  • phino
  • phino
13 Mar 2026 03:15
Laser Head Height Sensor – Looking for a Beta Tester
Category: Plasma & Laser
Is there stock available for purchase of the height sensor?
A couple of days ago, I saw 1 in stock, but when attempting to purchase, it said out of stock.
  • NWE
  • NWE's Avatar
13 Mar 2026 03:10
Epoxied electronics sure are hard to extract. I have had some success using a small butane torch or a heat gun to soften the epoxy with heat. Some kinds of epoxy turn rubbery an can be carved out in small bits with a knife while it is hot. But that is messy. It is too easy to burn it up or start a fire. Plus I end up with blisters on my fingers from working with the hot stuff.
Take care and have fun!
  • NWE
  • NWE's Avatar
13 Mar 2026 03:01
Replied by NWE on topic Trying out LinuxCNC on Raspberry PI5
but normal need use WHITOUT this expensive hat , only gpio pin out and shift level converter can use 3,3V gpio pin to out 5V and traight to driver step and dir and enable pin.
how this made if ewer newer not has understand anything code nd not understand what need doing code, understand only good all hardware how connect and build,
i have rpi4 and SD card have linuxcnc rpi4 image, working and boot ok, (whit HDMI display) but not boot whit pi hut mikro HDMI to vga cable.
how make this gpio pins can take out gpio pin to driver DM556. were can download setting hal and ini file or what need add to rpi4, normal peoples NOT can understand and write hard code to rpi, hal or ini or what possiple need doing, not know.
i just buy rpi4, paraller port BOB, cheap chinese 10$ board, encoder, rotary SW, shift level converter modules, 3,3V to 5V, all buttons, DM556 drivers, nema 23 470 OZ/3Nm motors, lot hardware but not can made code anything.
help need send to me files what need copy and paste to rpi4 linuxcnc and were folder need add. not know were and what and how.
I have not tried connecting a BOB to a Raspberry pi. I think it could work but it will not be easy. You will have to write the hal and ini files.
How will you connect BOB to the Raspberry pi? The connectors are quite different.
If you could use your BOB connected to a pc that has a parallel port that will be a lot easier. I might be able to help. Then you could use stepconf to create your configuration.
  • rodw
  • rodw's Avatar
13 Mar 2026 02:51
Replied by rodw on topic ARE YOU KIDDING ME YOUTUBE !!!
Youtube isn't all bad. As a newly minted but not yet monetized Youtube Partner, I got an email from them today reminding me of the copyright match tool I was now allowed to use. So I turned it on in YT studio and low and behold there was a match where somebody made a video using 90% of my content. A video of my Spaceship Plasma cutting a part (well lots of parts). They had been selling off my video for  four years!
I decided to play nice and asked YT to serve them a 7 day take down notice, instead of an immediate takedown.
Last time I had something similar was a large company using my registered trademark running Google ads for my product! That time I had to pay a specialist IP lawyer to issue a takedown request which cost me quite a few $ and Youtube is doing it for free!.
  • RobbieG
  • RobbieG
13 Mar 2026 02:23
current latest download of LinuxCNC V2.9.8 will not install GRUB on several PC's
Category: Installing LinuxCNC
Hello,
I had a similar issue where I had to skip the grub boot installer step.
I found a solution is to install like normal and skip that step, then launch the usb boot drive live. From there, I had to mount the efi drive partition (/dev/sda1 I think it was). Then I went and renamed the Debian directory in EFI to boot and the grubx64.efi file to bootx64.efi and then everything booted fine.
I was doing this on an old Mac so it could have been a little different.
  • rodw
  • rodw's Avatar
13 Mar 2026 01:54
Its not possible to install Debian without an internet connection (hardwired is best) The Linuxcnc installer depends on internet (It uses the Debian Live INstaller). Try offline at your own risk
  • PCW
  • PCW's Avatar
13 Mar 2026 00:52
Replied by PCW on topic pin locations
pin locations
What pins do you mean?
If you run:
mesaflash --device 7i96s --addr 10.10.10.10 --readhmid
it will print the 7I96S's function (stepgen, pwmgen, encoder, etc)
terminal block pin numbers.
(replace the 10.10.10.10 with 192.168.1.121 if the 7I96S is jumpered that way)
  • PCW
  • PCW's Avatar
12 Mar 2026 21:08 - 12 Mar 2026 21:19
Replied by PCW on topic Retrofitting Deckel FP4ATC
Category: Milling Machines
Just checked 7i97t_7i74d.bin
md5sum=
4130ebee623115267327c166f8da9d39  7i97t_7i74d.bin
All encoders work, 7I97 sserial (0) and all 7I74 sserial channels (1..7) work as expected
  • Mbrand1901
  • Mbrand1901
12 Mar 2026 20:15
Replied by Mbrand1901 on topic Retrofitting Deckel FP4ATC
I have only used firmwares from the Website. I also know that i only need a 7i97t with 7i74 firmeware. In the file there are a few firmwares with the 7i97t_7i74 Name. So the 7i97t_7i74d.bin is the right now?
Tomorow i will look further in to it.
And why the encoders arent counting.
  • natas01
  • natas01
12 Mar 2026 20:01
pin locations was created by natas01
pin locations
might be a dumb question I have a 7i96s how how do you no where PIN numbers locations. I'm in the pnccofig it says pin # xx  but where is it on the board ?
  • Xnke
  • Xnke
12 Mar 2026 19:57
This is the plan. Keep in mind, all who follow, that if you finish the installation completely offline-no internet access-your Debian package sources files will be empty. You will have to create the .sources file, or when you do sudo apt install you will get "could not find" and when you do sudo apt unpdate it will run through the updates and say there is nothing to update.
  • TAKUYA
  • TAKUYA
12 Mar 2026 19:27 - 12 Mar 2026 19:33
Replied by TAKUYA on topic Ethercat random jitter fix
Category: EtherCAT
So pll-error remains 0 for me. App phase hovering between 9800 and 10500
What i did notice, i had all 3 axis vibrate like crazy upon first Launch today. Rebooting lcnc fixed that.
Edit: did another power cycle. No Vibration but sudden clunking on all 3 axis again
  • Todd Zuercher
  • Todd Zuercher's Avatar
12 Mar 2026 18:36
Replied by Todd Zuercher on topic Connect Siggen to Stepgen?
I think I overlooked the control type (because its in the pin list rather than a parameter.)
  • Todd Zuercher
12 Mar 2026 18:33
I'm not sure if I set the control mode to 1. I'll have to check that. I thought I had most of the settings the same as the stepgens that were in use, and those are commanded by velocity command from the PID.
  • endian
  • endian's Avatar
12 Mar 2026 18:00
Replied by endian on topic LinuxCNC S-Curve Accelerations
Hello,
I can see merge of your progress to master? Am I right ?
Regards e.
Displaying 4261 - 4275 out of 14024 results.
Time to create page: 0.459 seconds
