  • angelnu
  • angelnu
06 Oct 2026 11:23
Replied by angelnu on topic mesa 7i97T + 7i84U
mesa 7i97T + 7i84U
Category: Driver Boards
Thanks for responding.
Cables 14, 15 and 16 are used in the machine.
I wasn't planning to touch the cables between the driver and the encoder, they have 16 or 17 cables.
  • viesturs.lacis
  • viesturs.lacis
06 Oct 2026 10:28 - 06 Oct 2026 10:30
Replied by viesturs.lacis on topic Help with Modbus needed
yes, hal pins need to be connected but reading/sending values over modbus come before that. got that working and then also hal pins went quickly and easy
just a little detail in case somebody else will encounter this in the future:
Correct value of "First element" for first register is 0, thanks to Ralph Stirling for sharing a working config.
Attached is working ini and hal files for mb2hal and Invertek Optidrive E3
05 Oct 2026 16:19
New LinuxCNC Multi-Channel System – Looking for Testers & Feedback
Category: Show Your Stuff
I have to agree with Todd, such machine is much more versatile with two separate controls.
A nice local network with a NAS would also add a lot to functionality and ease of use.
  • Todd Zuercher
  • Todd Zuercher's Avatar
05 Oct 2026 14:11
At one point in the past I was getting quotes for buying a double router like that. In the end our company decided it was more cost effective and practical to simply buy two separate machines.
  • hermann1976
  • hermann1976's Avatar
05 Oct 2026 14:00
tommylight post=350129 Benutzer-ID=17274
hermann1976 post=350128 userid=26821
Es ermöglicht die erfolgreiche Nachrüstung älterer Maschinen —z. B. kompletter Homag-Holzbearbeitungszentren mit mehreren Tischzonen— unter Verwendung von LinuxCNC.
Ich bin mir ziemlich sicher, dass dies bereits möglich ist, siehe G55, G56 usw.
I am indeed referring to a multi-channel control system.
The machine works on a component on the left machining table, while the next part can be set up on the right table simultaneously. Once setup is complete, the program is started and the table moves to a standby position. Only when the left-hand part is finished does the machining head move to the right to execute that program. At the same time, the left table moves out of the machining area to a parking position for re-setup.
There are also multi-head systems, and so on.
  • Todd Zuercher
05 Oct 2026 13:55
Replied by Todd Zuercher on topic Looking for an older CNC mill to refurbish/retrofit
We have all flavors of Amish here. From ones like you describe to Swartzentruber Amish that will only use a couple kerosene lanterns on their buggies (they won't even use a smv triangle.) The ones like you describe may have a 50kw (or bigger) genset for their wood shop to run big CNC routers and other wood working equipment, but those wires run to the English city; das ist veboten.
  • retrofitcenter
  • retrofitcenter
05 Oct 2026 13:30
Servus, thanks for your message, nice to meet another Austrian here!
I’m originally from the Amstetten area, but Salzburg is also home for me. I went to HTL in Steyr, and I’ve been self-employed for around 20 years, mainly working in the aerospace and automotive industries.
My background is primarily in PLC programming, CNC machining and industrial automation. Over the years I’ve worked on pretty much everything around metalworking: mechanical engineering, machine automation, fixtures and clamping systems, CNC programming, commissioning, and of course complete machine retrofits.
I also started working with LinuxCNC very early on and was one of the first to use it seriously for machining centers rather than just simpler hobby machines. That experience is actually one of the reasons why I’m now pushing the multi-channel system further, I see a lot of potential for bringing older but mechanically excellent industrial machines back to life.
Your Homag example is interesting as well. Multi-channel control could definitely open up a lot of possibilities for machines with several working areas, tables or independently coordinated processes.
  • Murphy
  • Murphy
05 Oct 2026 12:50 - 06 Oct 2026 00:46
Has anybody got G95 working with their remora setups??
iv got it working by setting lowpass-spindle-encoder-velocity.gain to true.
But how do I permanently set it to true. I tried setp in .Hal but it's getting overwritten every time I restart linuxcnc
  • trackwhack
  • trackwhack
05 Oct 2026 12:34
Replied by trackwhack on topic Perpetual License CAM
I understand, in that case you can delete it. If some customer posts a question in future in a different thread, I will reply, but no more promotion and I'm also grateful for the opportunity the forum provided. We really wish we could go open source. We will at least make some of the larger suite of products open source. Our target is to make engineering software of all kind extremely affordable.
05 Oct 2026 12:33
Replied by tommylight on topic Perpetual License CAM
Do not delete your replies, that is really, really not polite.
If you do need to edit it, leave the original content, unless it poses a risk/danger, and add the corrections/additions/etc.
05 Oct 2026 12:30
Not important, it just does not belong here, only Open Source stuff does.
I allowed it at my own risk, to help you till you set up your own website and forum.
I have yet to figure out if it would be OK to present it in the "CAD/CAM" section after your site is up and running. Either way, support must be on your side, not on ours.
  • spumco
  • spumco
05 Oct 2026 12:24
I'm also NE Ohio (Wayne Co.) and I didn't think most of the farmers right around me had 3ph. But maybe that has more to do with the fact I'm on the edge of Amish country.
They got the 0ph power.
I'm in Ashtabula, and our Amish have F350's, $10k kick-scooters, and 3 phase power that seems to be disconnected only when the Elders are around.
  • PCW
  • PCW's Avatar
05 Oct 2026 12:24
Replied by PCW on topic mesa 7i97T + 7i84U
mesa 7i97T + 7i84U
You can connect single ended NPN encoder outputs to the 7I97T
Worst case you might need a stiffer pullup resistor on the inputs
than the built in 2K ohm encoder input pullups on the 7I97T
A 7I84U (32 inputs 16 outputs)  or a 7I70 (48 inputs) can be used to expand the inputs on a 7I97T
05 Oct 2026 12:23
Replied by tommylight on topic mesa 7i97T + 7i84U
mesa 7i97T + 7i84U
I just wrote half a page and had to delete and start over:
-Use pins 14, 15, 16 on C2
-Set mesa for single ended encoders
-do not touch the wiring between drives and motors.
  • angelnu
  • angelnu
05 Oct 2026 11:59
mesa 7i97T + 7i84U was created by angelnu
mesa 7i97T + 7i84U
Hello.I have a cnc sharpener with motors and Italian analog servo drivers -10V Phase AX-V 06094. I want to upgrade to linuxcnc since the controller is an old PROMAX system that has an old SD card reader, it does not support modern sc cards. Some cards I have have errors and there are no spare parts. I think the phase drives are connected to SINCOS encoders, the driver has encoder outputs Ch A, Ch. B and Ch. C (Ch C seems to be index) the outputs are NPN open collector 30 V, 100 mA. Is it possible to connect these drivers to a 7i97T table card?, and also advice to expand the inputs since the 7i97T only has 16, I had thought about a 7i84U card.
Sorry if it's not right in English, my language is Spanish.
Displaying 541 - 555 out of 11363 results.
Time to create page: 0.278 seconds
