  • ihavenofish
  • ihavenofish
29 Jun 2024 16:15
Replied by ihavenofish on topic VFD setup help
VFD setup help
Category: Milling Machines
Yes. But apparently setting a 220v 1000hz motor to 135v and 600hz on this drive is not the same as just moving down the VF curve on a 1000hz drive. The engineer was confused as much as me. It should "just work" but it doesn't.
And of course as I found out, faster drives are not easy to get so I'm stuck with this compromise we found for now.
  • JT
  • JT's Avatar
29 Jun 2024 15:53
Replied by JT on topic Debian 12 RTAI
Debian 12 RTAI
Category: Installing LinuxCNC
If I try and run the sim again I get:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-5.4.258-rtai-amd64/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.2
Machine configuration directory is '/home/john/linuxcnc/configs/my-mill'
Machine configuration file is 'my-mill.ini'
INIFILE=/home/john/linuxcnc/configs/my-mill/my-mill.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./my-mill.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: axis
task: 34 cycles, min=0.000005, max=0.011682, avg=0.005748, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Debug file information:
/usr/bin/linuxcnc: line 977:  2934 Segmentation fault      $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
2862
2931
Stopping realtime threads
Unloading hal components
Kernel message information:
[  270.856729] I-pipe: head domain RTAI registered.
[  270.856730] RTAI[hal]: mounted. ISOL_CPUS_MASK: 0.
[  270.856732] SYSINFO - # CPUs: 4, TIMER NAME: 'lapic-deadline', TIMER IRQ: 4355, TIMER FREQ: 474987506, CLOCK NAME: 'tsc', CLOCK FREQ: 3791999000, CPU FREQ: 3791999000, LINUX TIMER IRQ: 4355.
[  270.859936] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[  270.859960] kstacks pool size = 524288 bytes
[  270.859960] RTAI[sched]: hard timer type/freq = lapic-deadline/474987506(Hz)
[  270.859961] linear timed lists.
[  270.859961] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3791999000 hz.
[  270.859962] RTAI[sched]: timer setup = 82 ns, resched latency = 0 ns.
[  270.860778] USERMODE CHECK: OK.
[  270.860778] USERMODE CHECK PROVIDED (ns): KernelLatency 809, UserLatency 1094.
[  270.860779] FINAL CALIBRATION SUMMARY (ns): KernelLatency 809, UserLatency 1094.
[  270.867139] RTAI[math]: loaded integrated musl libm version 1.2.3.
[  271.150629] axis[2934]: segfault at 0 ip 00007fbaa6352083 sp 00007ffdc8eb94c0 error 6 in libtcl8.6.so[7fbaa62ad000+143000]
[  271.150634] Code: 8b 5c 24 20 e9 ae fe ff ff 66 0f 1f 44 00 00 48 8b 45 00 0f b6 4a 01 49 83 c6 08 48 83 c2 02 48 8b 40 70 48 8b 04 c8 49 89 06 <83> 00 01 0f b6 02 e9 2e ff ff ff 66 90 49 8b 8c 24 a8 00 00 00 48
[  273.622344] RTAI[math]: unloaded.
[  273.684923] SCHED releases registered named ALIEN PEDV$D
[  273.697002] RTAI[malloc]: unloaded.
[  273.804895] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  273.822479] I-pipe: head domain RTAI unregistered.
[  273.822482] RTAI[hal]: unmounted.
JT
  • JT
  • JT's Avatar
29 Jun 2024 15:51
Debian 12 RTAI
Interesting a Stepconf sim started up and ran then Firefox crashed then the sim crashed with this:
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.2
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z
libnml/buffer/shmem.cc 507: SHMEM: Can't take semaphore
* Current Directory = /home/john/linuxcnc/configs/my-mill
* BufferName = toolSts
* BufferType = 0
* ProcessName = emc
* Configuration File = /usr/share/linuxcnc/linuxcnc.nml
* CMS Status = -1 (CMS_MISC_ERROR:   A miscellaneous  error occurred.)
* Recent errors repeated:
* BufferLine: B toolSts               SHMEM   localhost       1024    0       0       5       16 1005 TCP=5005 xdr
* ProcessLine: P emc           toolSts         LOCAL   localhost       R       0       1.0     0       0
* error_type = 5 (NML_INTERNAL_CMS_ERROR)
task: 4249 cycles, min=0.000005, max=0.077609, avg=0.010031, 0 latency excursions (> 10x expected cycle time of 0.010000s)
link (updating variable file): No such file or directory
note: MAXV     max: 1.000 units/sec 60.000 units/min
note: LJOG     max: 1.000 units/sec 60.000 units/min
note: LJOG default: 0.100 units/sec 6.000 units/min
note: jog_order='XYZ'
note: jog_invert=set()
/usr/bin/linuxcnc: line 977:  1788 Segmentation fault      $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
1715
Inconsistency detected by ld.so: rtld.c: 1656: dl_main: Assertion `main_map != NULL' failed!
1784
[   88.945183] I-pipe: head domain RTAI registered.
[   88.945184] RTAI[hal]: mounted. ISOL_CPUS_MASK: 0.
[   88.945185] SYSINFO - # CPUs: 4, TIMER NAME: 'lapic-deadline', TIMER IRQ: 4355, TIMER FREQ: 474987506, CLOCK NAME: 'tsc', CLOCK FREQ: 3791999000, CPU FREQ: 3791999000, LINUX TIMER IRQ: 4355.
[   88.949322] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[   88.949347] kstacks pool size = 524288 bytes
[   88.949347] RTAI[sched]: hard timer type/freq = lapic-deadline/474987506(Hz)
[   88.949348] linear timed lists.
[   88.949348] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3791999000 hz.
[   88.949349] RTAI[sched]: timer setup = 82 ns, resched latency = 0 ns.
[   88.950696] USERMODE CHECK: OK.
[   88.950697] USERMODE CHECK PROVIDED (ns): KernelLatency 809, UserLatency 1094.
[   88.950698] FINAL CALIBRATION SUMMARY (ns): KernelLatency 809, UserLatency 1094.
[   88.966552] RTAI[math]: loaded integrated musl libm version 1.2.3.
[   89.079357] traps: hal_manualtoolc[1775] general protection fault ip:51710d sp:7ffc0ba72b10 error:0 in python3.11[41f000+2b3000]
[   98.833243] [pango] FcInit[1819]: segfault at 10 ip 00007f14d476e579 sp 00007f14d188bb90 error 4 in libc.so.6[7f14d46fd000+155000]
[   98.833247] Code: 8b 4e 08 49 39 c8 0f 82 7d 03 00 00 48 83 f9 0f 0f 86 73 03 00 00 4c 8b 06 49 83 e0 f8 49 39 c0 0f 85 db 05 00 00 4c 8b 42 18 <49> 3b 50 10 0f 85 fd 04 00 00 4c 39 7a 10 0f 85 f3 04 00 00 f6 c1
[  131.785856] axis[1788]: segfault at 14 ip 00007f0b06c91a50 sp 00007fffbfc57fe0 error 4 in libtcl8.6.so[7f0b06bd8000+143000]
[  131.785862] Code: 66 2e 0f 1f 84 00 00 00 00 00 4d 85 f6 74 b0 41 c7 06 00 00 00 00 eb a7 66 90 48 85 db 0f 84 38 ff ff ff 0f 1f 80 00 00 00 00 <44> 39 6b 10 75 06 4c 39 7b 20 74 d4 48 8b 1b 48 85 db 75 ec e9 18
[  134.163588] RTAI[math]: unloaded.
[  134.226200] SCHED releases registered named ALIEN PEDV$D
[  134.228332] RTAI[malloc]: unloaded.
[  134.338161] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  134.355825] I-pipe: head domain RTAI unregistered.
[  134.355829] RTAI[hal]: unmounted.
JT
  • JT
  • JT's Avatar
29 Jun 2024 15:46
Debian 12 RTAI
Hmm, I think the startup scrip does some magic but it freezes on me and does not print anything to the terminal.
29 Jun 2024 15:40
Replied by Cant do this anymore bye all on topic Debian 12 RTAI
Debian 12 RTAI
Ran modinfo and it seems it has dependencies
sudo modinfo /usr/realtime-5.4.258-rtai-amd64/modules/linuxcnc/motmod.ko
[sudo] password for rmurphy:
filename:       /usr/realtime-5.4.258-rtai-amd64/modules/linuxcnc/motmod.ko
license:        GPL
description:    Motion Controller for EMC
author:         Matt Shaver/John Kasunich
depends:        homecomp,tpmod,hal_lib,millturn,rtapi,rtai_math
vermagic:       5.4.258-rtai-amd64 SMP mod_unload
parm:           key:shared memory key (int)
parm:           base_period_nsec:fastest thread period (nsecs) (long)
parm:           base_thread_fp:floating point in base thread? (int)
parm:           servo_period_nsec:servo thread period (nsecs) (long)
parm:           traj_period_nsec:trajectory planner period (nsecs) (long)
parm:           num_spindles:number of spindles (int)
parm:           num_joints:number of joints used in kinematics (int)
parm:           num_extrajoints:number of extra joints (not used in kinematics) (int)
parm:           num_dio:number of digital inputs/outputs (int)
parm:           names_din:names of digital inputs (array of charp)
parm:           names_dout:names of digital outputs (array of charp)
parm:           num_aio:number of analog inputs/outputs (int)
parm:           names_ain:names of analog inputs (array of charp)
parm:           names_aout:names of analog outputs (array of charp)
parm:           num_misc_error:number of misc error inputs (int)
parm:           names_misc_errors:names of errors (array of charp)
parm:           unlock_joints_mask:mask to select joints for unlock pins (int)
There's a whole lot of modules that need loading before motmod
  • PCW
  • PCW's Avatar
29 Jun 2024 15:14
Replied by PCW on topic VFD setup help
VFD setup help
AC induction motor voltage is speed dependent in the same way as DC motors.
They are more complex because of things like field weakening in the the armature,
but the basic behaviour is the same.
That is if you took a 240V 60 Hz AC induction motor and ran it at 1/2 speed at 30 Hz
you would need to reduce the voltage to approximately 120 V to avoid overcurrent/saturation
29 Jun 2024 15:04
Replied by Cant do this anymore bye all on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Ok went back to my Lattice dev board, and connected up via SPI, qt test works, LCNC does not. get header message error. Could be my wiring.
Once I finally worked out the pin changes in my sources, from about 12 months or so the UDP bridge works fine, well at least with qt test.
It's 1am, Marc crashed out of the Sprint at Assen (grumble grumble grumble), I'll attack it when the sun is up.
This is beginning to seem like an ID 10 T issue and it's all my fault.
  • JT
  • JT's Avatar
29 Jun 2024 14:12
Debian 12 RTAI
One thing I noticed is Linuxcnc and RTAI versions don't match on the downloads page.
Dunno if that is an issue or not.
JT
  • JT
  • JT's Avatar
29 Jun 2024 14:09
Debian 12 RTAI
Rebooting and just running halrun from a terminal I get an error with motmod:
john@rtai:~$ halrun
halcmd: loadrt trivkins coordinates=XYZ
halcmd: loadrt motmod base_period_nsec=100000 servo_period_nsec=1000000 num_joints=3
insmod: ERROR: could not insert module /usr/realtime-5.4.258-rtai-amd64/modules/linuxcnc/motmod.ko: Unknown symbol in module
<stdin>:2: exit value: 1
<stdin>:2: insmod for motmod failed, returned -1
See the output of 'dmesg' for more information.
halcmd:
JT
  • JT
  • JT's Avatar
29 Jun 2024 14:03
Debian 12 RTAI
This is what I get:
john@rtai:/usr/realtime-5.4.258-rtai-amd64/testsuite$ halrun -U
ERROR:  Can't remove RTAI modules, kill the following process(es) first
                     USER        PID ACCESS COMMAND
/dev/rtai_shm:       john       1106 ....m halcmd
JT
29 Jun 2024 13:50
Replied by tommylight on topic Debian 12 RTAI
Debian 12 RTAI
Try
halrun -U
then try to run the included parallel port configuration
mind the upper case U
  • PCW
  • PCW's Avatar
29 Jun 2024 13:32
Error: Unexpected realtime delay on task 0 + Watchdog has bit!
36 s32  RW  3890184        hm2_7i90.0.write.tmax
Means the SPI write to the FPGA took almost 4 ms.
As I mentioned before, this likely means that the
Orange PI's kernel SPI driver is not capable of
real time operation.
  • JT
  • JT's Avatar
29 Jun 2024 11:50
Debian 12 RTAI was created by JT
Debian 12 RTAI
I installed a generic Debian 12 then installed
www.linuxcnc.org/dists/bookworm/2.9-rt/b...xcnc_2.9.2_amd64.deb
www.linuxcnc.org/dists/bookworm/base/bin...ai-amd64-2_amd64.deb
www.linuxcnc.org/dists/bookworm/base/bin...xcnc-delta_amd64.deb
When I try and run LinuxCNC the config picker just freezes up. Latency is crazy good...
When I try and run the testsuite I get
john@rtai:/usr/realtime-5.4.258-rtai-amd64/testsuite$ pwd
john@rtai:/usr/realtime-5.4.258-rtai-amd64/testsuite$ sudo /usr/realtime-5.4.258-rtai-amd64/testsuite/display
[sudo] password for john:
CANNOT FIND MAILBOX
john@rtai:/usr/realtime-5.4.258-rtai-amd64/testsuite$ sudo /usr/realtime-5.4.258-rtai-amd64/testsuite/latency
CANNOT CREATE MAILBOX
john@rtai:/usr/realtime-5.4.258-rtai-amd64/testsuite$ sudo /usr/realtime-5.4.258-rtai-amd64/testsuite/run
.runinfo is /usr/realtime-5.4.258-rtai-amd64/testsuite/.runinfo
RTAI loaded.
Unloading modules...
Running rmmod on /usr/realtime-5.4.258-rtai-amd64/testsuite/.runinfo...
rmmod: ERROR: Module rtai_msg is not currently loaded
rmmod: ERROR: Module rtai_mbx is not currently loaded
rmmod: ERROR: Module rtai_sched is in use by: rtapi
rmmod: ERROR: Module rtai_hal is in use by: rtapi rtai_sched
All RTAI modules unloaded.
Running insmod on /usr/realtime-5.4.258-rtai-amd64/testsuite/.runinfo...
insmod: ERROR: could not insert module /usr/realtime-5.4.258-rtai-amd64/modules/rtai_hal.ko: File exists
Error inserting rtai_hal.ko
CANNOT FIND MAILBOX
Cleaning up...
Error removing rtai_msg.ko
Anyone have an idea what I missed?
JT
  • Hossein74Majidi
  • Hossein74Majidi
29 Jun 2024 11:15
Hey guys
I still have problem. With lots of searching and trying out and talking with some of friends, I think it might be the SPI that have the realtime issue not the os kernel. Please help me to get through this.
I'm still getting these 2 errors:
"Unexpected realtime delay on task 0 with period 1000000. This message will only display once per session. Run the latency test and resolve before continuing."
"hm2/hm2_7i90.0: Watchdog has bit! (set the .has-bit pin to false to resume)"
The watchdog error doesnt show up in a regular timing. but  in every session it will definitely happen.
  • BHar
  • BHar
29 Jun 2024 11:11
Replied by BHar on topic VFD setup help
VFD setup help
Well, I better bow out, you sound quite sure that your motor speed is voltage-dependent not hz/poles like an AC induction motor.
Might be worth throwing some info on the motor up here - surely someone in the linuxcnc community has used a similar unit.
Displaying 25591 - 25605 out of 25742 results.
Time to create page: 0.641 seconds
