  • suraj9735
  • suraj9735's Avatar
05 Feb 2026 21:14
How to do wiring to generate quadrature encoder signal in Mesa 7i95 board
Category: Driver Boards
Hi PCW,
The filter is already by default set to true. Suggest any other troubleshoot method for the same.
Or suggest me a daughter board having analog input output pin
  • Hakan
  • Hakan
05 Feb 2026 21:06
Stepperonline Y series/ YAKO YKD2608PE configuration
Category: EtherCAT
Progress!
You forgot the two first lines from that example cia402.hal
loadrt [KINS]KINEMATICS
  • Salrodri
  • Salrodri
05 Feb 2026 20:28
7i95t firmware brick because i flashed a 7i95 bitfile in the fallback
My head is still spinning from all the trouble I went through to revive this board.
Looking back now, I can say it was relatively easy—I just had to learn a lot in a short amount of time.
Thank you for your patience and support.
I truly can’t thank you enough.
  • IndeeSales
  • IndeeSales's Avatar
05 Feb 2026 20:24
Category: EtherCAT
Okay so i commented out the 2 1014's then 2 2004 now i get a servo thread not found so i attached all files and the log again
File Name: ethercat-c...2-05.xml
File Size:5 KB
File Name: linuxcnc_2...2-05.txt
File Size:5 KB
File Name: Ethercat_2...2-05.hal
File Size:5 KB
  • rodw
  • rodw's Avatar
05 Feb 2026 20:06
Replied by rodw on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
Its definitely a performance parameter for this drive. Maybe it isn't on their matched motors. NWE can confirm on his mother's eventually.
But you have given me a thought. If I changed parameters that I expected to get max velocity from 2000 m/m to 20000 mm/min and only got 8500 mm/min, I should be able to increase the step count from 1000 now without loosing performance.
Another thought I had which we can't do on this drive is on those machines with a torque reduction pdo, we could replicate what my step boost component does which is to reduce the torque (well curent in that case) when the motor is not accellerating to allow the motor to cool when not working hard. I used 50% current reduction but the maths indicates you can go a lot lower perhaps as low as 10-15%) This gives a massive performance improvement
  • Finngineering
  • Finngineering
05 Feb 2026 19:58
Replied by Finngineering on topic XHC WHB04B development?
Okay, cool. Let us know if you try it out. Maybe you could check if its the same for you as for me when trying to jog while running gcode prior to updating the xhc-whb04b-6 component. The pendant always disconnects in that situation for me.
05 Feb 2026 19:52
Category: EtherCAT
yes I dont know what keeps happening I have registered 3 times in 72hrs.
Yes, i have noticed that, hence my question, but i think you should be clear from now on, based on what i gather this happens when there is a single post from a member in a certain timeframe and might be due to automation set to disable spammer accounts.
  • PCW
  • PCW's Avatar
05 Feb 2026 19:35 - 05 Feb 2026 21:03
Replied by PCW on topic Mesa 7i96S bad start
_usually_ CR343 will protect the rest of the card from overvoltages
CR43 is (or was) a SMBJ5V0 TVS diode across the 5V supply
  • PCW
  • PCW's Avatar
05 Feb 2026 19:33
You need to install a user configuration (the fallback configuration has no modules except GPIO):
mesaflash --device 7i95t --addr 192.168.1.121 --write  7i95t_d.bin
(7i95t_d.bin  is from the 7i95t.zip file in configs/hostmot2)
Once this is done, you can set the IP select jumpers to DOWN,DOWN (192.168.1.121)
or DOWN,UP (10.10.10.10)
  • Salrodri
  • Salrodri
05 Feb 2026 19:23
I remember you mention something about the dpll?
I was trying to create a machine to test the borad
Debug file information:
Note: Using POSIX realtime
./main.hal:37: parameter or pin 'hm2_7i95.0.dpll.01.timer-us' not found
22938
Stopping realtime threads
Unloading hal components
  • Hakan
  • Hakan
05 Feb 2026 19:22
Replied by Hakan on topic XHC WHB04B development?
The computer screen, with the g-code trace.
I have some user macro buttons, they are on the screen in Man but are removed in Auto and the trace window is resized.
I agree with the too long blocking diagnose, sounds exactly like the problem.
I'll try that tomorrow, it would be great to get a fix.
  • Finngineering
  • Finngineering
05 Feb 2026 19:14
Do you means when the computer screen re-organizes? Or the pendant screen?
I found that if I try to jog when a g-code program is running, the pendant will disconnect every time. The reason is too long blocking (like I mentioned in the first post) without USB polling. The pendant will request manual/teleop mode (I don't recall which) and wait for minimum 300 ms if the mode does not change. It's these two functions:
github.com/LinuxCNC/linuxcnc/blob/master...6/hal.cc#L1361-L1420
I solved this issue by reducing the "loops" parameters here:
github.com/LinuxCNC/linuxcnc/blob/master...b04b-6/hal.h#L71-L86
Maybe your issue could be because of the same reason?
Still, if I use the mill for an hour or so, the pendant is likely to disconnect. And I have not found any specific reason for that yet.
  • Hakan
  • Hakan
05 Feb 2026 19:10 - 05 Feb 2026 19:10
Category: EtherCAT
There it is.
The problem is with your slave 5, the EL1014.
Can it be that it is a very old version? They had a different PDO mapping.
Can you temporarily remove or comment out slave idx=5 and see if you
come any further?
We can come back to how to fix it for the EL1014.
Well, it is to run lcec_configgen with the option, "lcec_configgen --typedb=false"
and then take the info for slave 5 from that output.
  • Becksvill
  • Becksvill
05 Feb 2026 19:09
Replied by Becksvill on topic LinuxCNC S-Curve Accelerations
that's awesome great progress.
quick question
have you caught up with Rob from tormach yet about including any of their work from the 1500mx machines
  • Juxus
  • Juxus
05 Feb 2026 19:08 - 05 Feb 2026 19:11
Mesa 7i96S bad start was created by Juxus
Hi everyone,
I just started my first LinuxCNC project and unfortunately managed to damage my Mesa 7i96S right away. I accidentally applied about 10 V to the 5 V input for a few seconds. There was a little smoke, and now the board draws about 3 A at 5 V even with no external load connected.
Using a thermal camera, I identified a hot SMD component marked “KE 2E66B” located very close to the 5 V input connector (designator CR43 on the PCB). It heats up immediately when power is applied. Measuring across it shows about 0.6 ohm. From the package and marking it looks like it could be a polarized SMD capacitor (possibly tantalum), but I can’t determine the value or rating.
Can anyone tell me the specifications of this component, or point me to the correct replacement part? Is there a BOM or schematic available that lists its value?
Thanks a lot for your help.
Displaying 5836 - 5850 out of 14030 results.
Time to create page: 3.504 seconds
