Ethercat random jitter fix
13 May 2026 01:28 #346368 by rodw
Replied by rodw on topic Ethercat random jitter fix
This is great news. There has been a lot of ethercat related development activity driven by grandixximo on both Linuxcnc and the linuxcnc-ethercat hal driver. When a few more things come together, I will be refreshing my ISO's which will put everything on the one ISO.
Its great that Grandixximo is now the owner of the  linuxcnc-ethercat repository and he's implemented a number of changes with more in the pipleine. He's also got a PR with LinuxCNC that will provide a "hook" in linuxCNC to allow synchronizing the servo thread with Ethercat before the servo thread starts which should further improve results and perhaps remove that little squeak even..
Thank you for your endorsement of my kernel tuning optimizations. Its very valuable feedback being able to state Trixie (Ddebian 13) is as good as Debian 10 once tuned. Having a system that queries your PC as it is optimised has reduced manually tuned jitter by 50% in my testing. I have never been very rigorous about this testing as it needs to be installed on hardware  and I have to stuff around compiling a wifi driver every times so its easy to loose data but it seems to improve with every iteration as its given me a place to record every new optimisation I unearth.
At risk of upsetting some, you can find out more about my optimisations on my Youtube channel www.youtube.com/@MrRodW or the companion website mrrodw.au/
The following user(s) said Thank You: andrax
13 May 2026 13:17 #346379 by andrax
Replied by andrax on topic Ethercat random jitter fix
Thank you very much for all your hard work. I’ve been following this thread the whole time, and now that the changes are being incorporated into the official repository, I’ll update my repositories and test the new EtherCAT HAL driver.Note 1:From what I’ve read, there does appear to be a dependency between the software and hardware.Note 2:I would ask you to investigate whether Debian, the base thread and the servo thread can each be assigned to a single CPU core.This would further improve stability.This is also done by Beckhoff and Codesys.It makes their runtime independent of the operating system and guarantees real-time capability.
13 May 2026 18:21 #346385 by rodw
Yes, I believe this is the correct approach but I've never run a base thread or looked at the thread instantiation code in detail. :)
With a single isolated core (normal case) both threads should end up there.
Ethercat and Mesa configs should not need a base thread
  • grandixximo
  • grandixximo's Avatar Topic Author
  • Online
  • Platinum Member
  • Platinum Member
14 May 2026 02:27 #346389 by grandixximo
Replied by grandixximo on topic Ethercat random jitter fix
There is no need for base-thread on ethercat machines
base-thread should be set to 0, which will disable it, you can hook up everything to servo-thread, also the "no floating point" situation is completely stripped out form 2.10 master, and disabled on next 2.9 release, 2.9.9 whenever that ships...
The following user(s) said Thank You: rodw, NWE
15 May 2026 11:21 #346415 by andrax
I installed and tested the new driver.
The installation went smoothly, and the driver is working.
I’ll be testing it thoroughly over the next few days.
I can’t comment on the jitter or synchronization issues, as I haven’t experienced any problems in that regard.
Nevertheless, I’d like to provide some feedback.
Great work
The following user(s) said Thank You: grandixximo
20 Jul 2026 01:10 #347858 by ihavenofish
Replied by ihavenofish on topic Ethercat random jitter fix
So i installed this on a redone setup of 2.9.8 and im getting constant random joint and limit errors. even mid program. they seem to stem from random spike encoder frames. sometimes it goes 10 mins without anything, sometimes you can move for 1 second without one.
I am not 100% sure they are related to this patch, or what this patch is meant to fix. But its rendered my machine pretty unusable. (i redid the machine to add a 4th axis)
Any thoughts?
20 Jul 2026 01:57 #347860 by rodw
Any thoughts?
From a message from grandixximo
can try for now to do
loadrt lcec
initf lcec.activate servo-thread
addf lcec.read-all servo-thread
20 Jul 2026 02:01 #347861 by rodw
Also the Ethercat repos have changed to point to linuxcnc-ethercat
The instructions in my Ethercat sticky have been updated so also follow them
2.9.10 ISO should install the new repos mentioned but follow the  instructions in step 2
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
The following user(s) said Thank You: JohnW
20 Jul 2026 02:57 #347865 by ihavenofish
loadrt lcec
thats already in my hal
I did find something interesting. at least specifically on the 4th. when it give a joint error, the encoder position INVERTS, as does the display. And it STAYS inverted. so ill be jogging at 900 degrees on the A... and then joint error and it become -900 degrees.
I dont know if the other axis joint errors are also inverting, i cant "see" them yet. If they are they are returning back to position the next frame. The rotary axis for some reason doesn't return, it just flips sign.
20 Jul 2026 03:17 #347866 by ihavenofish
ok, the joint error is something else. it happens at 912.45 ALWAYS. it must and over run of something. we have like 800 million counts per turn of the axis, so its inverting at 2 billion encoder counts.
Ill put this in my other thread as it i dont think has to do with the ethercat jitter problem.
Time to create page: 0.137 seconds
