  • jmelson
  • jmelson
20 Dec 2025 13:34
Pico Universal PWM Won't boot Random pins not working
Category: Driver Boards
John,
Yes it is the UPWM board. It is driving your pwm servo drives. The CMOS battery did die at one point but the parallel port is set up in epp mode. I am not sure why it is doing this. If you have any troubleshooting tips I would be glad to hear them. Could the eeprom be bad?
OK, so the scan of the parallel port is getting some random stuff, since it thinks it sees a bunch of PPMC boards there.
The FPGA on the UPC runs a checksum on the data loaded from EPROM, so if the red (load fail) LED flashes and goes out when power is applied, then it is accepting the firmware as valid.  If that LED stays on, then the firmware did NOT load.  First, check that the BIOS settings are for the parallel port to be at address 378, as that is what LinuxCNC is using.  If this is a PCI or PCIe parallel port, then the address will not be 0x378.  There are several versions of EPP mode, if the BIOS allows to select between 1.7 and 1.9 versions, try both.  If your parport cable is not rated for IEEE1284 operation, that can be the problem.
Oh, one other thing is there are some ppmc driver options that may need to be changed for the newer LinuxCNC version.
In your config file set, in ppmc_load.hal, on the line that loads the ppmc driver,
loadrt hal_ppmc timestamp="0x00"
try adding this to the end of that line:
< space> epp_dir=1
That might fix it.  This is documented in a comment in that file.
I'm not too sure what else to suggest.
Jon
  • markusk
  • markusk
20 Dec 2025 13:31
Replied by markusk on topic Toyota embroidery machine - retrofit
Category: CNC Machines
subscribed .. curious about the outcome and further experiences.
venturing into embroidery myself lately, got a 2010ish 12needle chinese machine (in reasonably good working condition) standing round but neither time nor space to work with it. in the meantime learned a bit about design and software for it - a whole ecosystem by itself obviously - curious how and if you'd try to translate this to the (linux)cnc-world..
cheers,
markus.
  • Surmetall
  • Surmetall's Avatar
20 Dec 2025 12:59
LatheEasyStep – experimental QtVCP macro for step-by-step lathe programming
Category: Qtvcp
Awesome, I’m really looking forward to your tool, and I think if this works out it’ll be an absolute game changer for lathes!I find all of this really interesting feel free to keep the camera running while testing and upload it somewhere. I’m pretty sure I’m not the only one watching this with excitement.A very cool project to make use of the time between the holidays.
  • lorenzing
  • lorenzing
20 Dec 2025 12:46
Replied by lorenzing on topic Ethercat Motion Problem
Category: EtherCAT
Unfortunately, I never reach the speed set in the .ini file.
The motors move much slower than the set speed and make a lot of noise. If I set the same speed in the drive program, the command executes smoothly and without making any noise.
I'm probably doing something wrong in the configuration.
  • unknown
  • unknown
20 Dec 2025 11:16
Replied by unknown on topic Linuxcnc Image for Raspberry Pi 3
There are no premade RPi3 images available for download.
You have a couple of options.
1: Someone maybe able to make one, but it would require that person having access to a Rpi3.
2: Find someone with Linux knowledge who can also speak english and is willing to help.
3: Have a go following someone's instructions, all is not lost if you make a mistake.
4: Look into using grbl.
A bit of a warning regarding the RPi3, you may have latency issues, which there may not be a solution for fixing it. Increasing thread period may not give smooth operation.
Saying that you don't understand all the time wont help. I'm sorry I really wish it was different.
  • unknown
  • unknown
20 Dec 2025 11:01 - 20 Dec 2025 11:08
Replied by unknown on topic PicoBOB-DLX
PicoBOB-DLX
Yeah std breakout board, a lot of the generic Chinese one have a 0-10v converter. Mesa also sells something called spinx1 store.mesanet.com/index.php?route=produc...oduct&product_id=205 which could be connected to the 2nd port on the 7i92T.
Glass sensor would require a buffer circuit of sorts I guess, PCW would have the best advice regarding that.
I've been using an original 7i92 for years (the change was to a different FPGA for the T) and had no issues........plus a number of other cards as things grew ;)
This how good the support from Mesa is. Some users have bought clones from AliExpress (I'd recommend the genuine thing) and he's been happy to help those users out. TBH PCW has helped me out when I got bored and tried to build a clone of a 7c81 based on a Spartan6 FPGA dev board. Which does work either via SPI to Raspberry Pi 4/5 or a PC with a parallel port using the EPP protocol.
You may find some forum users very biased towards Mesa, some build machines professionally and only use Mesa, other have converted a mill or a lathe....or many other machines that I have probably missed. But they all swear by Mesa products.
Not that there aren't other options, but it's the best way if you "just wanna make chips".
  • Hakan
  • Hakan
20 Dec 2025 09:57
Replied by Hakan on topic Ethercat Motion Problem
Category: EtherCAT
Just standard linuxcnc settings. You have Velocity and Accelerations settings for every axis in the ini file. Adjust them to your liking.
  • aDm1N
  • aDm1N's Avatar
20 Dec 2025 09:50
Category: Qtvcp
I'm still working on it. At the moment it is only partially useable. At the moment I am working on ensuring that the contour is implemented correctly. Especially with regard to circular arches. Thread already looks good. The goal is that 100% can be done on the machine. After I have implemented this with the contour, the goal is that a correction is included, depending on which tool is chosen. Means that the cutting geometry is included in the movement depending on which tool is chosen. If possible, the information should come from the Tool.db. In addition, a warning if the chipping with the tool is not possible. I can't say how quickly I can do it, but I'll try until I have a working solution. Anyone who has ever worked on Siemens controllers should certainly get along with the panel, because my experience with the machines certainly shows similarities.
  • Nator
  • Nator
20 Dec 2025 09:47
Replied by Nator on topic PicoBOB-DLX
PicoBOB-DLX
thanks for the answer!
To get the 7i92T working I need at least a "standard" lpt breakoutboard, right? That would be for the steppers. What would I need for a 0-10V signal for the spindle? Can I plug in glass "sensor" into it? (I would not really need it, never had any step losses with my other machine).
Well yes you always have to double check what the KI says, but for programming it helps alot :)
regards Han
  • Sandro
  • Sandro
20 Dec 2025 09:45
Replied by Sandro on topic Axis deflecting while jogging in G54
Category: QtPyVCP
Good point Rod, I will do so.
  • lorenzing
  • lorenzing
20 Dec 2025 09:44 - 20 Dec 2025 09:47
Ethercat Motion Problem was created by lorenzing
Category: EtherCAT
Hi all,I'm experiencing an issue with my EtherCAT drive. When I try to move any axis through LinuxCNC, the motion is noticeably slower compared to using the drive's own software.I've attached two videos for comparison:
  • Hakan
  • Hakan
20 Dec 2025 09:37
Ver 2.9.4 iso clean install Trouble when disabling EOE
Category: EtherCAT
I was able to find the manual and some info´about the alarm. Even if there were very few clues in the post
Then you can try
  <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1000" syncToRefClock="true">
or if you have an old lcec version and syncToRefClock isn't recognized: refClockSyncCycles="-1000"
Check the lcec.0.pll-reset-count variable that it stays on single digit. Read at least one full page here github.com/linuxcnc-ethercat/linuxcnc-et...istributed-clocks.md
  • Hakan
  • Hakan
20 Dec 2025 09:21
Ethercat compatible Encoder board tentative STM32F4 + LAN9252
Category: EtherCAT
Good. Has happened before. A total reset after eeprom update is usually a good idea.
I normally upload firmware on the fly, even when connected to linuxcnc. Much less sensitive.
  • Hakan
  • Hakan
20 Dec 2025 09:18
Category: EtherCAT
And what does the last lines in "sudo dmesg" say?
It is the drive that is unhappy, but hopefully the ethercat master tells why it won't download data to an SDO.
Or give another clue.
  • tar_san
  • tar_san
20 Dec 2025 08:21 - 20 Dec 2025 08:21
Category: EtherCAT
Yes, 67108864 is Encoder count per round.
The problem is "Alarm A12 (EtherCAT Output Syncronization Error) "
A support person said,
"As long as A12 occurs, servo amp can't anser properly."
Displaying 7921 - 7935 out of 14059 results.
Time to create page: 0.501 seconds
