Ethercat installation from repositories - how to step by step
11 months 1 week ago - 11 months 1 week ago #338756 by Hakan
Try
apt depends ethercat-dkms apt policy libtool
For me is says it can find libtool at
 *** 2.5.4-4 500
        500 deb.debian.org/debian trixie/main amd64 Packages
But I'm on trixie so not identical.
Last edit: 11 months 1 week ago by Hakan.
11 months 1 week ago #338759 by tommylight
Did you do
sudo apt update
before
sudo apt install build-essential
11 months 1 week ago #338762 by kor
apt depends ethercat-dkms ethercat-dkms   Hängt ab von: dkms (>= 2.1.0.0)   Hängt ab von: <libtool>   Hängt ab von: <autoconf>   Hängt ab von: <autoconf-archive>   Hängt ab von: <automake>   Hängt ab von: pkg-config     pkgconf bf20@BF20:~$ apt policy libtool libtool:   Installiert:           (keine)   Installationskandidat: (keine)   Versionstabelle:
hängt ab von means depends on
keine means none
unfortunatly i did do the sudo apt update already that would be to easy :)
just tried again and tried the build essentials afterwards it tells me it is already the newest version 12.9
should I do a reinstall with the english language? It seems od to me that this would depend on the language.
11 months 1 week ago #338763 by Hakan
Is /etc/apt/sources.list broken?
11 months 1 week ago - 11 months 1 week ago #338780 by kor
how do i test this? (and fix if broken)
Last edit: 11 months 1 week ago by kor.
11 months 1 week ago #338781 by Hakan
Show the content here it's not many lines.
Time to create page: 0.160 seconds
