  • Troff
  • Troff
30 Jan 2026 09:55 - 30 Jan 2026 10:40
OMRON Yaskawa controllers, what I/O board would you choose
Category: Driver Boards
Newbie here! Be gentle :-)
I have recently acquired a bunch of Omron Yaskawa servos and SGDH drives from a running machine.
Read the LinuxCNC documentation a while ago planning for a CNC setup for my minor lathe.
Searched the forum for experience with the Omron Yaskawa SGDH controllers. One guy doing mesa to control the SGDH.
First of all i would like to do x-y axis operations to do threads etc. Long term perspective i would like to do 3 axis machining, making the spindle A-axis servo controlled - and mounting a spindle on the x-y axis.
I have not settled on a PC platform yet. But concidering making it simple and cheap as a start. And I can upgrade if i find myself in a situation where it is meaningful to throw more money at the platform.
Questions:
1. What are my simple I/O options, a RPI5 and a basic I/O card, a BeagleBone with a cape ? Any recommendations ?
2. If i later on do the A axis i plan on installing the Sevo drive with a gearing that will get up to max 600rpm. . It is a small hobby lathe and  currently is has a 700W motor. Anyone with experience running servo on an A-axis - the servo motor i have is a 1200W type?
Hope this is meaningful, if not let me know and i will try to elaborate.
Thanks in advance!
  • endian
  • endian's Avatar
30 Jan 2026 08:41 - 30 Jan 2026 08:44
Replied by endian on topic LinuxCNC S-Curve Accelerations
there is added filtering and influence of real active ferror from feedback but I am not using it because it creating frequencies ...
  • endian
  • endian's Avatar
30 Jan 2026 08:40 - 30 Jan 2026 08:50
Very good stuff! I made a start today forum.linuxcnc.org/ethercat/58260-lichua...r-need-help?start=20
is dt = Delta time = servo period?
I'll have to follow you guys a bit more closely!
yes interpolation servo period.. Rod please check this repo  codeberg.org/endian/Beckhoff_AX5ZYZZ_lcec_driver here it is solved at all ... there is a .hal file example and everything needed
  • rodw
  • rodw's Avatar
30 Jan 2026 08:27
Replied by rodw on topic LinuxCNC S-Curve Accelerations
  • Unlogic
  • Unlogic
30 Jan 2026 08:10
Replied by Unlogic on topic Optimum Optimill MH50V CNC conversion
Category: Milling Machines
There hasn't been any updates to this thread for a while. But the machine has worked great this autumn and I've created some nice billet aluminum car parts.
However it's finally timed for a much awaited spindle upgrade. I bought this 8000 rpm, liquid cooled BT40 spindle from FUKA/Swift. It seems like a very nice unit but it's gonna be a while before I can test it as I now need to design and manufacture a new head for the milling machine along with a much larger pneumatic tool release cylinder.
  • grandixximo
  • grandixximo's Avatar
30 Jan 2026 07:57
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
0x60B1 (velocity feedforward) can use joint.N.vel-cmd directly - is equal of FF1 of PID which already exist and its widely used to compensaty cycle delay ... this stuff is from my point of view useless for now
but I am still taking just about pin which allready read position from allredy presented 50ms buffer .. you are providing us from sTP posCmd(t), velCmd(t) (command speed is compensated cycle with PID FF1 and we do no use 60B1 for now), accCmd(t) and jerkCmd(t) and we need for ethercat posExtraCmd(t+2) for ethercat devices which is running in Constant Synchronized Position mode because of absention PID and therefore FF1 absention too (2 cycle lag present of ethercat) - this is just array position value which allready exist in buffer because of time(you notice 50ms) precalculation ...
and I know this is topic connected with ethercat but it is directly connected to trajectory planner ... Beckhoff, Codesys, Deltaww it has implemented as I said because their native bus is ethercat ...
 The lookahead buffer stores velocities and segment data, not pre-calculated positions. Positions are computed at RT execution time through interpolation based on progress values that depend on velocity integration each cycle. The future position you want doesn't exist in a buffer waiting to be exposed.Your HAL component using
vel_cmd * dt + 0.5 * acc_cmd * dt²
is actually the correct approach given the architecture. It's not a workaround, it's the right way to predict future position from the data that exists.The TP gives you accurate vel-cmd and acc-cmd every cycle. With S-curve planning these will be even smoother and more predictable than with trapezoidal, so your compensation should work better not worse.
  • Aciera
  • Aciera's Avatar
30 Jan 2026 07:41
Replied by Aciera on topic Strange preview for circular arc (G2/G3)
Category: G&M Codes
Seems to work for me, but maybe you could provide a complete gcode example:
  • rodw
  • rodw's Avatar
30 Jan 2026 07:26 - 30 Jan 2026 07:26
Replied by rodw on topic Lichuan 4 axis stepper need help-
Category: EtherCAT
Ooops no attachment
File Name: pins_2026-01-30-2.txt
File Size:2 KB
  • rodw
  • rodw's Avatar
30 Jan 2026 07:24
Category: EtherCAT
Well, I made a start and at least have some pins displaying (see attached text file). Still so much to do after a full day on this!
Not sure if this is final but the states should look like
// CiA 402 states
typedef enum {
    STATE_NOT_READY_TO_SWITCH_ON,
    STATE_SWITCH_ON_INHIBITED,
    STATE_READY_TO_SWITCH_ON,
    STATE_SWITCHED_ON,
    STATE_OPERATION_ENABLED,
    STATE_QUICK_STOP_ACTIVE,
    STATE_FAULT_REACTION_ACTIVE,
    STATE_FAULT,
    STATE_HOMING
} DriveState;
I need to make sure everything is seperated into readall and writeall functions.
We rtapi_malloc structured data storage when we loadrt so I hope that will work.
The statusword structure looks something like this so the bit fields are mapped overthe status word
// CiA 402 Statusword union
typedef union {
    hal_u32_t raw;
    struct
        unsigned char ready_to_switch_on      :1; // 0
        unsigned char switched_on             :1; // 1
        unsigned char operation_enabled       :1; // 2
        unsigned char faulted                 :1; // 3
        unsigned char voltage_enabled         :1; // 4
        unsigned char quick_stop              :1; // 5
        unsigned char switch_on_inhibited     :1; // 6
        unsigned char warning                 :1; // 7
        unsigned char manufacturer_specific1  :1; // 8
        unsigned char remote_cmd              :1; // 9
        unsigned char target_reached          :1; // 10
        unsigned char internal_limit_active   :1; // 11
        unsigned char  opmode_specific1       :1; // 12 (homing attained / target reached)
        unsigned char  opmode_specific2       :1; // 13 (homing error)
        unsigned char  manufacturer_specific2 :2; // 14-15
    } bits;
} StatusWord;
When I get a bit further, I'll share via github
  • endian
  • endian's Avatar
30 Jan 2026 06:54
The pins already exist:
joint.N.vel-cmd - velocity command per joint
joint.N.acc-cmd - acceleration command per joint
joint.N.jerk-cmd - jerk command (useful for S-curve)
These are updated every servo cycle after cubic interpolation, so they represent instantaneous commanded values suitable for feedforward.
For your cia402 component rewrite:
0x60B2 (torque feedforward) needs joint.N.acc-cmd × inertia, you can do this with a mult2 in HAL or inside your component
No TP changes needed. Just wire the existing pins to your component and map them to the PDOs.
At the moment only joint 0-1-2 jerk-cmd is calculated proper I think, later on we will do all.
  • NWE
  • NWE's Avatar
30 Jan 2026 05:49
PLC + LinuxCNC for industrial machine with simple HMI (non-G-code operators)
Some notes on what has been working for me:
Currently my go-to PLC+HMI setup is LinuxCNC+Node Red dashboard. Sometimes also Glade user interfaces.
I use a combination of Mesa Electronics boards and/or Beckhoff ethercat remote I/O at locations on the machine where you'd normally expect to find a PLC. My logic runs on hal + custom hal components coded in basically C.
Non real-time logic, recipe selections etc. can be configured in node-red pretty much without writing a single line of code unless you want customized functions.
LinuxCNC also has a ladder logic PLC built-in but I cannot inform you of its capabilities, having never used it. I don't care for ladder logic in any form. I have spent way too much time trying to automate complicated machine sequences in expensive proprietary PLC ladder programming software that did not always function the way I expected or wanted.
With node-red for the HMI, all the software lives in the LinuxCNC 'server'. The physical HMIs consist of panel mount touchscreen IPCs booting pretty much any os, autostarting a web browser fullscreen, pointed at the LinuxCNC sever's Node Red web page. The hmi is simply a web page(s) in the server. Placing a duplicate HMI at an additional operator station consists of whatever device you wish, running a web browser displaying the server's web page(s)
I think node-red supports multiple user logins, but I have not tried that feature. In the projects I did so far, I am the only programmer, and the operators don't know how to access the programming back end. Everyone is logged in as me.
On a recent project I set up a router blasting WIFI over the premises. The operator driving the payloader can log into the WIFI with his phone and access the HMI to monitor the processes and switch the machines on/off that he is tending. From the payloader cab.
The entire network is air-gapped from public internet except the server has access to ntp time.
E-stop, safety lockouts, etc are all hardwired with physical safety hardware.
With this system an operator station needs the following wiring:
1. A power cord for the pc.
2. A network cable.
3. A 2 to 6 conductor cable for the E-stop circuit.
When I get more time I'd like to provide some documentation on all this, and some example configs. Currently I'm in the middle of several half finished projects like this, plus a customer running a proprietary PLC I programmed in ladder logic is starting to have random crashes of the PLC, so he is due for an upgrade to LinuxCNC with Glade user interface. This is one more basic machine, so I will skip the node-red. The glade user interface is an app that runs on a monitor plugged directly into the LinuxCNC pc. Then there is a sizable project I'm currently drafting a quote for.
node red getting started:
nodered.org/docs/getting-started/local
I use this for installing node-red:
nodered.org/docs/getting-started/raspberrypi
Although it says raspberry pi, it can be used on an x86/64 pc. During the installation it asks whether I want to install Pi specific nodes, I opt out of that because my x86/64 pc is not a Raspberry pi.
I have been using mqtt messaging to communicate between the LinuxCNC program(s) and node-red. That entails setting up an mqtt server, I have been using mosquitto:
sudo apt install mosquitto
then I run a python-hal component to communicate with node-red via mqtt
Doing all the above configuration pretty much requires a a person to first know his way around linux configuration in the /etc directory extensively.
Default installation of mosquitto and node-red I think listen only on localhost for connection.
Wow, I was going to attach a copy of my python-hal-mqtt connector, but my backup of it seems to be missing. I will have to retrieve a copy from customer's machine as soon as I can.
  • grandixximo
30 Jan 2026 05:39 - 30 Jan 2026 06:02
  • SOLD
  • SOLD
30 Jan 2026 02:36
Replied by SOLD on topic 7i92M + 7i76 add PWM+PktUART
Thank you very much for the explanation and for providing the complete 7I76 firmware image.
That clarifies the architecture and recovery path perfectly.
I will try external programming on my side based on this.
If I run into anything unclear, I may follow up.
Thanks again for your help.
  • Marcos DC
  • Marcos DC's Avatar
30 Jan 2026 02:21
Hello,I work for a company that provides on-site and in-factory service and maintenance for heavy-duty industrial and construction machinery.We are currently developing a large custom machine for laser cleaning and automated painting of heavy equipment and structures. The system will use LinuxCNC as the motion controller, but the machine will be operated by multiple technicians who do not have a G-code programming background.For this reason, we are evaluating the use of a PLC + LinuxCNC architecture, where:
  • LinuxCNC handles motion control
  • A PLC and HMI handle operator interface, recipes, and simple machine operation (start/stop, part selection, dimensions, safety, etc.)
I would like to hear from others who are using LinuxCNC in an industrial environment with PLC + HMI, especially for machines operated by non-CNC specialists.In particular, I am interested in:
  • How you split responsibilities between PLC and LinuxCNC
  • How you manage recipes and part parameters
  • How you design a simple HMI for operators
  • Any recommended PLC platforms or architectures that integrate well with LinuxCNC
Any real-world examples or lessons learned would be greatly appreciated.Thank you.
  • COFHAL
  • COFHAL
30 Jan 2026 00:55
Solving the USB Latency Dogma for HMI/MPG: Technical Feedback Request
Another error I found is in the io_decoder-keymap.cfg file. In the example, there are comments with #, and when LCN is run, errors appear. I deleted all the extra lines and only left the lines that assign keys to the inputs.
Displaying 6136 - 6150 out of 14036 results.
Time to create page: 0.441 seconds
