Ethercat installation from repositories - how to step by step
1 year 3 months ago #332474 by horcsab
Dear All,
Does anyone have information that the KINCO FD425-EF-000 drive works with linuxcnc? On Ethercat?
Is there an xml file provided by the manufacturer, can I use that?
I haven't connected an Ethercat device to the machine under Linuxcnc yet.
Regards
11 months 2 weeks ago - 11 months 2 weeks ago #338578 by kor
I tried to install the linux-ethercat package
but I get the error that they are dependent on other packages: libtool, autoconf, autoconf-archive and automake. which can not be installed.
I do have a freshly installed linuxcnc 2.9.4 preempt-rt installed from the iso image.
Last edit: 11 months 2 weeks ago by kor.
11 months 2 weeks ago #338607 by rodw
try
sudo apt install build-essential and try again
11 months 1 week ago - 11 months 1 week ago #338627 by kor
after
unfortunatly I receive the same error mesage:
Die folgenden Pakete haben unerfüllte Abhängigkeiten: ethercat-dkms : Hängt ab von: libtool ist aber nicht installierbar Hängt ab von: autoconf ist aber nicht installierbar Hängt ab von: autoconf-archive ist aber nicht installierbar Hängt ab von: automake ist aber nicht installierbar E: Probleme können nicht korrigiert werden, Sie haben zurückgehaltene defekte Pakete.
unfortunatly in german but basically libtool autoconf, ... can not be installed
I tried to install libtool individually: and I get the error message:
For the paket libtool there is no install candidate.
(my translation)
Last edit: 11 months 1 week ago by kor.
11 months 1 week ago - 11 months 1 week ago #338747 by kor
after
(my translation)
Is there any more information I can provide to narrow down the problem?
11 months 1 week ago #338749 by rodw
Strange. all packages are available in the Debian repositories (libtool,autoconf,autoconf-archive,automake)  packages.debian.org/search?suite=default...mes&keywords=libtool
Even stranger because iGh the ethercat master developer is a German company.. I wonder if its a language/locale issue? I can't help
Time to create page: 4.273 seconds
