  • Dudelbert
  • Dudelbert
17 Apr 2026 18:17
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
So,
I have a great update. I got the machine working. Using the X-minus hall switch did not do the trick. Testing everything that I already thought was not the problem gave me the solution. The magnetic linear encoder in the X axis was the problem.
I did most of the testing of it at low speeds and short distances, as my indicators obviously cannot measure the length of the full axis. I can remember doing a test running the whole axis at rapid speed for multiple minutes, but I may have done this only on Z, it was two weeks ago. Or it got worse somehow, I don’t know.
In the end, using the motor encoder resolved all the problems.
I also disassembled the X axis to see how the encoder is installed. There is a very small read head in the plate behind the thrust bearing for the ballscrew and a putted scale in the underside of the X-axis slide.
I also made some pictures of the Z-axis encoder.
And then, after I spent all day getting this done, I was able to actually make op 1 on the test parts I wanted to make as test parts.
  • andrax
  • andrax's Avatar
17 Apr 2026 17:23
Sanitycheck my plan: ethercat + stepperonline A6
Category: EtherCAT
I've equipped the A6 with a battery-powered encoder cable.
No homing, no problems.
However, I would also recommend the following thread:
forum.linuxcnc.org/ethercat/58103-etherc...fix?start=160#345453
  • RotarySMP
  • RotarySMP's Avatar
17 Apr 2026 17:22
Retrofitting a 1986 Maho MH400E
Category: Milling Machines
You will need to modify the gearbox comp and recompile it. I didn't write it myself, it was written for me by a friend, so you might need to find someone to do the code changes.
  • Hakan
  • Hakan
17 Apr 2026 16:48
Replied by Hakan on topic Ethercat random jitter fix
Category: EtherCAT
Tested a bit.
I get fairly consistent loading times of lcec's rt_app_main() function of 1.85-1.90 seconds.
But but. In syslog I can see that the initial sync of slaves takes anywhere between zero and
say 3,4,5 seconds.
To check
ethercat debug 1
start linuxcnc
exit or leave running, doesn't matter.
sudo journalctl --since "2 minutes ago" | grep "Sync after"
and see where it stops for every slave.
I reckon this is the problematic delay time.
Seldom, but it happens, I get "Checking for synchrony" and then it is satisfied directly and moves on.
It seems measuring the time of lcec's rt_app_main is not a good indicator.
Is there a good way of measuring time to OP?
trixie,
Linux plasma 6.12.69+deb13-rt-amd64 #1 SMP PREEMPT_RT Debian 6.12.69-1 (2026-02-08) x86_64 GNU/Linux
IgH EtherCAT master 1.6.8 1.6.8.g2543cc5-1+27.3  (via apt)
linuxcnc-ethercat, a slightly modified version of commit bf13577ec7b1b54844e07a80d949232e71776b32
linuxcnc 2.9.4 (via apt)
  • papagno-source
  • papagno-source
17 Apr 2026 16:22 - 17 Apr 2026 16:37
Replied by papagno-source on topic Ethercat random jitter fix
Category: EtherCAT
I have installed linuxcnc-ethercat...0.9.5-retro1.5.2-rc1, without error, but if coomand ethercat version have reult 1.6.9
But I think, this is not the Igh part, but the lcec driver, right?
I have a version running in place in another directory, do I need to copy or link something to test?
On Debian 10 , in direcory bin the linuxcnc , i have only lcec_conf and not have lcec_coffingen
  • papagno-source
  • papagno-source
17 Apr 2026 15:37
Category: EtherCAT
Syste is debian 10 buster x86_64
Kernel: 4.19.0-27-rt-amd64 #1 SMP PREEEMPT RT Debian 4.19.316-1 (2024-06-25) x86_64 GNU/Linux
Ethercat : IgH ETHERCAT master 1.5.2 unknow
Etherlabmaster-1.5.2+20190904hg33b922p8ea394
LINUXCNC 2.9.0-pre0
When axis opens the gui, the axis dimensions are already present. From tests done, when I had the same problem with debian 12, as soon as it reads the loadrt lcec command, the dimensions appear on the pins in hal, relating to the individual axes.
  • motionmasterupgrade
17 Apr 2026 13:52 - 17 Apr 2026 13:59
Replied by motionmasterupgrade on topic MotionMaster Upgrade
Update on this:
(a) I have connected 220v power to the machine and have confirmed that the drives and servos all work. I will be able to use this machine in its entirely with 220v single phase input on 12HP spindle (will run it at 4hp max) and run all the drives  (8 of them, XYYZ, AA BB). These old amp drives were set up to run the DC brushed servo at max rpm if the signals (10V,tach,EN) were all OPEN - sort of insane. Thankful I had the foresight to disconnect the ballscrews from the servos. I don't have workspace - working ON the bed of the machine with the controller. See pic. Could have been a final destination sort of outcome.
(b) Hunted down faulty monitor display to a few bad connections and once those were fixed, my LCD display is actually perfectly good, this allowed me to actually test out the machine's ability to work. The linuxcnc mindhive (grumpy old dudes who have forgotted more shit than I will ever learn) helped me out immensely like with everything else. Have to look at the fagor 8055 manual to understand what to expect from triggering the limit switches but other than that, I have a big functioning CNC router. There is some weird stuff going on which I do not understand - the servos are not paired corrected, meaning, moving "controller Y" physically turns one X servo and one Y servo. A few wires need to be fixed and I need to make sure stuff turns in the right direct and get synced and what not. Maybe its a controller setting. I have no intention of using the Fagor controller and will likely not waste time on it.
(c) Mechanically, Y axis is good. Z axis is good. the X-axis is "grinding". Will remove rust with neutralized citric acid and starch to get me a chelating paste. and repack the bearings on the X axis. I hope it is not a bad ball screw. The blocks that glide on the linear rails are these things that have 2 rows of bearings that slide along the groove. I have no experience whatsoever with these. Any and all tips super appreciated.
(d) Ordered my 5in rotaries. Found this design where the 5in chuck is connected to a wormgear with 20:1 reduction. backlash (10arcs) seems acceptable. The reduction gives me holding power that will all but eliminate any issues with holding the word steady. Adding up the 2 chucks, I'll have in the region of 200Nm of torque on my work pieces. Happy about this.
(e) Gambling that it will be OK to hang 200lbs off the gantry for the swivel head + spindle. Found some implementations of this with older heavier hardware so I'll take my chances. I might have to upgrade the air balancer, or add a counter weight to the gantry. In any case, its too late. Stuff is ordered and they don't do refunds.
(f) Fun times. The entire manual for my spindle contains one single word of English. It says No! on page 19. See attached. Everything else is in Chinese that I can't read. Hopefully AI translation is decent. Same company with spindle and swivel head. Very happy to have found them. Not pushy. Don't give bullshit answers. Take pride in explaining stuff in engineering speak. Feels like a bunch of guys trying to make the best damn product they are capable of making.
Some questions that remain:
I wonder if I can reuse the dynamic brake and reactors. They are rated for the amperage that I will use with my 9kw spindle. I don't see why not, but I do not know for sure. I also don't understand from first principles what a reactor does. I think they are inductors to smooth out ripples in the outgoing current from VFD to spindle.
Grease. What should I use? I wanted to change the color of the grease so I know which lines are blocked, but someone cautioned against mixing stuff.
Ball bearings. Should I just put new ones in while I'm at it, or, do they last a lifetime? Do I caliper them? Is it even meaningful to? Surely the precision needed would be far more than my 0.02mm caliper.
July 4th. This has to make a chopstick by then.
  • PCW
  • PCW's Avatar
17 Apr 2026 13:51
Replied by PCW on topic Lathe C axis homing
Lathe C axis homing
OK I guess I got too swayed by the "homing" in the title when in fact this looks like a C axis
programmed path where the "steps" are real.
It basically looks like  the acceleration is too high to the spindle to follow. This may just be physics
(inertia vs spindle motor torque) or programming (some acceleration limit set in the drive)
  • grandixximo
  • grandixximo's Avatar
17 Apr 2026 13:47
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
@Hakan @papagno-source
I get worse OP times with 1.5.2
Is that the case for you as well?
Do you have a kernel + linuxcnc + linuxcnc-ethercat + ethercat
versions combination that gets everything ready sub 1 sec?
Before axis opens or just as axis UI opens up?
  • grandixximo
17 Apr 2026 13:36
Category: EtherCAT
gitlab.com/grandixximo/ethercat/-/jobs/1...ad?file_type=archive
Here have debs of ethercat 1.5.2 compatible with debian 13
github.com/grandixximo/linuxcnc-ethercat...0.9.5-retro1.5.2-rc1
and here a linuxcnc-ethercat compatible with the 1.5.2 retro release
you need to type in the mac address and use generic in the systemconfig/ethercat file, in my test OP is same speed, please test on your end and let me know.
linuxcnc-ehtercat retro version I only tweaked latest version based on Sascha's work, and did minimal changes to be compatible with retro 1.5.2 ethercat
  • Todd Zuercher
  • Todd Zuercher's Avatar
17 Apr 2026 13:33
Replied by Todd Zuercher on topic Using Offsetpage Widget?
Category: GladeVCP
I'm trying to revisit this again. (and still failing)
I am trying to insert the Gladevcp Offsetpage widget into a tab in the Axis user interface. The tab and Offsetpage widget are opening and seem to function (sort of), but it is showing all offsets as zero. I can use the edit button in the widget to set an offset to some value, and that offset is set to that value in Linuxcnc. The problem is that the widget will not see what current offset values are or are set to by other means in Linuxcnc.
What am I missing to make the widget read the current offset values from Linuxcnc?
  • axemas
  • axemas's Avatar
17 Apr 2026 12:54
NativeCAM 2.0b — Python 3 & GTK3 port for LinuxCNC 2.9 / Debian 13 Trixie
Category: NativeCAM
Hi everyone,I've recorded a short video demonstrating NativeCAM 2.0b (Python 3 / Gtk3) running on Debian 12/13. You can see it in action here:Video:
In this video, I demonstrate basic operations and G-code generation, showing how the new Gtk3-based interface handles the workflow.P.S. For those who want the full experience: please note that to correctly display tool orientation in the preview, some modifications to the core LinuxCNC files (
glcanon.py
and
tooledit.py
) are required. I will provide more details on these tweaks if anyone is interested.Best regards, Axemas
  • axemas
  • axemas's Avatar
17 Apr 2026 12:52
Category: NativeCAM
Hi Zbigi,
Great to hear it's working!
Regarding the "Master treeview minimal width" — yes, this is a known
GTK3 issue. The setting uses set_size_request() which GTK3 ignores
on paned widgets. Will be fixed in next release using set_position()
instead.
Thanks for the feedback — every report helps improve NativeCAM!
Best,
Axemas
  • rodw
  • rodw's Avatar
17 Apr 2026 12:48
Category: EtherCAT
 re homing, read the homing configuration chapter in the docs. linuxcnc.org/docs/stable/html/config/ini-homing.html
In fact read it about 3-5 times so it sinks in as its not a light read! Both sides need a home switch that remains triggered to the end of travel. When HOME_SEQUENCEs are set up correctly, the first side to hit a home switch stops and waits for the other one to catch up then homing continues in unison. Setting  HOME_OFFSETs allows you to square the  gantry on the final move with no need to physically adjust home switch position.
  • axemas
  • axemas's Avatar
17 Apr 2026 12:48
Category: NativeCAM
Hi Tom,
Thank you so much for the kind words — it really motivates us to keep going!
You are absolutely right about the lathe polyline / contour cycles.
This is exactly on our roadmap. G71/G72/G73 in LinuxCNC 2.9 are now
working properly, so the main blocker that stopped Fern is gone.
Planned for lathe:
- Polyline function (contour definition)
- G71 roughing cycle (OD/ID)
- G72 facing cycle
- G73 pattern repeating cycle
This would indeed bring NativeCAM lathe close to ShopTurn level
for conversational programming — without needing external CAD/CAM.
No timeline promises yet, but it is a real priority.
If you want to follow progress or report issues:
github.com/cnc-proton/nativecam-py3-gtk3
Thanks again for the feedback — users like you make open source
worth working on!
Best regards,
Axemas
Displaying 2896 - 2910 out of 13998 results.
Time to create page: 0.292 seconds
