Ethercat random jitter fix
  • grandixximo
  • grandixximo's Avatar Topic Author
  • Platinum Member
  • Platinum Member
13 Apr 2026 09:33 #345483 by grandixximo
Replied by grandixximo on topic Ethercat random jitter fix
Are you saying that the only way it works is this
refClockSyncCycles="-1" syncToRefClock="false"
13 Apr 2026 09:35 - 13 Apr 2026 09:41 #345484 by papagno-source
Replied by papagno-source on topic Ethercat random jitter fix
Initially, everything seemed to be working fine, because I was testing a system with smaller motors, always from the same manufacturer, not connected to the mechanics. I noticed the problem when I started moving the axes on a real machine. Here's my experience:
-First of all, on Debian 10 with EtherCAT 1.5.2, I never used the :syncToRefClock parameter, only refClockSyncCycles.
-On a real machine with an ASD2 Delta drive, with the first I/O node being the same, if I set the refClockSyncCycles parameter to -1, the axes shook at the first movement.
If I set the refClockSyncCycles parameter to 1, the machine worked 99.9% of the time; only very rarely was I forced to reboot the system because the axes made noise the first time they were restarted.
Still on Debian 10 with ethercat 1.5.2, with the same I/O node, with a Veichy drive, the refClockSyncCycles=1 parameter causes the axes to shake. I had to set refClockSyncCycles=-1 to work without problems.
Debian Trixie ethercat 1.6.9, Veichy drive machine. I initially set the Debian 10 xml file, so with only refClockSyncCycles=-1, the machine makes noise.
I then modified the xml with refClockSyncCycles=-1 and syncToRefClock="false" and now the machine works correctly.
I haven't been able to test Debian Trixie with the ASD2 drive, but I think at this point it will behave the same as Debian 10, namely:
refClockSyncCycles=1 and syncToRefClock="false"
I therefore assume that the syncToRefClock="true" parameter is set by default if not added to the XML file.
Last edit: 13 Apr 2026 09:41 by papagno-source.
13 Apr 2026 09:37 #345485 by papagno-source
Yes machine work only with refClockSyncCycles="-1" syncToRefClock="false"
  • grandixximo
  • Platinum Member
  • Platinum Member
13 Apr 2026 09:40 #345486 by grandixximo
syncToRefClock is false by default, your assumption is incorrect, are you sure you have built my repo's code?
  • grandixximo
  • Platinum Member
  • Platinum Member
13 Apr 2026 09:58 - 13 Apr 2026 10:03 #345487 by grandixximo
then it should also work with
refClockSyncCycles="1"
just the above don't add
syncToRefClock="false" or syncToRefClock="true"
your assumption is correct in the case you are testing.
will force syncToRefClock="true" because that is expected to respect old behavior
so your problem is PLL is causing the vibrations
Please run my commands again with only
then run
ethercat upload -p 0 -t uint32 0x1C32 0x06
ethercat upload -p 0 -t uint32 0x1C33 0x06
ethercat upload -p 1 -t uint32 0x1C32 0x06
ethercat upload -p 1 -t uint32 0x1C33 0x06
ethercat upload -p 0 -t uint32 0x1C33 0x03
ethercat upload -p 1 -t uint32 0x1C33 0x03
ethercat upload -p 0 -t uint32 0x1C32 0x09
ethercat upload -p 1 -t uint32 0x1C32 0x09
Last edit: 13 Apr 2026 10:03 by grandixximo.
13 Apr 2026 10:19 #345488 by papagno-source
I only tested refClockSyncCycles="1" without writing syncToRefClock, and the machine worked flawlessly.
The lcec.0.pll-err pin in this case reported a value oscillating from approximately 991902 to 994498.
The rest remained the same:
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
The result is :
ethercat upload -p 0 -t uint32 0x1C32 0x06 return Failed to upload SDO: Input/output error
ethercat upload -p 0 -t uint32 0x1C33 0x06 return Failed to upload SDO: Input/output error
ethercat upload -p 1 -t uint32 0x1C32 0x06 return 0x00000000 0
ethercat upload -p 1 -t uint32 0x1C33 0x06 return 0x00000000 0
ethercat upload -p 0 -t uint32 0x1C33 0x03 return SDO transfer aborted with code 0x06010000: Unsupported access to an object
ethercat upload -p 1 -t uint32 0x1C33 0x03 return SDO transfer aborted with code 0x06010001: Attempt to read a write-only object
ethercat upload -p 0 -t uint32 0x1C32 0x09 return 0x00030d40 200000
ethercat upload -p 1 -t uint32 0x1C32 0x09 return 0x00000000 0
  • grandixximo
  • Platinum Member
  • Platinum Member
13 Apr 2026 10:31 #345489 by grandixximo
sorry, I got messed up, should test the ethercat upload commands with
If you could also do some more testing, I'd really like to get to the bottom of this
also with refClockSyncCycles="-1" (don't move just start)
Check pll_reset_cnt, does it increment every ~1/sec?
Also could you move the first servo drive as the first slave, and try with refClockSyncCycles="-1"?
13 Apr 2026 10:50 #345490 by Hakan
Replied by Hakan on topic Ethercat random jitter fix
@rodw
grandixximo's linuxcnc-ethercat repo, right?
That pll-err value shows it's not the linuxcnc standard code. That oscillates around zero.
Please expand on what you mean here.
This is a standard RIP install of Debian 2.10 except its in a folder under /usr/lib, grandixximos driver built from source, Ethercat from repos. That should make no difference. For me, latency etc is fine on my hardware which makes it weird.
In Scott's linuxcnc-ethercat repo pll-err oscillates around 0.
In grandixximo's repo pll-err oscillates around that number 992000 something.
It's not necessarily wrong, it was just how I could tell.
13 Apr 2026 10:52 - 13 Apr 2026 10:53 #345491 by papagno-source
As mentioned, with only the refClockSyncCycles="-1" parameter, the axis makes noise, but it's only for reconfirmation.
Parameter values ​​are with refClockSyncCycles="-1"
ethercat upload -p 0 -t uint32 0x1C32 0x06 return 0x00000000 0
ethercat upload -p 0 -t uint32 0x1C33 0x06 return 0x00000000 0
ethercat upload -p 0 -t uint32 0x1C33 0x03 return Failed to upload SDO: Input/output error
I can't reverse I/O with the drive. I/O is always 0, the drives follow. I would have to change everything hal, but this configuration works fine with Debian 10 and now also with Trixie, but with refClockSyncCycles="1"
The pin pll , oscillation value about 1 second value 0 after 4210619, after 1 second restar with 0
Last edit: 13 Apr 2026 10:53 by papagno-source.
  • grandixximo
  • Platinum Member
  • Platinum Member
13 Apr 2026 10:56 #345492 by grandixximo
please check hal pin
ecat.0.pll_reset_cnt
Time to create page: 0.350 seconds
