Ethercat random jitter fix
- grandixximo
- Thank you received: 413
23 Mar 2026 03:47 #344624
by grandixximo
Replied by grandixximo on topic Ethercat random jitter fix
Try with synctorefclock false, and see if your reset counter also counts up or not
The following user(s) said Thank You: NWE
- TAKUYA
28 Mar 2026 11:27 #344883
by TAKUYA
Replied by TAKUYA on topic Ethercat random jitter fix
I did, unfortunately with SyncToRefclock set to false, the dc-phased pin starts flickering.
the reset counter doesnt go up either.
with it set to true, the rest counter goes to 1 or 2 per lcnc launch.
what ive also found, without every driver being ready, the dc-phased pin is already HIGH. Is that supposed to happen?
- Hakan
- Thank you received: 499
28 Mar 2026 12:47 #344886
by Hakan
Replied by Hakan on topic Ethercat random jitter fix
Can you plot pll-err? Sounds like you have quite a bit of "normal" jitter.
That can be seen in pll-err.
dc-phased is just the condition that pll-err is below 10% of your servo cycle time.
- TAKUYA
28 Mar 2026 13:07 #344887
by TAKUYA
I can yea. what bothers me, is that the DRO was "filled" with the encoder position right away previously. Now, it rarely does but most of the time, takes 5-10 seconds to fully fill in with machine positions. If you enable it before that, you get amplifier errors or a loud axis clunk.
I dont know of anything that changed other than weather
- grandixximo
29 Mar 2026 02:30 #344897
by grandixximo
The phasing is done before all-op, it is about phasing with first drive DC epoch, the epoch arrives ages before all-op
Your problem is CPU and or network jitter, the symptoms your are reporting as Hakan correctly deduced, are telling us your latency is too high.
refClockSyncCycles="1" syncToRefClock="false"
I think is your best bet.
if you still get jitter, I'd say look at your latency, cpu? kernel version? network harware? latency histogram results with a few glx gears?
isolcpus, nohz_full ?
The following user(s) said Thank You: endian
- TAKUYA
29 Mar 2026 05:40 #344901
by TAKUYA
im reinstalling the whole unit today.
i was trying trixie as i had to redo my host for the new cnc. But apparently is this very experimental with debian 13.
Im installing the linuxcnc 2.9.4 iso now, which should still be bookworm. then updating to 2.9.8 and installing the patch again
- TAKUYA
29 Mar 2026 14:53 #344927
by TAKUYA
re-did the pc. even used one with a 10th gen i5 now instead of the old 5th gen. Jitter is at around 10-20k. should be fine.
DRO is still not always filled on start, still takes a few moments for it to do that.
Will test further
Will test further
- TAKUYA
30 Mar 2026 06:35 #344944
by TAKUYA
@grandixximo
Do you have any idea what might be causing the delay in the DRO?
It seems like the drives arent going into OP right away. The delay is always different. Sometimes the DRO is instantly filled with the encoder read (but converted to axis position) values, sometimes it takes up to 10 seconds.
Could this also be part of the whole issue? The drives PRE-OP to OP delay.
- NWE
- Thank you received: 87
30 Mar 2026 17:41 #344974
by NWE
Does anything relavant show up in dmesg?
Once it finally populates the DRO, is everything working after that?
Replied by NWE on topic Ethercat random jitter fix
Seems a bit unexpected to have up to 10 second delay before OP on ethercat. Is this a new config or was it previously working?It seems like the drives arent going into OP right away. The delay is always different. Sometimes the DRO is instantly filled with the encoder read (but converted to axis position) values, sometimes it takes up to 10 seconds.
- TAKUYA
30 Mar 2026 23:33 #344982
by TAKUYA
The config was previously working just fine. I dont know what changed that caused this.
Ill check dmesg again when im home.
As for the working state after the DRO populates... Its hard to say. I can definately move every axis just fine, but theres a 50% chance that clunks occur. Sometimes more clunks, sometimes less clunks. Sometimes they even appear mid-cycle which is a no-go.
ive swapped out all the ethernet cables now, re-imaged my lcnc host, even used a new host without any success.
Time to create page: 0.164 seconds
