Ethercat installation from repositories - how to step by step
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
21 Jun 2026 10:21 #347185 by rodw
I've never seen the sysv error before.
Odd others have got the new method working already.
You need to use sudo for systemctl and journalctl. Can you redo and share?
  • grandixximo
  • grandixximo's Avatar
  • Platinum Member
  • Platinum Member
21 Jun 2026 12:15 #347189 by grandixximo
check the output of these command
systemctl status ethercat.service
sudo journalctl -xeu ethercat.service --no-pager
dkms status | grep -i ethercat        # module built for running kernel?
uname -r                              # running kernel matches?
lsmod | grep ec_                     # loaded?
sudo modprobe ec_master              # manual load - shows real error
Is your /etc/ethercat.conf properly set?
21 Jun 2026 17:44 #347195 by spumco
[Forum/internet is being really unresponsive, bear with me]
Thanks gents for having a look.  Here's the terminal outputs:
Warning: Spoiler!
Yes.  Added MAC addr for enp2s0 and "generic"
mill@debian:~$ sudo dkms status | grep -i ethercat
[sudo] password for mill:
ethercat/1.6.9: added
mill@debian:~$ uname -r
6.12.86+deb13-rt-amd64
mill@debian:~$ lsmod | grep ec_
typec_ucsi             69632  1 ucsi_acpi
typec                 114688  1 typec_ucsi
roles                  16384  1 typec_ucsi
usb_common             16384  3 xhci_hcd,usbcore,typec_ucsi
mill@debian:~$ sudo modprobe ec_master
modprobe: FATAL: Module ec_master not found in directory /lib/modules/6.12.86+deb13-rt-amd64
So it looks like something didn't get installed properly despite just pasting the linuxcnc-ethercat apt stuff from GH instructions.
21 Jun 2026 17:48 #347196 by spumco
Further terminal output after trying to re-install ethercat-master below:
Warning: Spoiler!
21 Jun 2026 18:14 #347197 by spumco
And the contents of make.log referenced in the "Error!" line in last post:
DKMS (dkms-3.2.2) make.log for ethercat/1.6.9 for kernel 6.12.86+deb13-amd64 (x86_64)
Sun Jun 21 13:46:11 EDT 2026
Building module(s)
# command: ./bootstrap && ./configure --with-linux-dir=/lib/modules/6.12.86+deb13-amd64/build --enable-generic --enable-8139too --enable-e100 --enable-e1000 --enable-e1000e --enable-r8169 --enable-igb --enable-igc --enable-genet --disable-stmmac-pci --disable-dwmac-intel --disable-ccat --disable-eoe --enable-cycles --enable-hrtimer --disable-rtdm --disable-debug-if --disable-debug-ring --disable-regalias --disable-tty --disable-wildcards --enable-sii-assign --enable-rt-syslog && make modules
+ touch ChangeLog
+ mkdir -p m4
+ autoreconf -i
./bootstrap: line 32: autoreconf: command not found
# exit code: 127
# elapsed time: 00:00:00
  • grandixximo
  • Platinum Member
  • Platinum Member
22 Jun 2026 02:29 - 22 Jun 2026 02:50 #347203 by grandixximo
try the commands below
sudo apt install autoconf automake libtool pkg-config linux-headers-$(uname -r)
sudo apt --fix-broken install      # clears half-configured linux-image/headers
sudo dkms autoinstall
dkms status | grep ethercat        # want "installed", not "added"
sudo systemctl start ethercat.service
This is mostly due to missing dependencies, I will add the additional dependencies to the package, should not happen next time.
Last edit: 22 Jun 2026 02:50 by grandixximo.
22 Jun 2026 03:53 #347206 by spumco
That seems to have worked, sort of.
I got the following errors while pasting the commands:
Warning: Spoiler!
fix-broken install and dkms autoinstall seemed to have worked (no errors)
dkms status | grep ethercat reported "installed"
systemctl status ethercat.service:
Warning: Spoiler!
But final commands got an error:
mill@debian:~$ sudo chmod 666 /dev/EtherCAT0
chmod: cannot access '/dev/EtherCAT0': No such file or directory
mill@debian:~$ ethercat slaves
Failed to obtain number of masters: Failed to open master device /dev/EtherCAT0: No such file or directory
I wonder if the "dev" folder is for a RIP install?
22 Jun 2026 04:08 #347207 by spumco
sudo apt update and upgrade seems to have fixed whatever was wrong.
after reboot:
mill@debian:~$ sudo systemctl start ethercat.service
0  0:0  INIT  E  AS715N_sAxis_V0.10
1  0:1  INIT  E  AS715N_sAxis_V0.10
2  0:2  INIT  E  AS715N_sAxis_V0.10
3  0:3  INIT  E  AS715N_sAxis_V0.10
I think I'm in business.
Thanks a ton for the assistance.
The following user(s) said Thank You: grandixximo, rodw
  • rodw
  • Platinum Member
  • Platinum Member
22 Jun 2026 05:23 #347210 by rodw
Spumco, great work. If you have to manually start the service each time. sounds like you overlooked the udev rules in the first post, Sorry about the formatting errors but its an awful post to edit
sudo geany /etc/udev/rules.d/99-ethercat.rules
and the following code block.
22 Jun 2026 10:38 #347216 by spumco
Rod - I hadn't actually gotten to that section of the installation yet.  The first 'ethercat slaves' check is before the 99-ethercat.rules line.
I just stopped when I got the errors starting ethercat service for the first time.  Bulldozing ahead past errors has not served me well in the past, despite my habitual attempts.
Time to create page: 0.986 seconds
