolute Encoder and Mesa Hardware
Category: Driver Boards
Not exactly the same manual but contains the same information in section 8.4.6:
assets.omron.eu/downloads/manual/en/sigm..._users_manual_en.pdf
  • viesturs.lacis
  • viesturs.lacis
31 Jul 2024 08:04 - 31 Jul 2024 08:06
Replied by viesturs.lacis on topic Yaskawa Absolute Encoder and Mesa Hardware
Hello Gurpreet!
Could you please share whole pdf document? I am struggling with Yaskawa incremental encoders and their C channel in particular because at least those encoders I have use the C channel to commutate rotor position. And it seems that your manual might be useful.
31 Jul 2024 07:44
Replied by tommylight on topic Is a parport fast enough?
To many things wrong there
-parallel port can NOT do all inputs in any of it's modes
-parallel port has 17 I/O in total, there are inputs 18 and 19 mentioned on the first post
so i agree with Cornholio, it is rubbish and will waste more time than asking humans
Parallel port can do
-mode out = 12 out 5 in
-mode in = 13 in 4 out
-mode X = 8 out 9 in
And LinuxCNC can control multiple at the same time.
  • Lpkkk
  • Lpkkk
31 Jul 2024 07:41 - 31 Jul 2024 08:10
Thank you Scott for verifying. I've tried with 3.1.3 but after flashing I've got an error in rs232 debug (attached). And the board stopped responding to ping. So I've tried 3.1.2 but now board stopped displaying any debug info and I cannot reflash it because of another error from pyocd (attached).
Displaying 24706 - 24720 out of 24825 results.
Time to create page: 0.540 seconds
