  • papagno-source
  • papagno-source
13 Apr 2026 10:52 - 13 Apr 2026 10:53
Replied by papagno-source on topic Ethercat random jitter fix
Category: EtherCAT
As mentioned, with only the refClockSyncCycles="-1" parameter, the axis makes noise, but it's only for reconfirmation.
Parameter values ​​are with refClockSyncCycles="-1"
ethercat upload -p 0 -t uint32 0x1C32 0x06 return 0x00000000 0
ethercat upload -p 0 -t uint32 0x1C33 0x06 return 0x00000000 0
ethercat upload -p 1 -t uint32 0x1C32 0x06 return 0x00000000 0
ethercat upload -p 1 -t uint32 0x1C33 0x06 return 0x00000000 0
ethercat upload -p 0 -t uint32 0x1C33 0x03 return Failed to upload SDO: Input/output error
ethercat upload -p 1 -t uint32 0x1C33 0x03 return SDO transfer aborted with code 0x06010001: Attempt to read a write-only object
ethercat upload -p 0 -t uint32 0x1C32 0x09 return 0x00030d40 200000
ethercat upload -p 1 -t uint32 0x1C32 0x09 return 0x00000000 0
I can't reverse I/O with the drive. I/O is always 0, the drives follow. I would have to change everything hal, but this configuration works fine with Debian 10 and now also with Trixie, but with refClockSyncCycles="1"
The pin pll , oscillation value about 1 second value 0 after 4210619, after 1 second restar with 0
  • Hakan
  • Hakan
13 Apr 2026 10:50
Replied by Hakan on topic Ethercat random jitter fix
Category: EtherCAT
@rodw
grandixximo's linuxcnc-ethercat repo, right?
That pll-err value shows it's not the linuxcnc standard code. That oscillates around zero.
Please expand on what you mean here.
This is a standard RIP install of Debian 2.10 except its in a folder under /usr/lib, grandixximos driver built from source, Ethercat from repos. That should make no difference. For me, latency etc is fine on my hardware which makes it weird.
In Scott's linuxcnc-ethercat repo pll-err oscillates around 0.
In grandixximo's repo pll-err oscillates around that number 992000 something.
It's not necessarily wrong, it was just how I could tell.
  • grandixximo
  • grandixximo's Avatar
13 Apr 2026 10:31
Replied by grandixximo on topic Ethercat random jitter fix
Category: EtherCAT
sorry, I got messed up, should test the ethercat upload commands with
If you could also do some more testing, I'd really like to get to the bottom of this
also with refClockSyncCycles="-1" (don't move just start)
Check pll_reset_cnt, does it increment every ~1/sec?
Also could you move the first servo drive as the first slave, and try with refClockSyncCycles="-1"?
  • papagno-source
  • papagno-source
13 Apr 2026 10:19
Category: EtherCAT
I only tested refClockSyncCycles="1" without writing syncToRefClock, and the machine worked flawlessly.
The lcec.0.pll-err pin in this case reported a value oscillating from approximately 991902 to 994498.
The rest remained the same:
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
The result is :
ethercat upload -p 0 -t uint32 0x1C32 0x06 return Failed to upload SDO: Input/output error
ethercat upload -p 0 -t uint32 0x1C33 0x06 return Failed to upload SDO: Input/output error
ethercat upload -p 0 -t uint32 0x1C33 0x03 return SDO transfer aborted with code 0x06010000: Unsupported access to an object
  • grandixximo
13 Apr 2026 09:58 - 13 Apr 2026 10:03
Category: EtherCAT
then it should also work with
just the above don't add
syncToRefClock="false" or syncToRefClock="true"
your assumption is correct in the case you are testing.
will force syncToRefClock="true" because that is expected to respect old behavior
so your problem is PLL is causing the vibrations
Please run my commands again with only
then run
  • grandixximo
13 Apr 2026 09:40
Category: EtherCAT
syncToRefClock is false by default, your assumption is incorrect, are you sure you have built my repo's code?
  • papagno-source
  • papagno-source
13 Apr 2026 09:37
Category: EtherCAT
Yes machine work only with refClockSyncCycles="-1" syncToRefClock="false"
  • papagno-source
  • papagno-source
13 Apr 2026 09:35 - 13 Apr 2026 09:41
Category: EtherCAT
Initially, everything seemed to be working fine, because I was testing a system with smaller motors, always from the same manufacturer, not connected to the mechanics. I noticed the problem when I started moving the axes on a real machine. Here's my experience:
-First of all, on Debian 10 with EtherCAT 1.5.2, I never used the :syncToRefClock parameter, only refClockSyncCycles.
-On a real machine with an ASD2 Delta drive, with the first I/O node being the same, if I set the refClockSyncCycles parameter to -1, the axes shook at the first movement.
If I set the refClockSyncCycles parameter to 1, the machine worked 99.9% of the time; only very rarely was I forced to reboot the system because the axes made noise the first time they were restarted.
Still on Debian 10 with ethercat 1.5.2, with the same I/O node, with a Veichy drive, the refClockSyncCycles=1 parameter causes the axes to shake. I had to set refClockSyncCycles=-1 to work without problems.
Debian Trixie ethercat 1.6.9, Veichy drive machine. I initially set the Debian 10 xml file, so with only refClockSyncCycles=-1, the machine makes noise.
I then modified the xml with refClockSyncCycles=-1 and syncToRefClock="false" and now the machine works correctly.
I haven't been able to test Debian Trixie with the ASD2 drive, but I think at this point it will behave the same as Debian 10, namely:
refClockSyncCycles=1 and syncToRefClock="false"
I therefore assume that the syncToRefClock="true" parameter is set by default if not added to the XML file.
  • grandixximo
13 Apr 2026 09:33
Category: EtherCAT
Are you saying that the only way it works is this
  • papagno-source
  • papagno-source
13 Apr 2026 09:22
Category: EtherCAT
the result is :
I've already tested only refClockSyncCycles="-1" without syncToRefClock="true" and the problem persists.
I've also tested refClockSyncCycles="1" and syncToRefClock="true"
Do you want me to try deleting refClockSyncCycles="1" and leaving only syncToRefClock="true"?
  • rodw
  • rodw's Avatar
13 Apr 2026 08:47
Replied by rodw on topic Probleme mit G Code...
Sometimes you do not have enough room for the tool outside of the machine limits.
Install home switches, set the tool centered above the part and set your G54 offsets and it will likely work fine.
the radius error is related to your gcode. Sometimes from running absolute instead of incremental  arcs or vice versa,
  • rodw
  • rodw's Avatar
13 Apr 2026 08:37
Replied by rodw on topic Ethercat random jitter fix
Category: EtherCAT
  • Hakan
  • Hakan
13 Apr 2026 07:59
Category: EtherCAT
I have looked in the code but don't see why it does what it does.
It is supposed to work like this
When the syncToRefClock option is given the "-" is ignored, "true" means to switch on, any other string means to not activate the pll code.
In lack of the syncToRefClock option, the "-" will switch on the pll code.
Your code doesn't react in that way.
  • grandixximo
13 Apr 2026 07:57 - 13 Apr 2026 08:27
Category: EtherCAT
Hakan is correct, but depends on device, we should check what they report.
could you run these?
Edit: also these please
Run these and write here the output, to confirm if sync0shift 0 is supported
Also
is self contradictory
use only
or only
to enable PLL
  • rodw
  • rodw's Avatar
13 Apr 2026 07:42
Replied by rodw on topic HAL component for tangential knife
Category: HAL
Just be patient, I started from scratch today and got the framework working but some of the data is  incorrect.
In the mean time, learn how to build linuxcnc as a RUN IN PLACE version for testing
When I get a bit further, you will be able to clone my git repository and test it for me.
Displaying 3046 - 3060 out of 13996 results.
Time to create page: 0.214 seconds
