  • alexandrap
  • alexandrap
21 Dec 2025 08:24
Replied by alexandrap on topic My MESA 7i95T wiring
Category: Driver Boards
first steps
21 Dec 2025 00:12
Replied by tommylight on topic I can't get my tabs (or code) to load
Category: Plasmac
Does the PC have an add on graphic card? If yes, remove it and try with the onboard graphic, or vice versa, if it does not have one try finding a used one to test with.
Another thing to check is for locale to be set as UTF-8, and maybe try EN-US also.
  • LearningLinuxCNC
  • LearningLinuxCNC's Avatar
20 Dec 2025 23:15
Replied by LearningLinuxCNC on topic Pico Universal PWM Won't boot Random pins not working
Jon,
I have tried both 1.9 and 1.7 on the bios epp setting.
I tried the epp_dir=1 setting as you suggested.
The cable is the same one I have been using since I converted the machine back in 2015 or so.
The load fail red led does come on and stay on when I boot up linuxcnc and get the error messages. also the green estop ok led is lit as well. Prior to starting linuxcnc the light is off.
I decided to try and update to 2.9 linuxcnc and see if that helps but I am running into issues with that also. I need to get python3.7 installed but it is not playing nice. I will keep working on it but I suspect it is a hardware issue.
Do we need to try another eprom?
  • NWE
  • NWE's Avatar
20 Dec 2025 22:51 - 23 Dec 2025 19:08
Replied by NWE on topic Linuxcnc Image for Raspberry Pi 3
This is catching my interest. I think I will try it. I have at my fingertips a Pi 3 Model B+ but it is not working, not sure why. Maybe I dropped it a while back. I also have a Pi 3 Model B V1.2, I have it running a fresh install of Debian 12 Bookworm.
Now it is installing LXDE.
Next up is realtime kernel, I'm looking at linux-image-6.1.0-41-rt-arm64
And then LinuxCNC....
Fingers crossed...
  • MaHa
  • MaHa
20 Dec 2025 22:35 - 21 Dec 2025 09:26
inconsistency with radiobutton and hal_pin
Category: Flex GUI
Today i recognized a problem with radiobutton, hal_io . The button is set to checked in designer, but the hal_pin is not set to true at startup. A single radiobutton is even unchecked at startup.  To click an already checked radiobutton doesn't help. I need to check one of the unchecked radiobutton (to activate) set the hal_pin to true.
I think the language barrier made the text above a bit confusing, so adding some screenshot
  • PCW
  • PCW's Avatar
20 Dec 2025 22:23
Replied by PCW on topic Stepcraft M700 with 7i92TM
Category: PnCConf Wizard
On a 7I92T you can change the  GPIO  resistors from pullups (default) to pulldowns
to solve this issue (W2 down)
  • xkonni
  • xkonni
20 Dec 2025 20:23
Replied by xkonni on topic Stepcraft M700 with 7i92TM
fixed the spindle with a R1000 resistor between pin1 of the db25 plug and ground. all good now!
  • JeremyMakesThings
  • JeremyMakesThings's Avatar
20 Dec 2025 20:12
I can't get my tabs (or code) to load was created by JeremyMakesThings
Category: Plasmac
So I built a CNC plasma cutter out of garbage.... and since I built it out of garbage, I used a very old computer to run it.  It's a 32bit computer, so I'm stuck running Linuxcnc 2.8.  I got a base configuration working and running fairly well, but because it's made out of garbage, it really needs torch height control.  I got a THCAD and got everything wired up to my Mesa 7i96s, and ran the PlasmaC configurator.  The buttons on the bottom of the screen work, I can test the ohmic probe, and the probe cycle seems to work, but I can't get any of the GladeVCP components to load.  The tabs are there, but they're blank, and if I try to configure it with a Run panel instead of the run tab, it doesn't show up.  The other issue I have is I can't load a G-code file, it seems to get stuck "Filtering."  On top of that, I'm now having latency issues I wasn't having before.  I've been staring at and trying to troubleshoot my configurations for way too long and I can't find anything obviously wrong, so I suspect this 20+ year old Dell just isn't up to the task.  Part of the "art" of this machine was that it's made of junk, so if I can keep using this computer, I'd like to... but I'd also like the machine to work properly, so I figured I'd at least upload my configs for someone more knowledgeable to look at before I buy something more modern.
File Name: scrapdroid...ions.hal
File Size:2 KB
File Name: scrapdroid0000.hal
File Size:10 KB
File Name: scrapdroid0000.ini
File Size:9 KB
File Name: terminal.txt
File Size:8 KB
  • T.Frei
  • T.Frei
20 Dec 2025 19:11
Replied by T.Frei on topic PoKeys57CNC HAL component
Category: HAL
I'm afraid that the 56U is not supported. Or at least I did not add explicit support for this.
I do not know if the 56 series supports the PulseEngine V2 which I'm using to control the motion. You could try though.
In the source code there is a check , if the device is a 57CNC, which only logs a warning.
And there is another check if the "external pulse generator" is used.
Excerpt from the documentation
Pulse engine v2 supports two different pulse generator modules:
- Internal: similar to basic Pulse engine, limited to 25 kHz pulse frequency at 3 channels, uses built-in circuitry and pins
- External: new in v2, limited to 125 kHz pulse frequency at 8 channels, requires external circuitry to deserialize the data to pulses
  • xkonni
  • xkonni
20 Dec 2025 18:07
yes, that actually helped! Machine is running with a stock cable now and all commands work as expected. Thank you very much!
Except when I shutdown, the spindle starts. That is very uncomfortable. Still trying to understand why this is happening here. Any hints? ;)
Oh and in uccnc the step scale was 160 for xy, 320 for z, here it is 80 for xy and 160 for z. Well, that's not a problem I guess. Maybe loosing some accuracy?
  • et
  • et
20 Dec 2025 16:57
I am only at the start stages, building the machine. Actually not dealing at the moment with CSS. I was wondering if the beta version ready for use. Eventually I installed 3.1.3. The Machine is DMC2 MINI from here: shariffdmc.com/product/dmc2-mini-cnc/ It needed many mechanical modifications that took some time to overcome.
  • lorenzing
  • lorenzing
20 Dec 2025 15:58
Replied by lorenzing on topic Ethercat Motion Problem
Category: EtherCAT
Hi jjdege, by changing the pos-scale value, all the movements don't correspond to reality.
I solved most of the problems by changing the SERVO_PERIOD from 2000000 to 1000000.
I've also a problem in display section: MIN_LINEAR_VELOCITY = 0 MAX_LINEAR_VELOCITY = 50.00
Many thanks to all of you
  • jjdege
  • jjdege's Avatar
20 Dec 2025 15:20
Replied by jjdege on topic Ethercat Motion Problem
Category: EtherCAT
try changing the value in the .hal file
setp cia402.0.pos-scale 1000
20 Dec 2025 14:55
Replied by tommylight on topic PicoBOB-DLX
PicoBOB-DLX
See also Mesa 7i96S and 7i76E and 7i95 and many other combos, but for a start 7i96S is the easiest to wire and quite cheap.
Displaying 7906 - 7920 out of 14059 results.
Time to create page: 0.608 seconds
