Ethercat installation from repositories - how to step by step
22 Apr 2025 13:13 #326886 by Moutomation
The problem was related to the Ethernet settings. It was solved.
23 Apr 2025 03:17 - 23 Apr 2025 03:19 #326930 by Soccer Kid
Personally, I think compiling through source code will have a much better effect. Usually, different environments lead to very poor compilation results...
Last edit: 23 Apr 2025 03:19 by Soccer Kid.
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
23 Apr 2025 05:08 #326931 by rodw
Looks like the path in your ini file  to your Ethercat xml file is wrong
21 May 2025 14:53 - 21 May 2025 14:53 #328860 by kjlty
How to install the latest linuxcnc-ethercat on Debian 10 (lcnc2.94)?
Last edit: 21 May 2025 14:53 by kjlty.
  • rodw
  • Platinum Member
  • Platinum Member
24 May 2025 09:51 #329034 by rodw
Upgrade to Debian 12
The following user(s) said Thank You: pklopping
25 Jul 2025 21:59 #332332 by Tntmold
Is there a repository that currently is complete and works? I have been trying to get an installation working since March with no luck at all. I continually get errors about various components (LCEC, Boost, meson, etc) I have been able to get an "install" using the repository on this thread but it seems to lack full connection to the before mentioned components
28 Jul 2025 14:20 #332474 by horcsab
Dear All,
Does anyone have information that the KINCO FD425-EF-000 drive works with linuxcnc? On Ethercat?
Is there an xml file provided by the manufacturer, can I use that?
I haven't connected an Ethercat device to the machine under Linuxcnc yet.
Regards
17 Nov 2025 21:27 - 17 Nov 2025 21:28 #338578 by kor
I tried to install the linux-ethercat package
but I get the error that they are dependent on other packages: libtool, autoconf, autoconf-archive and automake. which can not be installed.
I do have a freshly installed linuxcnc 2.9.4 preempt-rt installed from the iso image.
Last edit: 17 Nov 2025 21:28 by kor.
  • rodw
  • Platinum Member
  • Platinum Member
18 Nov 2025 09:38 #338607 by rodw
try
sudo apt install build-essential
and try again
18 Nov 2025 15:48 - 19 Nov 2025 19:19 #338627 by kor
after
unfortunatly I receive the same error mesage:
Die folgenden Pakete haben unerfüllte Abhängigkeiten: ethercat-dkms : Hängt ab von: libtool ist aber nicht installierbar Hängt ab von: autoconf ist aber nicht installierbar Hängt ab von: autoconf-archive ist aber nicht installierbar Hängt ab von: automake ist aber nicht installierbar E: Probleme können nicht korrigiert werden, Sie haben zurückgehaltene defekte Pakete.
unfortunatly in german but basically libtool autoconf, ... can not be installed
I tried to install libtool individually: and I get the error message:
For the paket libtool there is no install candidate.
(my translation)
Last edit: 19 Nov 2025 19:19 by kor.
Time to create page: 0.431 seconds
