  • Zbigi
  • Zbigi
16 Apr 2026 18:16 - 16 Apr 2026 18:21
NativeCAM 2.0b — Python 3 & GTK3 port for LinuxCNC 2.9 / Debian 13 Trixie
Category: NativeCAM
Hi Axemas
Thank you very much—after making the changes, it worked
immediately. A huge thank you!
I agree with what Surmetall wrote; a feature like that would be very helpful.
However, regarding some minor tweaks—which I hope are simple for you to fix—setting the width of the NC tab—
“Master treeview minimal width” in Preferences
doesn’t work. This results in a lot of screen space for parameters and a very small project display area, but as I mentioned, this is just a cosmetic issue.
Thanks again, and I hope the community of Nativecam enthusiasts—of which I am one—will grow significantly.
Zbigi
  • jetbadger
  • jetbadger
16 Apr 2026 18:13
Replied by jetbadger on topic Lathe C axis homing
Lathe C axis homing
It does make some sense to me that the commanded position would stay ahead by some bit so that it doesn't instantly get massive following error, but am not sure at this point. It comes from joint.n.motor-pos-cmd. I've attached the config files here
File Name: Schaublin2.hal
File Size:13 KB
File Name: SchaublinSpindle.hal
File Size:13 KB
File Name: Schaublin2.ini
File Size:8 KB
  • papagno-source
  • papagno-source
16 Apr 2026 18:03
Replied by papagno-source on topic Ethercat random jitter fix
Category: EtherCAT
Furthermore, while on Debian 12 and Debian Trixie the Grub command line has been optimized, with isolcpu, c state, etc., in Debian 10 there are no optimizations. Obviously I tried to remove the optimizations on Debian 12 and Trixie, as well as on Debian 10, but the problem persists, only on Debian 12 and Trixie.
  • MaxiMec
  • MaxiMec
16 Apr 2026 17:50
Modernización Emco Turn 55-ii was created by MaxiMec
Category: Turning
¿Cómo están? Es mi primera vez por acá, me encuentro en la situación de querer actualizar un torno CNC Emco Turn 55-ii con mis compañeros de la tecnicatura de Mecatrónica, el torno se encuentra y es parte de una Escuela técnica de argentina. Vengo en búsqueda de opiniones, experiencias y quien dice; algún manual de cableado del torno. Todo es agradecido. Espero que se encuentren bien.
  • MaxiMec
  • MaxiMec
16 Apr 2026 17:41
Replied by MaxiMec on topic Emco PC Turn 55 retrofit
Category: Show Your Stuff
​I'm currently working on an upgrade project for an Emco Turn 55-II lathe located at a local school.
​I’m looking for the wiring manual or electrical schematics for this machine. I’m not entirely sure which of the two versions it is, so if anyone happens to have documentation for either (or both), it would be a huge help so I can compare them and move forward with the project.
​Any help or guidance on where to find these would be greatly appreciated!
​Thanks in advance.
Please excuse any mistakes in my English, as I am using a translator to write this
  • HansU
  • HansU's Avatar
16 Apr 2026 17:17
Replied by HansU on topic More touch-friendly Speedcontrol-slider
Category: Gmoccapy
I think the popup of any kind is not strictly necessary but possibility to change value by sliding the slider are most welcome. Especially by users of capacitive Touchscreens. Original solution I think was created for resistive touchscreens where the +- buttons still are viable solution as sliding there would not work well.
I have a resistive touchscreen and this works quite well.
  • papagno-source
  • papagno-source
16 Apr 2026 17:09
Category: EtherCAT
Good morning everyone. After several tests I had to leave the machine to the customer with Debian 10. Believe me, I tried everything. It seemed to work with the refClockSyncCycles setting to 1, but sometimes the motors, when the PC was started for the first time, made noise. Turning it off and on again is fine and when it works well, it works well for a long time. I even tried Debian 12, the Git ISO and ethercat 1.6.3, but even worse than Trixie. I put back the Debian 10 HD and ethercat 1.5.2 and it still works fine, even if at first glance, in addition to the fact that with Debian 10, the drive values ​​are read instantly when the PC starts, while with Debian 12 and Trixie, you have to wait a few seconds. And in my opinion, everything starts from this problem. I set latency-histogram --nobase --sbins 1000 --show, stressed the PC, with gear, opening the browser (not connected), moved windows, opened librecad etc., but Debian 10 has maximum and minimum latency half of Debian 12 and Trixie, same PC. I think the problem is between the RT kernel and the Ethercat version. For example, I tested the Debian 10 pins with Ethercat 1.5.2. The pll-error value oscillates between -2200 and 1600. The pll-out pin has a fixed value of 1000 or -1000. Why don't we try installing Ethercat 1.5.2 on Trixie, so as to understand if the problem is on the kernel or Ethercat side. I think that on the Icec side, there is little to do. Yes, we're certainly trying to optimize, but the main problem is latency and jitter stability. I remain available. Luca, I wrote to you privately, but you haven't responded.
  • deomon
  • deomon
16 Apr 2026 15:45
Replied by deomon on topic More touch-friendly Speedcontrol-slider
Category: Gmoccapy
  • motionmasterupgrade
16 Apr 2026 15:19
Columbo 7.5hp spindle was created by motionmasterupgrade
Category: User Exchange
Hey, folks here literally saved my ass from a disaster so I'm passing it on.
I have a 7.5hp old Columbo spindle that I know little about besides:
(a) Resistance is 1.8ohm consistent across all 3 windings.
(b) Its from 1994ish, and serviced in 2004.
(c) Manual change, and the mechanism to hold the spindle works.
(d) CAT40, insides look good, threads look good.
(e) 18000rpm (I think)
(f) About 80 freedom weight units (says so on the maintenance invoice from 2004).
Free.
You pay shipping. Its located in southern New Hampshire in Freedomland.
I will post runout or vibration numbers once I get set up to measure everything.
Do request any info you need, and I'll update it here as I measure stuff.
I'm trying to set up linuxcnc on an old motion master bridge. Reusing the brushed servos and 4 amp. drives. Adding 4 pulse train Yaskawa servos/drives (this is the upgrade) to swivel head and rotaries. I'd very much appreciate someone willing to take a few calls and guide me along so I can get help or quick opinions when in a pinch. I've so far managed to covert a 480V machine to 220V.
Something I'd love is a 7i77u board (just borrow it for a few weeks if you have one to spare). I just don't know enough to understand if I can use 7i77 boards that are immediately available. That's my immediate next step.
They are out of stock and I'm hard up for time. Wife gave me permission to start a project with a machine that is the size of a room, and then, a few weeks later, tells me the whole family is moving to a place that not much bigger than the room the machine is filling up. FML.
Make stuff and prosper.
  • Dudelbert
  • Dudelbert
16 Apr 2026 15:03
Considering a Full Rewire on a Working Schaublin 125 CNC
Category: Turning
Oh, I had forgotten about that. I will try if that works. Thanks for the idea.
  • RotarySMP
  • RotarySMP's Avatar
16 Apr 2026 15:03
Replied by RotarySMP on topic More touch-friendly Speedcontrol-slider
Category: Gmoccapy
That looks cool, but I added physical encoders for Jog, feed and spindle overrides, so I never use the buttons.
  • RotarySMP
16 Apr 2026 15:00
Category: Turning
Since there are two Hall sensor triggers on X, do you get the same errors homing off each?
  • LukeST
  • LukeST
16 Apr 2026 14:56
Replied by LukeST on topic spindle-at-speed
spindle-at-speed
Category: Deutsch
Ihr seid klasse!
Mit eurer Hilfe habe ich folgendes rausgefunden:
Unter P04.03 kann ich mit dem Wert 03 für das Relais 1 folgendes einstellen: "3:Arbritrary frequency arrival Time,
Relay=ON,Related to P02-10 settings" --> Unter P04.04 ist das für ein Relais 02 einzustellen. Dieses Relais gibt es aber (bei meinem FU) gar nicht.
P02.10 war dann nicht so leicht zu finden.: P02.10 Arbitrary Frequency Setpoint 0-400Hz
Zuerst hatte ich dieses Manual: bulkman3d.com/wp-content/uploads/2019/08...Wk1gLYu__4-sQemlJnOc
Da fehlten aber einige Einstellungen. Dann habe ich noch dieses Manual (nur die Einstellungen) gefunden: bulkman3d.com/wp-content/uploads/2019/08...Wk1gLYu__4-sQemlJnOc
Jetzt schaltet sich das Relais erstmal ein, sobald sich die Spindel dreht. Ich denke, dass ich mit P02.10 da noch was besser einstellen kann.
Nun schaltet das Relais die Kontakte CM1 und NO1 durch, sobald sich die Spindel dreht. Ich denke, dass ich den Anschluss an die Mesa-Card (+24V auf CM1, NO1 an die Mesa-Card) und dann die Einstellungen in der HAL (siehe in der Antwort von 0x2102) dann hinbekomme.
Vielen Dank!
  • HansU
  • HansU's Avatar
16 Apr 2026 14:54
Category: Gmoccapy
Currently the value of the sliders can only be adjusted by the +/- buttons. This makes it impossible to change those values quickly.
Here are two implementations which opens a bigger slider with the possibility to drag the slider.
What do you guys think of those two versions?
  • Dudelbert
  • Dudelbert
16 Apr 2026 14:45 - 16 Apr 2026 14:47
Category: Turning
The previous owner installed a magnetic encoder on the X axis. I did not disassemble it, so all there is to see is a thin cable coming out.
I installed a glass scale on Z. I will make photos tomorrow, there is perfect space for it behind the X-axis motor mount. The installation was really easy.
Oh, and to “home to switch (hall switch) and then to the next encoder count” that is what I did initially. That way I got about 0.4 mm variability on X.
Displaying 2926 - 2940 out of 13998 results.
Time to create page: 0.494 seconds
