Ethercat random jitter fix
- Thank you received: 4149
17 Apr 2026 12:33 #345633
Replied by rodw on topic Ethercat random jitter fix
This does not surprise me. I found over the years of keeping repositories in sync, Ethercat includes dkms code which is tailored for specific kernels and breaks with the release of new versions of Debian. This did happen again with the release of Trixie but etherlab expedited the release of 1.6 on my request so you guys probably never noticed. Also, 1.6 is much more sensitive to secure boot and this requires authorizing dkms to modify the kernel code.I tried to compile 1.5.2 on trixie but easier said than done. While I could get around several configuration issues,
there were in the end too severe compilation problems (for me) that I gave up.
At least 1.5.2 doesn't compile out-of-the-box on trixie.
- grandixximo
- Thank you received: 406
17 Apr 2026 13:36 #345639
by grandixximo
Replied by grandixximo on topic Ethercat random jitter fix
gitlab.com/grandixximo/ethercat/-/jobs/1...ad?file_type=archive
Here have debs of ethercat 1.5.2 compatible with debian 13
github.com/grandixximo/linuxcnc-ethercat...0.9.5-retro1.5.2-rc1
and here a linuxcnc-ethercat compatible with the 1.5.2 retro release
you need to type in the mac address and use generic in the systemconfig/ethercat file, in my test OP is same speed, please test on your end and let me know.
linuxcnc-ehtercat retro version I only tweaked latest version based on Sascha's work, and did minimal changes to be compatible with retro 1.5.2 ethercat
- grandixximo
17 Apr 2026 13:47 #345640
by grandixximo
@Hakan @papagno-source
I get worse OP times with 1.5.2
Is that the case for you as well?
Do you have a kernel + linuxcnc + linuxcnc-ethercat + ethercat
versions combination that gets everything ready sub 1 sec?
Before axis opens or just as axis UI opens up?
- papagno-source
- Thank you received: 13
17 Apr 2026 15:37 #345643
by papagno-source
Replied by papagno-source on topic Ethercat random jitter fix
Syste is debian 10 buster x86_64
Kernel: 4.19.0-27-rt-amd64 #1 SMP PREEEMPT RT Debian 4.19.316-1 (2024-06-25) x86_64 GNU/Linux
Ethercat : IgH ETHERCAT master 1.5.2 unknow
Etherlabmaster-1.5.2+20190904hg33b922p8ea394
LINUXCNC 2.9.0-pre0
When axis opens the gui, the axis dimensions are already present. From tests done, when I had the same problem with debian 12, as soon as it reads the loadrt lcec command, the dimensions appear on the pins in hal, relating to the individual axes.
LINUXCNC 2.9.0-pre0
- papagno-source
17 Apr 2026 16:22 - 17 Apr 2026 16:37 #345644
by papagno-source
I have installed linuxcnc-ethercat...0.9.5-retro1.5.2-rc1, without error, but if coomand ethercat version have reult 1.6.9
But I think, this is not the Igh part, but the lcec driver, right?
I have a version running in place in another directory, do I need to copy or link something to test?
On Debian 10 , in direcory bin the linuxcnc , i have only lcec_conf and not have lcec_coffingen
Last edit: 17 Apr 2026 16:37 by papagno-source.
- Hakan
- Thank you received: 454
17 Apr 2026 16:48 #345645
by Hakan
Replied by Hakan on topic Ethercat random jitter fix
Tested a bit.
I get fairly consistent loading times of lcec's rt_app_main() function of 1.85-1.90 seconds.
But but. In syslog I can see that the initial sync of slaves takes anywhere between zero and
say 3,4,5 seconds.
To check
ethercat debug 1
start linuxcnc
exit or leave running, doesn't matter.
sudo journalctl --since "2 minutes ago" | grep "Sync after"
and see where it stops for every slave.
I reckon this is the problematic delay time.
Seldom, but it happens, I get "Checking for synchrony" and then it is satisfied directly and moves on.
It seems measuring the time of lcec's rt_app_main is not a good indicator.
Is there a good way of measuring time to OP?
trixie,
Linux plasma 6.12.69+deb13-rt-amd64 #1 SMP PREEMPT_RT Debian 6.12.69-1 (2026-02-08) x86_64 GNU/Linux
IgH EtherCAT master 1.6.8 1.6.8.g2543cc5-1+27.3 (via apt)
linuxcnc-ethercat, a slightly modified version of commit bf13577ec7b1b54844e07a80d949232e71776b32
linuxcnc 2.9.4 (via apt)
say 3,4,5 seconds.
To check
ethercat debug 1
start linuxcnc
trixie,
- grandixximo
18 Apr 2026 00:21 #345665
by grandixximo
linuxcnc-ethercat version?
LINUXCNC 2.9.0-pre0
dpkg -l | grep linuxcnc-ethercatPlease Log in or Create an account to join the conversation.
- grandixximo
18 Apr 2026 00:37 #345666
by grandixximo
This is the igh ethercat, you need to uninstall your current ethercat master to get this to work, also ethercat-dkms and libethercat.
You might have to run or restart the ethercat service after installing the deb packages in the artifact.zip
for the linuxcnc-ehercat remove your current version
and install this
this is the lcec part, and it has both lcec_conf and lcec_coffingen
I cannot fathom why you would have one and not the other if you installed my packages.
I saw you tried to come to the discord, but you did not give a thumbs up to the rules message, so you were not allowed in.
I'm on +08:00 time. not in Italy. So mind the time difference. I'll only probably be available in the morning Italy time.
gitlab.com/grandixximo/ethercat/-/jobs/1...ad?file_type=archiveI have installed linuxcnc-ethercat...0.9.5-retro1.5.2-rc1, without error, but if coomand ethercat version have reult 1.6.9
sudo systemctl restart ethercat.servicefor the linuxcnc-ehercat remove your current version
and install this
18 Apr 2026 00:49 #345668
For somebody trying hard to follow along from the sidelines, can you guys outline the objective for rolling back to 1.52 here?
Has anybody looked at the Igh Ethercat master 1.6 or even 1.7 which was released on gitlab 3 weeks ago (but not in their repositories) to see if it has these delays outside of linuxcnc.
It seems to me it would be unlikely that iGh master 1.6 or 1.7 are problematic as people would be complaining at iGh so to me, the effort should be in understanding what has changed that linuxcnc-ethercat is not liking. Rolling back to a very old version does not seem a progressive step following the synchronisation enhancement.
- grandixximo
18 Apr 2026 01:17 - 18 Apr 2026 01:20 #345669
by grandixximo
At the end of my hal file Iand I save the default watch to display the OP pins, you can have master all-op, and each slave individual OP pin, I count Mississippies or use stopwatch...
Another alternative isBut this might "dirty" the bus, may effect OP time, maybe...
To get more accurate times might have to build a script, or use dmesg with some debug from ethercat.
But I think the difference papagno-source is talking about can be perceived with less precise tooling, in one case everything OP even before the UI opens, and in the other he has to wait some amount of time, so it is a difference in the seconds range.
I will try to setup similar setup to yours, and check the OP times.
Tested a bit.
say 3,4,5 seconds.
To check
ethercat debug 1
start linuxcnc
trixie,
loadusr halshowAnother alternative is
watch -n 0.2 ethercat slTo get more accurate times might have to build a script, or use dmesg with some debug from ethercat.
Last edit: 18 Apr 2026 01:20 by grandixximo.
Time to create page: 0.209 seconds
