- Configuring LinuxCNC
- Advanced Configuration
- EtherCAT
- Ethercat installation from repositories - how to step by step
- kor
19 Nov 2025 19:20 - 19 Nov 2025 19:23 #338747
by kor
Replied by kor on topic Ethercat installation from repositories - how to step by step
Is there any more information I can provide to narrow down the problem?after
sudo apt install build-essential
unfortunatly I receive the same error mesage
folgenden Pakete haben unerfüllte Abhängigkeiten: ethercat-dkms : Hängt ab von: libtool ist aber nicht installierbar Hängt ab von: autoconf ist aber nicht installierbar Hängt ab von: autoconf-archive ist aber nicht installierbar Hängt ab von: automake ist aber nicht installierbar E: Probleme können nicht korrigiert werden, Sie haben zurückgehaltene defekte Pakete.
unfortunatly in german but basically libtool autoconf, ... can not be installed
I tried to install libtool individually: and I get the error message:
For the paket libtool there is no install candidate.
(my translation)
Last edit: 19 Nov 2025 19:23 by kor.
- Thank you received: 4149
19 Nov 2025 19:42 #338749
Replied by rodw on topic Ethercat installation from repositories - how to step by step
Strange. all packages are available in the Debian repositories (libtool,autoconf,autoconf-archive,automake) packages.debian.org/search?suite=default...mes&keywords=libtool
Even stranger because iGh the ethercat master developer is a German company.. I wonder if its a language/locale issue? I can't help
- Hakan
- Thank you received: 454
19 Nov 2025 20:42 - 19 Nov 2025 20:42 #338756
by Hakan
Replied by Hakan on topic Ethercat installation from repositories - how to step by step
Try
For me is says it can find libtool at
*** 2.5.4-4 500
500 deb.debian.org/debian trixie/main amd64 Packages
But I'm on trixie so not identical.
apt depends ethercat-dkms
apt policy libtoolFor me is says it can find libtool at
*** 2.5.4-4 500
Last edit: 19 Nov 2025 20:42 by Hakan.
- Thank you received: 7478
19 Nov 2025 21:43 #338759
Replied by tommylight on topic Ethercat installation from repositories - how to step by step
Did you do
sudo apt update
before
sudo apt update
before
- kor
19 Nov 2025 22:24 #338762
by kor
hängt ab von means depends on
keine means none
unfortunatly i did do the sudo apt update already that would be to easy
just tried again and tried the build essentials afterwards it tells me it is already the newest version 12.9
should I do a reinstall with the english language? It seems od to me that this would depend on the language.
ethercat-dkms
Hängt ab von: dkms (>= 2.1.0.0)
Hängt ab von: <libtool>
Hängt ab von: <autoconf>
Hängt ab von: <autoconf-archive>
Hängt ab von: <automake>
Hängt ab von: pkg-config
pkgconf
bf20@BF20:~$ apt policy libtool
libtool:
Installiert: (keine)
Installationskandidat: (keine)
Versionstabelle:keine means none
- Hakan
19 Nov 2025 22:31 #338763
by Hakan
Is /etc/apt/sources.list broken?
- kor
20 Nov 2025 09:37 - 20 Nov 2025 09:37 #338780
by kor
how do i test this? (and fix if broken)
Last edit: 20 Nov 2025 09:37 by kor.
- Hakan
20 Nov 2025 09:40 #338781
by Hakan
Show the content here it's not many lines.
- kor
20 Nov 2025 11:55 #338788
by kor
That seems to be the problem
/etc/apt/sources.list contains only one line and i guess it wants the DVD i used to install it:
deb cdrom:[Debian GNU/Linux 12 _Bookworm_ - Official Snapshot amd64 LIVE/INSTALL Binary 20250127-13:30]/ bookworm contrib main non-free non-free-firmware
- Hakan
20 Nov 2025 12:02 - 20 Nov 2025 12:07 #338789
by Hakan
That won't work.
wiki.debian.org/SourcesList#Examples take the example for bookworm, I think you are on Debian 12.
You can add contrib to all lines, like "main contrib non-free" etc. Its says that on line 2 btw.
Last edit: 20 Nov 2025 12:07 by Hakan.
The following user(s) said Thank You: kor
- EtherCAT
Time to create page: 0.946 seconds
