Ethercat random jitter fix
  • grandixximo
  • grandixximo's Avatar Topic Author
  • Platinum Member
  • Platinum Member
07 Apr 2026 09:37 #345261 by grandixximo
Replied by grandixximo on topic Ethercat random jitter fix
I've used LeadShine and XingJie same issues with both, there may well be mitigations on the servos side for some manufacturer, but that does not mean the standard of Ethercat says they should be doing such a thing. So it's luck?
  • grandixximo
  • Platinum Member
  • Platinum Member
07 Apr 2026 10:48 - 07 Apr 2026 11:27 #345263 by grandixximo
The linuxcnc-ethercat current release does not respect the ethercat standard, it has time phasing issues, this is demonstrably true.
Anyone lucky enough to not experience any issue has:
Incredibly low latency
Servos that somehow adjust phasing themselves further than what the Ethercat standard dictates.
CPU with instruction execution timing consistency across processes, somehow doing the phasing properly even if the code did not directly intended it.
Some servo feature that filters the commanded position.
Not used pos-cmd mode.
Not actively been looking for it, restarting 100+ times and induced high latency, and looking at Ferror and servo-thread in the halscope.
Even if some hardware is not bothered by wrong phasing, you should not blame this on the servo drives manufacturers. The software they are interfacing with demonstrably does NOT respect the communication standard.
Last edit: 07 Apr 2026 11:27 by grandixximo.
The following user(s) said Thank You: NWE
07 Apr 2026 11:42 #345264 by andrax
Replied by andrax on topic Ethercat random jitter fix
Interesting.
My computer is an ancient IPC from 2006. Except for the SSD, everything is original hardware.
The network card, however, has an Intel chip and is Beckhoff certified.
infosys.beckhoff.com/index.php?content=..../9309844363.html&id=
Perhaps that's a clue.
  • grandixximo
  • Platinum Member
  • Platinum Member
07 Apr 2026 12:15 #345265 by grandixximo
What are the clues supposed to point us to?
I have igc i210 advertised as supported by igh and Beckhoff.
There maybe a lot of reasons why your setup works for you, but there is only one cause for the jitter noise I was experiencing, there maybe other unrelated noises on other hardware, but the one I identified is fixed in my fork of the code.
What will figuring out why you don't have the issue get us? Did you run extensive testing with restarts looking at the halscope to prove you don't have the issue?
07 Apr 2026 13:01 #345266 by andrax
Sorry,
It was just a thought. And no, I haven't had any jitter problems so far, despite endless restarts. I've often even had to restart the servos mid-operation (homing failure).
I'm absolutely certain that your driver is working and resolving the jitter issues.
But what if the hardware isn't compatible or is causing problems...?
I just wanted to throw that out there.
Sorry.
07 Apr 2026 13:20 #345267 by endian
Replied by endian on topic Ethercat random jitter fix
what do you think with not to use pos cmd mode ? do you have an unreliable experiences with them?
  • grandixximo
  • Platinum Member
  • Platinum Member
07 Apr 2026 14:22 #345271 by grandixximo
@andrax
No need to apologize, just trying to understand where you were going with it.
With my fork I don't have any jitter noise when things are set as they should. Finding the issue was no easy feat, before looking at linuxcnc ethercat, hardware wise I tested with  different servos, different CPUs, different network chips, software wise, different ethercat versions, different kernels, different linuxcnc versions. Ruled out basically everything else, I knew it had to be linuxcnc-ethercat, and after putting in the time to find the issue, I am sure I found it, while before it was random, I can now reproduce it at will, and I can turn off the jitter at will, I can place the phasing in and out of the jitter with the sync0shift setting, this is correct and expected within the ethercat standard, even twincat has a default Sync0shift of 30% cycle time, and you should expect issue somewhere between 0 and 30% what issues will depend on hardware, but the standard does not want your Sync0shift in that range for a good reason, and the hardware is not supposed to work properly when you don't follow the standard, and the original code was NOT following the standard, maybe accidentally on some hardware it was ok, even a broken clock is right twice per day...
@Endian
I only use pos-cmd mode, i think velocity and torque mode can get better performance, give you more control, but require more tweaking, and I think (but not sure) any slight issue like the jitter of this topic might be absorbed by a finely tuned PID for the job.
While pos-cmd rely on PID of the servo, it's normally a general one, which will work for most applications, in my case it's very strict and quick, that's why the motor vibrates, it's trying to respect position very strictly, which usually is a good thing...
The following user(s) said Thank You: andrax, endian
  • grandixximo
  • Platinum Member
  • Platinum Member
07 Apr 2026 14:44 #345274 by grandixximo
If there are still users with the jitter noise, and they are using my fork, please increase your Sync0shift, check your latency, try with both synctorefclock true and false, post halscope readings of the various relevant pins, and your XML ini and hal files.
Whatever is left must be software of hardware tuning issues, there maybe some network chips or some CPUs with very bad latency, that my phasing can't fix, I know it works well on my hardware, but it needs to be seen if I need to create some more Hal pins or not, some hard code values which could help with tuning the phasing process, some users might want to tune these, but I'm not sure it's worth it, if your latency is decent, the current hard coded values will work well.
The following user(s) said Thank You: andrax, endian, NWE
07 Apr 2026 16:29 #345278 by andrax
That’s exactly what I was getting at.
After their extensive testing, they can confirm that the driver works flawlessly.
Anyone who’s still having problems should take a closer look at their hardware. That’s why I brought this up and mentioned Beckhoff. All compatible chips are listed there, but unfortunately, few people know that.
Maybe I just didn’t express myself clearly.
Here’s my thinking.
Many people already have EtherCAT up and running successfully.
We could collect the hardware information and put it in a wiki.
System requirements:
>PC, network card, cable, EMC filter
>Configuration examples
>Troubleshooting tips
>Explanation of individual functions
That would help many new users get up to speed on the madness of EtherCAT
before they flood the forum with the same questions over and over.
I can’t do that myself. When I start a thread like that, it disappears into oblivion really fast.
Only the admins can do that
Regards, Andrax
The following user(s) said Thank You: endian
07 Apr 2026 17:49 #345284 by Atsu
Replied by Atsu on topic Ethercat random jitter fix
Just wanted to report back that since installing grandixximo's fork three weeks ago, I’ve had zero issues. So at least for me and my hardware, that’s the real solution here.
Time to create page: 0.308 seconds
