  • axemas
  • axemas's Avatar
20 Apr 2026 19:46
NativeCAM 2.0b — Python 3 & GTK3 port for LinuxCNC 2.9 / Debian 13 Trixie
Category: NativeCAM
"Hi everyone,
Thank you all for testing the port and providing feedback! I've just pushed a few fixes to the repository (including the INI parsing errors and GTK deprecation warnings). github.com/cnc-proton/nativecam-py3-gtk3...vecam_2.0b-4_all.deb
Regarding Bug Reports:
As more people start using this port, it becomes harder to track individual errors and logs across forum pages. If you encounter a bug, a crash, or a specific error message, please report it via GitHub Issues here: github.com/cnc-proton/nativecam-py3-gtk3/issues
The forum is still the perfect place for general discussions, sharing ideas (like the Lathe Polyline!), and showing off your work. But keeping the technical bug reports on GitHub allows me to solve them much faster and keep the project organized.
Thanks for understanding and for your continued support!"
  • jetbadger
  • jetbadger
20 Apr 2026 19:25
Replied by jetbadger on topic Lathe C axis homing
Lathe C axis homing
I've tried that too. Now I've noticed that I have pid.c.feedback-deriv connected. Maybe getting rid of it will help, Guess I'll try that next.
  • Konstantin
  • Konstantin
20 Apr 2026 19:06 - 20 Apr 2026 19:06
Replied by Konstantin on topic CiA 402 Folder Missing
Category: EtherCAT
Hello andrax,
I tried to follow your guide but still getting .hal file error for missing pins.
I ran LinuxCNC from terminal and it outputs that the HomeComp started.
Then the terminal reports that pins "joint.0.request-cia-homing" and "start-cia-homing" are not found.
  • Surmetall
  • Surmetall's Avatar
20 Apr 2026 18:36
Replied by Surmetall on topic LinuxCNC and Beckhoff AX5000 servo drives
Category: EtherCAT
HEllo Endian,
thank you for the link i tried my best to fix it myself (and later with help of AI...) i hope i understood most of the problems.
I am trying to get a Beckhoff AX5125-0000-0216 running.
Current situation:
- LinuxCNC 2.9.8
- IgH EtherCAT master 1.6.8
- all other slaves on the real machine bus go OP
- only the AX5125 stays in PREOP / PREOP+ERROR
I also tested AX-only (only the AX connected to the LinuxCNC EtherCAT port, no other slaves) and it still does not go beyond PREOP. So it does not look like bus order / other slaves are the root cause.
It runs perfekt in TC3 also after  change from 2ms to 1ms i could jog it by hand.
What I already verified:
- TwinCAT project was switched to 1 ms
- exported again from TwinCAT
- converter run with c -i
- appTimePeriod = 1000000
- IDN 1 = e803
- IDN 2 = e803
- generated assignActivate 740 was changed to 730
Observed errors during the different attempts:
- AL status 0x0045: MBX_SOE
- AL status 0x001D: Invalid output configuration
- Writing IDN 0x80CC failed
- SoE configuration failed
- sometimes PDO entry 0x0024:00 is not mapped
- in AX-only test it still remains PREOP
Current result with LinuxCNC running:
- all non-AX slaves = OP
- AX5125 = PREOP E
I am attaching:
1. current ethercat-conf.xml
2. current initCmds/Antrieb-1-AX5-0-initCmds.xml
3. TwinCAT 1 ms export XML
4. ethercat slaves output
5. ethercat pdos -p 7 output
6. relevant dmesg output
Question:
Do you see an obvious issue in the AX SoE startup / telegram / DC setup, and what would be the correct minimal working config for AX5125-0000-0216 with lcec?
Thank you very very much for your time and help!
All the best
Tom
  • PCW
  • PCW's Avatar
20 Apr 2026 18:30
Replied by PCW on topic Lathe C axis homing
Lathe C axis homing
With open loop, (stepgen feedback) you need to have a _much_ higher P term
(typically 1000 with a 1 ms servo thread period)
  • jetbadger
  • jetbadger
20 Apr 2026 18:13
Lathe C axis homing
Yeah, the title is a bit misleading at this point, but not sure it's worth making another thread for this.
I see what you mean but I've tried vastly different acc/vel values on the joint and stepgen sections and it still has the same kind of behaviour.
If it was a physical issue that should be ruled out when using stepgen.position-fb instead of encoder feedback, I'm thinking so? But that makes no difference still...
I tried to figure out how the joint comes up with the position command but with no luck either.
  • andrax
  • andrax's Avatar
20 Apr 2026 17:18
Replied by andrax on topic Tuning Steperonline A6 Servos
Category: EtherCAT
Thanks for the help,
I'll go through this step by step and get back to you
  • Mikel
  • Mikel
20 Apr 2026 17:00
Tree J425 , J325 Retrofit was created by Mikel
Category: Show Your Stuff
This retrofit is possibly the easiest retrofit of all mills. I used a 7I97T with the existing servo dives and VFD.Notes:1. Aside from the servos and VFD there are only five 24V miniature relays to control.2. Since the servos utilized a tach (Aka Resolver) drive tuning took minutes to tune.3. The only additional board I made was transistor board to provide a signal to the J425’s drive enable relay. The drive enable optocoupler on the 7I97T cannot provide sufficient current for this miniature relay. This board consisted of a P-Channel Mosfet and a 10Kohm pull up.4. On the J425 all of the axis limit switches and the Estop are all connected in series to a single relay.5. I was able to use all of the existing wiring. I didn’t have to cut or splice any of the existing wiring.6. Almost all of the wiring to the 7I97T was through the existing DB connectors.7. Just like any other CNC, you’ll need wiring diagrams. They are available from zpsusa.com/kneemills.html I did not have any issues with the installation or performance of the Mesa 7I97T. I was concerned on its ability to thread mill since it requires 3 axis’s synchronized. It wasn’t an issue at all, in fact I cranked it up to 120ipm without any following errors.
  • papagno-source
  • papagno-source
20 Apr 2026 16:09
Replied by papagno-source on topic Ethercat random jitter fix
Category: EtherCAT
Good evening, has anyone tried the new fixes in Grandixximo v1.41.0-pre2?
Are the slave pin values ​​read quickly?
  • CyberCraze
  • CyberCraze
20 Apr 2026 14:50
A practical G-code learning path (from beginner to industrial level)
Category: User Exchange
Yeah, that’s definitely part of it as well.
I’ve touched on 5-axis concepts too, mainly around coordinate systems, tool orientation, and how things behave behind the scenes — even if most of my hands-on work has been 3-axis and some 4-axis.
It definitely adds another layer compared to standard setups.
  • COFHAL
  • COFHAL
20 Apr 2026 14:12
Category: NativeCAM
Now all these errors appear indicating that some strings are already in the ini file:
Error modifying ini file
While reading from '<string>' [line 24]: option 'position_feedback' in section 'DISPLAY' already exists
error modifying ini file
While reading from '<string>' [line 37]: option 'program_extension' in section 'FILTER' already exists
While reading from '<string>' [line 71]: option 'halfile' in section 'HAL' already exists
While reading from '<string>' [line 94]: option 'tool_table' in section 'EMCIO' already exists
Source contains parsing errors: '<string>'
[line 291]: '= \n'
/usr/bin/ncam:346: PyGTKDeprecationWarning: The keyword(s) "type, message_format" have been deprecated in favor of "message_type, text" respectively. See: wiki.gnome.org/PyGObject/InitializerDeprecations
dlg = gtk.MessageDialog(parent = None,
/usr/bin/ncam:346: PyGTKDeprecationWarning: The "flags" argument for dialog construction is deprecated. Please use initializer keywords: modal=True and/or destroy_with_parent=True. See: wiki.gnome.org/PyGObject/InitializerDeprecations
  • papagno-source
  • papagno-source
20 Apr 2026 14:01
Replied by papagno-source on topic Simple G7x Profile editor for Linuxcnc/Axis
Category: AXIS
Good morning everyone. But does this conversational lathe software only work with Axis or does it have its own native GUI?
  • tjtr33
  • tjtr33's Avatar
20 Apr 2026 13:32
Sinker EDM machine based on diy pulse generator
Hello,
I still work on the 'sedm' project on GitHub.
But there were questions about the technology';s origin.
So i took a week (so far) to resurrect the tools I used to generate tech.
The premise is that a discharge of N amperes at Vdischarge voltage,
for T uSecs can be calculated.
It's been a challenge, as the code is Excel 4 XLM ( the pre VBA language).
It's a work in progress. I was pleased to see the inputs were Idischarge Vdischarge Tduration,
making the relationship OverBurn is proportinal to joules.
I was also pleased it listed RMS,RA,Rz and VDI surface finish values for
each discharge energy.
Is this project wanted as a Github repo?
I'll need to translate it from Excel4 with XLM
to LibreOffice(current) with Python as the macro language.
lemmeknow
Tomp tjtr33
  • cmorley
  • cmorley
20 Apr 2026 13:24
Replied by cmorley on topic Using Offsetpage Widget?
Category: GladeVCP
excellent.
  • grandixximo
  • grandixximo's Avatar
20 Apr 2026 11:48
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
You might have to do some testing, EK1100 works fine as the first DC with Beckhoff servos, but I don't know how your servos will like it, to be tested, possibly fine, but I wouldn't finalize anything before testing is done.
Displaying 2761 - 2775 out of 13996 results.
Time to create page: 0.355 seconds
