  • PCW
  • PCW's Avatar
27 Dec 2025 00:21
Replied by PCW on topic Mesa 6i25 not working?
Category: Driver Boards
That's really odd
You are not running as root are you?
is this a normal Linux installation?
What does
uname -a
report?
  • NWE
  • NWE's Avatar
27 Dec 2025 00:03
DIY CNC Mill - Random Limit Switch Errors
Category: Milling Machines
Connecting all grounds to the buss bar sounds great.
One way to track down redundant grounds is to disconnect the known grounds then take an ohm reading to find out whether it is still connected to ground via an unexpected route.
Like I said, you can cheat some. I am not real strict on my projects about having no redundant grounds, but it is one of the things I work on if there are interference problems.
In your case, I would suggest concentrating on the shield grounds right at the BOB as that seems to be a pain point what with it acting up as soon as you so much as connect stepper signals and start the vfd.
Please, did you try moving those AC wires that are parallel to the BOB and within inches of it?
  • tlightus
  • tlightus
26 Dec 2025 23:59
calling subroutine from G54, G55, G56, but it acts weird
Category: O Codes (subroutines) and NGCGUI
thank you for testing. i have been getting a very different result but will go back and see if it was something i was doing wrong.
  • sorokin_pro
  • sorokin_pro's Avatar
26 Dec 2025 23:55
Replied by sorokin_pro on topic Mesa 6i25 not working?
What version of mesaflash do you have?
user@denc:~$ mesaflash --version
Mesaflash version 3.5.11
No warnings without sudo.
  • MaHa
  • MaHa
26 Dec 2025 23:32
I was just working on a mdi command, so it was easy to have a look at this in FlexGui.
Starting with  G0G55X0Y0
Then pressing the button with MDI command
and it goes to    G0G54X0Y0
the subroutine:
o<work_zero> sub
G90 G54 G0 X0 Y0
o<work_zero> endsub [1]
M2
  • sorokin_pro
26 Dec 2025 23:27
5i25 is not 5I25
Linux is case sensitive.
Here is a piece of code from mesaflash:
access.device_name[i] = toupper(access.device_name[i]);
Device names are converted to upper case automatically.
  • dann1324
  • dann1324
26 Dec 2025 22:57
7c81 + 7i73 was created by dann1324
7c81 + 7i73
Hello all! I'm new here on the forum, I've been searching for a day or so now and can't really seem to figure this out. I've been using the machine with a rpi4, with the 7c81 running the 5abobx2 bitfile setup for a little while now and decided to expand with the 7i73. From what I've read, when using pncconf I should see the 7i73 or at least a way to set pins on the smart serial interface, right? So far, it never seems to show up. I have it connected to the 7c81 via a cat6 cable, and I have a power light on the 7i73. I've set the jumpers on the 7i73 to all the default locations (terminated serial, no lcd, no keypad). when using mesaflash to check the config of the 7c81, I can see the smart serial interface. I feel like there's something very simple I'm missing. I hope this isn't a repeat question, I couldn't find it here. I appreciate any help you can offer
  Module: SSerial
  There are 1 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 64 bytes
26 Dec 2025 22:53
Replied by tommylight on topic Mesa 6i25 not working?
user@denc:~$ sudo mesaflash --device 5I25
i
is not
I
5i25 is not 5I25
  • zippoffs
  • zippoffs's Avatar
26 Dec 2025 22:47
Replied by zippoffs on topic DIY CNC Mill - Random Limit Switch Errors
Wow, that's a lot to take in. I may have a ground loop to the machine frame. There is a ground wire in the spindle cable that is grounded to the motor frame, which is in contact with the rest of the mill. But I also do have a ground wire on the frame going to the ground bus in the breaker box. I will remove that.
There is continuity from the BOB end of the parallel cable to the PC when the PC power is disconnected, so it probably is shielded.
I currently have all the grounds and shielding grounds running to the ground bus in the breaker box. Are you saying this is causing issues? What would be the BOB's frame ground?
I have most of the electronics mounted to a piece of sheet metal, which is connected to main ground by the green/yellow terminal block by the contactor. Should I not do this?
  • PCW
  • PCW's Avatar
26 Dec 2025 22:46
Do get a warning when not using sudo?
If not, something really basic is broken here.
pcw@pcw-HP-Compaq-Elite-8300-USDT:~$ mesaflash --device 5i25
You need root privileges (or setuid root) to access PCI hardware
No 5I25 board found
  • Surmetall
  • Surmetall's Avatar
26 Dec 2025 22:39
LatheEasyStep – experimental QtVCP macro for step-by-step lathe programming
Category: Qtvcp
@Mark
Andys Marcos are great, but i think its something different. you only can do one task at a time as far as i know, right?
@aDm1N
You said in your last post "as far as I know, LinuxCNC doesn’t really offer something like this out of the box." That confuses me, because I already wrote about NativeCAM on the previous page. You didn’t respond to it specifically, but I simply assumed that you were already familiar with it. It’s possible that you overlooked it or that you just don’t like the tool. both are perfectly fine. However, if you simply missed it:NativeCAM does exactly what SIEMENS ShopTurn does. You write your program directly on the machine, editable and with a preview.The only thing is that the contour function was never fully completed back then and would need to be added by someone who can program. It’s called “Polyline” and already exists in milling, where it works perfectly. It just hasn’t been implemented for turning yet:
  • sorokin_pro
26 Dec 2025 22:20
You need to use sudo with mesaflash when accessing PCI cards
I just tried with and without sudo, I also tried while LinuxCNC is running.
Result is the same all the time:
user@denc:~$ mesaflash --device 5I25
No 5I25 board found
[sudo] password for user:
No 5I25 board found
  • PCW
  • PCW's Avatar
26 Dec 2025 22:16
  • sorokin_pro
26 Dec 2025 22:02
Will mesaflash recognize the card after LinuxCNC has run?
(I've seen this before with some BIO's that detect the card but for some reason disable the cards memory region)
No:
No 5I25 board found
user@denc:~$ linuxcnc
LINUXCNC - 2.9.7
Machine configuration directory is '/home/user/linuxcnc/configs/BenchtopX5'
Machine configuration file is 'BenchtopX5.ini'
Starting LinuxCNC...
Waiting for component 'tpmod' to become ready..........Waited 3 seconds for master.  giving up.
.Note: Using POSIX realtime
Found file(REL): ./BenchtopX5.hal
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:02:00.0
hm2/hm2_5i25.0: Low Level init 0.15
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0:     IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 006 (P3-04): StepGen #3, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 007 (P3-17): StepGen #3, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 008 (P3-05): StepGen #4, pin Direction (Output)
hm2/hm2_5i25.0:     IO Pin 009 (P3-06): StepGen #4, pin Step (Output)
hm2/hm2_5i25.0:     IO Pin 010 (P3-07): IOPort
hm2/hm2_5i25.0:     IO Pin 011 (P3-08): IOPort
hm2/hm2_5i25.0:     IO Pin 012 (P3-09): IOPort
hm2/hm2_5i25.0:     IO Pin 013 (P3-10): IOPort
hm2/hm2_5i25.0:     IO Pin 014 (P3-11): IOPort
hm2/hm2_5i25.0:     IO Pin 015 (P3-12): IOPort
hm2/hm2_5i25.0:     IO Pin 016 (P3-13): IOPort
hm2/hm2_5i25.0:     IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0:     IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0:     IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0:     IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0:     IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0:     IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0:     IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0:     IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0:     IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0:     IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0:     IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0:     IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0:     IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0:     IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0:     IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0:     IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0:     IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
Found file(REL): ./custom.hal
note: MAXV     max: 25.000 units/sec 1500.000 units/min
note: LJOG     max: 25.000 units/sec 1500.000 units/min
note: LJOG default: 6.000 units/sec 360.000 units/min
note: AJOG     max: 180.000 units/sec 10800.000 units/min
note: AJOG default: 12.000 units/sec 720.000 units/min
note: jog_order='XYZA'
note: jog_invert=set()
Running HAL shutdown script
task: 1471 cycles, min=0.000007, max=0.031596, avg=0.010006, 0 latency excursions (> 10x expected cycle time of 0.010000s)
hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
hm2/hm2_5i25.0: unregistered
RTAPI_PCI: Unmapped 65536 bytes at 0x7fc2736fd000
hm2_pci: driver unloaded
hm2: unloading
No 5I25 board found
  • tlightus
  • tlightus
26 Dec 2025 21:51
sorry if this is the wrong place to post this but it seemed appropriate.
i think i found a bug with subroutine calls
Conditions:
set up a pyvcp button to call an MDI_COMMAND
Set fixgure offsets for G54, G55
remain in G55 X0 Y0 and issue:
MDI_COMMAND = G0 G90 G54 X0 Y0
and that will work fine
Go back to G55 active offset at X0 Y0 and change the command to call a subroutine
MDI_COMMAND = o<work_zero> call
will fail not executing the subroutine command and sit at G55 zero
i tested this in both axis and flexgui with the exact same results
####### SUBROUTINE #######
o<work_zero> sub
G90 G54 G0 X0 Y0
o<work_zero> endsub
m2
if you are still in G55 at X0 Y0 and issue
G0 G90 G54 X0 Y0 from the mdi command line it will go to G54 X0 Y0 also
Displaying 7711 - 7725 out of 14053 results.
Time to create page: 3.233 seconds
