  • oldmanzwing
  • oldmanzwing
27 Mar 2026 15:50
Replied by oldmanzwing on topic Ethercat boards and hardware
Category: Driver Boards
Thank you for the tip.
i currently just setting up a lab/Prototyping so don't need thing to work flawlessly just enough to test things, so trying to get away cheaply witch seems a bit hard with ethercat.
so mainly IO board that you could output LinuxCNC stepper signals out of would be ideal but it seems really hard to find at least when it comes to Ethercat, if i was more versed in electronics i would probably try and develop my own Ethercat board and open source it for other experimenters.
  • grossm5000
  • grossm5000
27 Mar 2026 14:59 - 27 Mar 2026 15:05
Replied by grossm5000 on topic Differential encoder hard crashes the PC MESA7i77
HEY! I am so dumb I didn't see your reply till just now. I actually bought another 6i25 convinced I had an issue with the card.
ANYWAY...I don't get any errors when I launch LinuxCNC, just a hard, full computer shutdown if the 7i77 is connected to the 6i25. If the 6i25 is NOT connected to the 7i77, I just get the Linuxcnc error i posted earlier.
So...I put in the NEW 6i25 just now, hooked up the 7i77 and launched Linuxcnc...and it DIDNT CRASH this time! Exciting. Now i just get a new Linuxcnc error:
Looks like the firmware wants an update? Do I do this with mesaflash?
  • Spezidrohne
  • Spezidrohne
27 Mar 2026 14:43
Replied by Spezidrohne on topic Ethercat Setup help needed for beginner
Category: EtherCAT
So i just take those files and copy them in the folder of my machine?
  • Hakan
  • Hakan
27 Mar 2026 14:03 - 27 Mar 2026 14:05
Review Request for Arc Volt Sensor Schematic
Category: Plasma & Laser
In what way do you see 2x50k as a better way than 1x100k?
You get voltages in the 50-60V range to THCAD.
With one 100k, and recognize that ground is really close to ground on the 5V rail,
you only get a few volts in after the voltage divider.
I thought about that on my card.
Only what is in red has 100V (well, -100V) and thereabout, the rest is 5V max.
I made some distance between torch voltage and copper as you can see in the read.
I always excuse myself by saying I am not an electric engineer, so I can be wrong.
Regarding filter, I have a digital lowpass filter with 10 Hz pole frequency in the controller. No hardware filter.
Linuxcnc has a "lowpass" hal filter component so it can be done there also.
I used the Herocut equivalent to the Lotos. Worked fine.I live in a place where we only can have 16A, absolutely max 20A, 230V at home.
I couldn't use all the 55A, the fuse blew all the time. I replaced it with a Herocut HC8000, three phase 400V 16A. I can now max out
the plasma cutter. But the compressor need to run off the petrol generator, it's too much with that one on one phase too.
27 Mar 2026 13:08
Replied by tommylight on topic Review Request for Arc Volt Sensor Schematic
Edited previous post to reflect resistor values, as the drawing is just a wiring example .
  • Todd Zuercher
  • Todd Zuercher's Avatar
27 Mar 2026 13:06 - 27 Mar 2026 13:12
Replied by Todd Zuercher on topic Updating Old GladeVCP Files?
Category: GladeVCP
I'm starting to get pissed off. This stupid Gladevcp just does not seem to want to cooperate. My two sets of radio buttons are just being stupid. There are 2 pairs with each button triggering a hal action MDI widget. Each of the Hal Action MDIs call either a small sub program or a custom M-code. A set for the left side and a right side and both are exhibiting the same behavior. I have the left unclamp radio button as the master in the left group. Pressing the left_clamp button works correctly and runs it's sub program activate the left side clamps in a sequence. I have the unclamp buttons call for a single custom M-code that releases all of the clamps at once. But when I press the unclamp button, it runs the clamp sequence, then unclamps. If I press the unclamp button(s) while the vcp screen already indicates that the radio button is in the unclamped state, then it behaves properly and only issues the unlcamp M-code.
My second problem, I also have a set of physical buttons on the other side of the machine that use Halui MDI commands to call the same sub programs and custom M-codes to clamp and unclamp. Those are working perfectly by themselves. I created some hal pins in the python call back that toggle each of the VCP radio buttons, so the screen can match and indicate the state of the clamps. If I disable eache the button's "Related Action" in glade, that all works perfectly. Pressing the clamp/unclamp buttons change the toggled buttons on the VCP like I'd like them to. But then the VCP buttons don't actually do anything. With the button's Related Actions turned on, it set up a loop, where when one of physical the buttons are pressed, the clamps start cycling on, off, on, off... continually. Well that's no good at all, but not surprising.
Any clues atll how to fix the first problem. So far everything I've tried either has no effect or stops the GladeVCP buttons from working.
I think I could work around the 2nd problem if I could fix the 1st one. I'd have the physical buttons simply trigger the glade buttons instead of calling the halui MDI commands. The other way would be to make the call back file change the active button on the VCP without activating the buttons action, but still let the button action work when pressed on the screen. But I don't know how to do that.
  • alangibson
  • alangibson
27 Mar 2026 13:03 - 27 Mar 2026 13:03
Replied by alangibson on topic Review Request for Arc Volt Sensor Schematic
tommylight  Really interesting. Thanks.
  • alangibson
  • alangibson
27 Mar 2026 13:02 - 27 Mar 2026 13:02
I've added the SPI isolation. The whole thing is now fully isolated.
27 Mar 2026 13:01 - 27 Mar 2026 13:06
edit:
The values are placeholders, i usually use 2x470K to 2x1M for the side resistors and adjust the value for the middle one depending on what i can find.
  • alangibson
  • alangibson
27 Mar 2026 13:00
I use the filter for a couple of reasons:
1. environmental noise
2. I don't trust cheap plasma cutters to output clean DC
I see a couple of capacitors and resistors as cheap insurance against potential future problems.
I want to be able to confidently support cheaper options like Lotos LTP5500CNC. That's the one I have. It works fine and is a small fraction the price of a Hypertherm.
I actually looked at supporting HF start machines in the past. I just couldn't justify the cost and effort.
  • JT
  • JT's Avatar
27 Mar 2026 09:58
Replied by JT on topic Flex GUI Keyboard Jogging
Category: Flex GUI
Anything is possible, I just need to think about the best way to implement that.
Just about finished a massive update on control enable/disable so the dust needs to settle a bit on that.
JT
  • Pierangelo
  • Pierangelo
27 Mar 2026 08:22
4-Axis RP5 with Bigtreetech Octopus Pro- How to make axis indipendent
Luca
Thank you for your response.
I have eventually managed to make it work.
It looks like the Octopus Pro board has Motor3 and Motor4 running in parallel.
I have used Motor0,1,3 and 5, defined XY;UV axis and it works.
Now I have 4 independent linear axis.
  • Hakan
  • Hakan
27 Mar 2026 08:15
I also wonder about the 2 50k resistors.
Good find on the regulated TMR-0511.
I looked at the output of the isolated power supply I use. I wasn't terrible, almost ok but not totally stable.
Why the filter step? HF?
  • Hakan
  • Hakan
27 Mar 2026 07:28
Replied by Hakan on topic Ethercat Setup help needed for beginner
Category: EtherCAT
Basically what you do is replace the motion part of the sim config with the ethercat motion.
Here is an example I often refer to. You do need the cia402 component as well.
github.com/dbraun1981/hal-cia402/tree/main/example
  • Yannis
  • Yannis
27 Mar 2026 07:07
Replied by Yannis on topic W axis machine config
The signals looks ok
Also on the WATCH tablet the virtual led for e-stop and machine enable are working fine
Displaying 3676 - 3690 out of 14012 results.
Time to create page: 0.976 seconds
