- Configuring LinuxCNC
- Advanced Configuration
- EtherCAT
- Ethercat installation from repositories - how to step by step
- jjdege
- Thank you received: 38
30 Jul 2024 06:38 - 30 Jul 2024 06:44 #306381
by jjdege
Replied by jjdege on topic Ethercat installation from repositories - how to step by step
hi Rod
everything is still broken here, I read the answer Bjarne, I don't understand if there is a way to restore things, I tried without success
many thanks
many thanks
Last edit: 30 Jul 2024 06:44 by jjdege.
- AndriySM
31 Jul 2024 09:08 #306477
by AndriySM
Replied by AndriySM on topic Ethercat installation from repositories - how to step by step
I tried to reinstall everything from scratch, to no avail, the keys are not updated. I think we should intervene on the image
- jjdege
31 Jul 2024 10:07 - 31 Jul 2024 10:21 #306487
by jjdege
Hi
waiting for a more suitable solution
I solved it almost like zylos146.
I searched and deleted all the ethercat-dkms folders, including the .deb
then I downloaded ethercat-stable-1.6 from
gitlab.com/etherlab.org/ethercat
followed the installation from install.md everything went well.
then I performed the standard installation here
it no longer returns errors
Hi
Hi
Last edit: 31 Jul 2024 10:21 by jjdege.
The following user(s) said Thank You: AndriySM
- AndriySM
31 Jul 2024 10:57 #306492
by AndriySM
jjdege .Thank you, I'll try to do that this evening, I hope to succeed
- Thank you received: 4149
31 Jul 2024 11:33 #306498
I built a new image. The keys have been fixed but I am getting a dkms erorr so no joy.
I've updated the issue upstream, gitlab.com/etherlab.org/ethercat/-/issues/131
so hopefully they will fix it soon. They have always beeen very good to me
Replied by rodw on topic Ethercat installation from repositories - how to step by step
Not quite out of the woods. the changes were pushed to the LInuxcnc code on github.Hi
Hi
The following user(s) said Thank You: tommylight, jjdege, AndriySM
- Moutomation
- Thank you received: 11
01 Aug 2024 13:16 #306610
by Moutomation
Replied by Moutomation on topic Ethercat installation from repositories - how to step by step
Err:1 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ ethercat-dkms 1.5.2.429.g3079ece-1+392.1
404 Not Found [IP: 195.135.223.226 80]
Err:2 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ ethercat-master 1.5.2.429.g3079ece-1+392.1
Err:3 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ libethercat 1.5.2.429.g3079ece-1+392.1
Err:4 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ linuxcnc-ethercat 1.25.1.g180ad89-0
E: Failed to fetch download.opensuse.org/repositories/scien...ce-1%2b392.1_all.deb 404 Not Found [IP: 195.135.223.226 80]
E: Failed to fetch download.opensuse.org/repositories/scien...-1%2b392.1_amd64.deb 404 Not Found [IP: 195.135.223.226 80]
E: Failed to fetch download.opensuse.org/repositories/scien...g180ad89-0_amd64.deb 404 Not Found [IP: 195.135.223.226 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Err:4 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ libethercat-dev 1.5.2.429.g3079ece-1+392.1
Err:5 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ linuxcnc-ethercat 1.25.1.g180ad89-0
I've done this before on another computer and there was no problem. Is there a problem with the computer?
- jjdege
01 Aug 2024 20:19 - 01 Aug 2024 20:28 #306667
by jjdege
thanks!
everything is working again, even on Raspy Pi5
thanks to everyone
thanks to everyone
Last edit: 01 Aug 2024 20:28 by jjdege.
- jjdege
01 Aug 2024 20:24 - 01 Aug 2024 20:30 #306669
by jjdege
sorry double
Last edit: 01 Aug 2024 20:30 by jjdege.
02 Aug 2024 22:23 #306812
Now fixed. They had a bug in the DKMS deb files. Grab this Linuxcnc ISO which has the new keys in it.
ISO: drive.google.com/file/d/1gEQzgHsj_LjHiGB...k1Z/view?usp=sharing
Folder with all generated files: drive.google.com/drive/folders/1pwDh_jn8...QcQwcLv7?usp=sharing
This ISO also corrects installing a pre-release version of Linuxcnc and no installs 2.93 as intended.
I have asked the devs to copy this ISO to the downloads page.
The following user(s) said Thank You: tommylight, endian, onceloved, jjdege, dacb
- jdowsonjr
04 Aug 2024 15:20 #306927
by jdowsonjr
Replied by jdowsonjr on topic Ethercat installation from repositories - how to step by step
tried to write the iso from the post above to a usb twice. Both times after selecting locale in the installer i get that a file failed to be copied
live enviroment works fine but the installer is not there
has anybody else tried it?
- EtherCAT
Time to create page: 0.590 seconds
