  • Satai
  • Satai
26 Apr 2024 18:49
Replied by Satai on topic Z-Axis no Ref configurable
Category: StepConf Wizard
No reaction. Gmoccapy assumes that the spindle is running but nothing...
  • COlger81
  • COlger81's Avatar
26 Apr 2024 18:30
Ethernet - Realtek vs Intel was created by COlger81
I have an onboard realtek and an intel pcie ethernet adapter. Which is best for stability with the Mesa ethernet control?
Onboard is realtek "rtl18168h-2"
PCIE is intel         "82573"
26 Apr 2024 17:49
Mesa cards or parallel port? And where to learn about Mesa
If you want to make a control panel with many buttons, I recommend a combination:
7i96s + cable DB25M-IDC26 + 7i74 + up to 9x 7i84
That or 7i96S + DB25-IDC26 + 7i85 + up to 5X 7i84 (4x on 7i85 and 1 on 7i96S)
Of course, instead of 7i84, there are 7i70, 7i71, 7i72, 7i73 that can be used.
26 Apr 2024 17:45
Replied by tommylight on topic PNCconf 7i92H and 7i76
Category: PnCConf Wizard
As MythBusters would say: well. there's your problem! :)
83 C is to much, although some go as high as 109C without issues, but some will start throttling at 63C, all this is from experience and i still have those PC's around.
So, this for sure warrants opening the PC, yanking out the CPU cooler, clean, repaste with thermal paste, mount the cooler back. Also a bit of dusting with high pressure air or using a brush might prove worthy.
26 Apr 2024 17:40
Can not get stepper motors to move with Gecko g250x drivers
No, not yet, i am just to damn busy, sorry for that.
I still think there is something not right with the wiring and all the jumps through the cabling, so if you are willing to investigate further, use a DVM set to measure resistance and check:
-if the G250 has the same gnd for step/dir and power
-if the signal gnd is the same with Mesa signal gnd
pretty sure the last one will not be 0 ohm, but do check that and report back, powered off when measuring.
If it does end up not being 0 ohm, use a 10-100 ohm resistor between the G250 gnd and Mesa signal gnd, then power on and test.
  • zz912
  • zz912's Avatar
26 Apr 2024 17:31
You wrote that you were considering a tool changer. Calculate how many inputs and outputs you will need. If you miss them, consider a combination:
7i96s + 7i84
Of course, you can start only with the 7i96s itself and buy other cards afterwards.
There is also the question of whether the closed loop motors you are using have an encoder output and whether you want to introduce it into the LCNC.
  • Aciera
  • Aciera's Avatar
26 Apr 2024 17:20
Replied by Aciera on topic Failed to find entry point
[qtpyvcp.app.launcher][ERROR] Could not load /home/mavijet/argecnc, make sure that the name or file path is correct. (launcher.py:134)
Seems that you are trying to load something that does not exist.
  • MennilTossFlykune
  • MennilTossFlykune
26 Apr 2024 17:03
Replied by MennilTossFlykune on topic Flexible GUI
Flexible GUI
Category: Other User Interfaces
  • KlausB
  • KlausB
26 Apr 2024 16:33
Replied by KlausB on topic z_level_compensation
Category: Qtvcp
You are great - Thanks a lot.
I don't get the error any more.
The calculated offset is shown in the GUI (QtDragon_hd), depending on the position of the spindel.
But there mus be a nother mistake in my HAL file perhaps, because the offset has no affect to my Z-axis yet.
There is a indicator "EOFFSET LTD" should it be enabled?
I made two Screenshots, perhaps you have an idea whats wrong in my config.
File Name: Z-Compensation.hal
File Size:2 KB
  • stonebite
  • stonebite
26 Apr 2024 16:24
Replied by stonebite on topic PNCconf 7i92H and 7i76
About 30 seconds after LinuxCNC starts, the temps rise and the fan starts running hard. Since the temperatures go well over 60°C, I wonder whether the processor has protective functions at these temperatures and does not allow OpenGL to function at all? The question is because yesterday while researching in a video about the current ASUS PN50 I saw that the construction of the heat sink from the processor to the cooling unit is supposed to be a defect? The video shows that heat transfer cannot take place because the surfaces do not have optimal contact. What does this theory look like?
  • moretoyswins
  • moretoyswins
26 Apr 2024 15:02
I guess I have lost everyone's interest or at least exhausted their list of suggestions.  I want to thank Tommylight and PCW for their help!  While the issue remains unresolved, they both helped me move forward in my understanding of LinuxCNC.
I have not given up on the Gecko G250X, but I must get this controller working ASAP.  As such, I have ordered DM556T stepper drives, which others seem to have working with LinuxCNC and Mesa boards.  Unfortunately, it will take a few days to get them.
I hope the DM556T will be more plug-and-play than the G250Xs seem to be.  Of course, this means I have to rearrange and rewire half of the control box.  Maybe I will get it right this time!  I still need to figure out outputs as they seem to be NC when I thought they would be NO.
26 Apr 2024 14:44
Replied by Cant do this anymore bye all on topic Curious about Raspberry Pi 4B SPI speed
Category: Installing LinuxCNC
The config is more to do with allocating the FPGA resources.
There’s actually 2 drivers involved, the hostmot2 driver which handles the “heavy lifting” and the hm2_xxxx driver which handles the physical communication.
With regards to the SPI speed just pick a speed that is reliable. There’s no need to get hung up on it.
It’s amazing what one learns when the docs are read. It’s also useful to read the manual for the card you are using as well.
  • PCW
  • PCW's Avatar
26 Apr 2024 14:21
Replied by PCW on topic TB6600 and STEP_SCALE with Mesa7i96s
Are you really using full steps (Microsteps=1)?
That would typically be quite rough and
susceptible to resonance.
  • rdtsc
  • rdtsc's Avatar
26 Apr 2024 14:06
Replied by rdtsc on topic Curious about Raspberry Pi 4B SPI speed
Interesting, was unaware that drivers could be "shimmed" on-the-fly this way.
Ok so it looks like, to experiment with LinuxCNC SPI speed on Rpi4, something like this could be done to the .hal file:
loadrt hm2_rpspi config="num_encoders=0 num_pwmgens=0 num_stepgens=3" spiclk_rate=31250 spiclk_rate_rd=12500
Where the speeds are out of:
- 62500 - 62.500 MHz
- 41667 - 41.667 MHz
- 31250 - 31.250 MHz
- 25000 - 25.000 MHz
- 20834 - 20.833 MHz
- 17858 - 17.857 MHz
- 15625 - 15.625 MHz
- 13889 - 13.889 MHz
- 12500 - 12.500 MHz
- 11364 - 11.364 MHz
- 10417 - 10.417 MHz
- 9616 - 9.615 MHz
  • stonebite
  • stonebite
26 Apr 2024 13:47 - 26 Apr 2024 14:24
Yes, if I can avoid it, I don't want to have to buy a new PC straight away. Of course I'm happy, although I can still hope for the great support ;o) Now the temperatures follow. To do this, I opened and closed the LinuxCNC several times, 4 times slowly in a row. The error messages always remain the same
cnc@cnc:~$ sensors
k10temp-pci-00c3
Adapter: PCI adapter
Tctl:         +56.8°C
nvme-pci-0400
Composite:    +46.9°C  (low  =  -5.2°C, high = +79.8°C)
                       (crit = +84.8°C)
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1:        +53.0°C
amdgpu-pci-0500
vddgfx:        1.33 V
vddnb:       681.00 mV
edge:         +53.0°C
PPT:           8.00 W
cnc@cnc:~$ sensors
k10temp-pci-00c3
Tctl:         +83.2°C
nvme-pci-0400
Composite:    +47.9°C  (low  =  -5.2°C, high = +79.8°C)
                       (crit = +84.8°C)
iwlwifi_1-virtual-0
temp1:        +56.0°C
amdgpu-pci-0500
vddgfx:        1.26 V
vddnb:       774.00 mV
edge:         +74.0°C
PPT:          16.00 W
cnc@cnc:~$ sensors
k10temp-pci-00c3
Tctl:         +78.2°C
nvme-pci-0400
                       (crit = +84.8°C)
iwlwifi_1-virtual-0
temp1:        +56.0°C
amdgpu-pci-0500
vddgfx:        1.22 V
vddnb:       774.00 mV
edge:         +70.0°C
PPT:          15.00 W
cnc@cnc:~$
Displaying 26476 - 26490 out of 26693 results.
Time to create page: 0.653 seconds
