Ethercat installation from repositories - how to step by step
- awallin
more /var/lib/dkms/ethercat-dkms/1.6.9/build/make.log
CC [M] /var/lib/dkms/ethercat-dkms/1.6.9/build/devices/stmmac/dwmac-intel-6.12-ethercat.o
/var/lib/dkms/ethercat-dkms/1.6.9/build/devices/stmmac/dwmac-intel-6.12-ethercat.c: In function ‘intel_mgbe_common_data’:
/var/lib/dkms/ethercat-dkms/1.6.9/build/devices/stmmac/dwmac-intel-6.12-ethercat.c:615:15: error: ‘struct plat_stmmacenet_data’ has no member named ‘msi_lpi_vec’; did you mean ‘msi_mac_vec’?
615 | plat->msi_lpi_vec = 28;
| msi_mac_vec
/var/lib/dkms/ethercat-dkms/1.6.9/build/devices/stmmac/dwmac-intel-6.12-ethercat.c: In function ‘stmmac_config_multi_msi’:
/var/lib/dkms/ethercat-dkms/1.6.9/build/devices/stmmac/dwmac-intel-6.12-ethercat.c:1001:19: error: ‘struct plat_stmmacenet_data’ has no member named ‘msi_lpi_vec’; did you mean ‘msi_mac_vec’?
1001 | if (plat->msi_lpi_vec < STMMAC_MSI_VEC_MAX)
| msi_mac_vec
/var/lib/dkms/ethercat-dkms/1.6.9/build/devices/stmmac/dwmac-intel-6.12-ethercat.c:1002:59: error: ‘struct plat_stmmacenet_data’ has no member named ‘msi_lpi_vec’; did you mean ‘msi_mac_vec’?
1002 | res->lpi_irq = pci_irq_vector(pdev, plat->msi_lpi_vec);
| msi_mac_vec
/var/lib/dkms/ethercat-dkms/1.6.9/build/devices/stmmac/dwmac-intel-6.12-ethercat.c: In function ‘intel_eth_pci_probe’:
/var/lib/dkms/ethercat-dkms/1.6.9/build/devices/stmmac/dwmac-intel-6.12-ethercat.c:1084:15: error: ‘struct plat_stmmacenet_data’ has no member named ‘msi_lpi_vec’; did you mean ‘msi_mac_vec’?
1084 | plat->msi_lpi_vec = STMMAC_MSI_VEC_MAX;
| msi_mac_vec
make[5]: *** [/usr/src/linux-headers-6.12.86+deb13-common-rt/scripts/Makefile.build:234: /var/lib/dkms/ethercat-dkms/1.6.9/build/devices/stmmac/dwmac-intel-6.12-ethercat.o] Error 1
make[4]: *** [/usr/src/linux-headers-6.12.86+deb13-common-rt/scripts/Makefile.build:471: /var/lib/dkms/ethercat-dkms/1.6.9/build/devices/stmmac] Error 2
make[3]: *** [/usr/src/linux-headers-6.12.86+deb13-common-rt/scripts/Makefile.build:471: /var/lib/dkms/ethercat-dkms/1.6.9/build/devices] Error 2
make[2]: *** [/usr/src/linux-headers-6.12.86+deb13-common-rt/Makefile:1981: /var/lib/dkms/ethercat-dkms/1.6.9/build] Error 2
make[1]: *** [/usr/src/linux-headers-6.12.86+deb13-common-rt/Makefile:236: __sub-make] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-6.12.86+deb13-rt-amd64'
make: *** [Makefile:963: modules] Error 2
# exit code: 2
# elapsed time: 00:03:42
- Thank you received: 4153
And follow this process which I have tested with 2.98 in the last week or so.
github.com/linuxcnc-ethercat/apt
This is going to become the official repository and Ethercat version to use for linuxcnc
- GFC
- Thank you received: 6
Failed command:
./configure --enable-sii-assign --disable-rt-syslog --disable-tool --disable-userlib --enable-generic --enable-ccat --disable-tty --with-linux-dir=/lib/modules/6.12.86+deb13-rt-amd64/build --enable-e1000 --enable-igb --disable-igbvf --disable-ixgbevf --enable-igc --enable-e1000e --enable-8139too --enable-e100 --enable-r8169 --disable-stmmac-pci --enable-dwmac-intel --disable-genet && make modules
Error! Bad return status for module build on kernel: 6.12.86+deb13-rt-amd64 (x86_64)
Consult /var/lib/dkms/ethercat-dkms/1.6.9/build/make.log for more information.
dpkg: error processing package ethercat-dkms (--configure):
installed ethercat-dkms package post-installation script subprocess returned error exit status 10
Setting up libltdl-dev:amd64 (2.5.4-4) ...
dpkg: dependency problems prevent configuration of ethercat-master:
ethercat-master depends on ethercat-dkms; however:
Package ethercat-dkms is not configured yet.
dpkg: error processing package ethercat-master (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linuxcnc-ethercat:
linuxcnc-ethercat depends on etherlabmaster | ethercat-master; however:
Package etherlabmaster is not installed.
Package ethercat-master is not configured yet.
dpkg: error processing package linuxcnc-ethercat (--configure):
Processing triggers for man-db (2.13.1-1) ...
Processing triggers for libc-bin (2.41-12+deb13u3) ...
Errors were encountered while processing:
ethercat-dkms
ethercat-master
linuxcnc-ethercat
E: Sub-process /usr/bin/dpkg returned an error code (1)
- awallin
Thanks, this repo works for me on 2.9.8 (the default is in the file /etc/apt/sources.list.d/science_EtherLab.list and gives errors)And follow this process which I have tested with 2.98 in the last week or so.
- GFC
There was some talk of publishing a new 2.9.x version to fix some bugs. If that is the case, I will send in a PR to update the repos in the installer based on the link above.
