Ethercat random jitter fix
- grandixximo
- Thank you received: 413
21 Mar 2026 10:17 - 21 Mar 2026 10:18 #344578
by grandixximo
Replied by grandixximo on topic Ethercat random jitter fix
Another thing that comes to mind, do your servos have braking feature? The clunking and the resonance could be related to that if you do have brakes, possibly they are not being properly managed? I use braking on my Z servo drive, and if I lock it when idle I have resonance as well, that's the only thing that comes to mind, also it does make a noise when it engages more of a click than a clunk, just my brain went there...
Last edit: 21 Mar 2026 10:18 by grandixximo.
- ihavenofish
- Thank you received: 287
21 Mar 2026 13:42 #344583
by ihavenofish
Replied by ihavenofish on topic Ethercat random jitter fix
no braking features.
noise, I'm not sure how to really tell if there was. the cables are all cat6.
- grandixximo
22 Mar 2026 00:21 #344594
by grandixximo
Cat6 come in both shielded and unshielded, need look at the cable specs, also the heads have metal, and you can check continuity for shielding, other than that, sharing your configuration would maybe tell us more.
- Hakan
- Thank you received: 499
22 Mar 2026 01:13 #344595
by Hakan
Replied by Hakan on topic Ethercat random jitter fix
Record lcec.0.pll-err with halscope. Should stay low.
- ihavenofish
22 Mar 2026 01:28 #344596
by ihavenofish
as i said it bounces plus or minus 30000 or soRecord lcec.0.pll-err with halscope. Should stay low.
- Hakan
22 Mar 2026 01:35 #344597
by Hakan
Haha read-check
Ten times more than I got, still only 30 mikroseconds.
Could be enough if you are close to the limit. But you shouldn't be, I guess. Are you?
Record position feedback and commanded position when the clunk happens.
There ought to be something.
- TAKUYA
22 Mar 2026 10:22 #344606
by TAKUYA
Replied by TAKUYA on topic Ethercat random jitter fix
@grandixximo
Unfortunately, the Jitter/Clunking came back, even though dc-phased is on.
- grandixximo
22 Mar 2026 17:29 - 22 Mar 2026 20:14 #344618
by grandixximo
@TAKUYA
Is your
sync0Shift="0"
You should set sync0Shift to 250000 or 500000
sync0Shift to 0 is not correct, as per my understanding of the ethercat DC specifications.
Is your
sync0Shift="0"
Last edit: 22 Mar 2026 20:14 by grandixximo.
- Hakan
23 Mar 2026 01:23 - 23 Mar 2026 01:26 #344621
by Hakan
Did you say you had changing values on pll-reset-count? That one should stay on 1, not increase.
Can you perhaps record pll-err in halscope and show?
Last edit: 23 Mar 2026 01:26 by Hakan.
- TAKUYA
23 Mar 2026 03:09 #344623
by TAKUYA
@grandixximo
Sync0shift is set to 300000
Time to create page: 0.149 seconds
