  • NWE
  • NWE's Avatar
15 Dec 2025 22:04 - 15 Dec 2025 22:18
Replied by NWE on topic Avon 3000 Mill retrofit
Category: Milling Machines
I see you already answered my question. That motor is powered by two contactors fwd/rev. Good enough. It also shows a spindle speed sensor with two wires. Is that perhaps some proximity sensor?
I can see possibly configuring that with hal and/or a custom hal component by using mesa card outputs to trigger the two contactors (via relays, probably).
15 Dec 2025 21:52
Advantech PCM 9362 freze when opening latency-test
Use this ISO
www.linuxcnc.org/iso/linuxcnc-2.7.14-wheezy.iso
Boot the PC from it and run the tests in Live mode, meaning do not install, see if it hangs.
15 Dec 2025 21:49
Replied by tommylight on topic VOLATILE_HOME not unhoming on fault
Category: Basic Configuration
LinuxCNC has not lost any ability to shut off anything, there is no need to shut the power down for stepper and brushless servo drives on normal faults, that was for DC brushed servo systems and even for those normal enable/disable drive was and is used, leme give it a try:
-stepper motors and brushless servo motors do not go into runaway if an output mosfet shorts, they just lock in one place and burn slowly if the drive fails to blow a fuse or trigger a full shutdown
-brushed motors do run at full speed in one direction in such an event, hence the necessity to have another set of "extreme" limit switches on both side of any axis that cut all power to drives
-older brushless servo drives had two separate power inputs, one for the drive stage and one for logic, most new ones only have a single power input
In general, drive power should be cut only on e-stop event, in normal operation drive enable/disable should be used.
If you are OK with using e-stop, wire (in hal) the drive enable signal to e-stop out, that should do what you want, but i have no clue if your machine agrees with that.
  • NWE
  • NWE's Avatar
15 Dec 2025 21:44
Can you find any specs on the motor that drives the CVT adjuster? Maybe even a pic. of its nameplate. I suspect something should be available for it. Using a VFD for speed control a person can gain some low end torque using closed loop speed feedback and PID, but the CVT on my Wilton mill certainly has a lot more low speed torque than I was able get with just a vfd on another project.
  • alangibson
  • alangibson
15 Dec 2025 20:24
MetalHeadCAM 0.3.0 released was created by alangibson
Category: Plasmac
Hi all,
I've just pushed MetalHeadCAM v0.3.0 to cam.metalheadcnc.com. I'd love to hear any and all feedback you have.
Just import a DXF file, then click the Add button in the operations panel. After that you should be able to simulate and export Gcode.
Since the last release:
- Much improved performance
- Added spot operations
I'm still not maintaining backwards compatibility, so if you've tried it before be sure to go to the hamburger menu in the top left corner > Settings > click Reset Application before use.
  • djdelorie
  • djdelorie
15 Dec 2025 20:15
Replied by djdelorie on topic VOLATILE_HOME not unhoming on fault
I will add that, with the invention of "servos with a step/dir interface", linuxcnc has lost the ability to shut off the servo power yet still keep track of where the machine *is* for when power is restored :-(
  • djdelorie
  • djdelorie
15 Dec 2025 20:12
My thinking is that once you have the machine dialed in you will never get this error.
Agreed; I wired my servos this way for when I get a hard crash.  the "fault" includes following errors in the clearpaths, and I really want the machine to stop and release the servos and spin down the spindle.  The hard crash might be a fleshy crash.  I realized the servos were going to lose position, added the VOLATILE_HOME, and discovered this bug...
  • Sekai
  • Sekai
15 Dec 2025 20:07
Hi.
I have mini pc that i tried to install linuxcnc ( latest version) but horrible latency above 100000.
So i put Debian 12 and install kernal RTai 5.4.258 and linux cnc 2.9.3.
All is good, latency test is like max 24000 with default settings in the bios ( remove everything from the bios i got about 16000 after 2 hours).
The problem sometime the mini pc freeze when running tests (latency-test) so i have to restart.
I thought the bios settings was the culprit so i restore bios to default but the same.
Should i use i different distro or kernel?
  • jaro_p
  • jaro_p's Avatar
15 Dec 2025 19:53 - 15 Dec 2025 19:59
Changes in configuration files generated in pncconfig for 7i76 to 7i78
Category: PnCConf Wizard
[/attachment]  I know that there is a configuration 7c81_7i78x2d.bit, but there is the same on P2 as on P1 - 7i78. Another 4 axes. And I don't need that for the lathe. But I would like one MPG encoder for each axis - basically to be able to control the lathe "almost" manually. The rest of P2 controls the tool turret and on P7 there are limit switches and buttons.
So that's the goal.
15 Dec 2025 17:38
Replied by tommylight on topic 7i96s + 7i78
7i96s + 7i78
Category: Driver Boards
You need a parallel port(female) to flat connector (think IDE PATA connector).
Dude, really ????
IDEA PATA is a 40 pin connector, and just to make you wonder, comes with a 40 wire and 80 wire flat cable.
Find out why.
And as a precaution, it is not a floppy drive connector either, that has ?? pins ! :)
15 Dec 2025 17:35
7i96s + 7i78
You would need this and maybe another DB25 to DB25 cable, also know as parallel port cable
eusurplus.com/index.php?route=product/pr...59_63&product_id=130
And might need a firmware flash, but do check what is already installed on the card using mesaflash
  • sin-do-re
  • sin-do-re
15 Dec 2025 17:09
7i96s + 7i78 was created by sin-do-re
7i96s + 7i78
How can i use a 7i96s together with a 7i78 to get 2 more STEPGENs?
My main board 7i96s was being used to control 5 axis Stepgens, but one has fried completely, and i was hoping i could expand the board with a 7i78 i have laying around, to control a total of 6 (4+2) stepgens. is this possible? What bit file should I use? Is there one available for it ?
Best regards
  • PCW
  • PCW's Avatar
15 Dec 2025 16:54
There is a 7I78X2 configuration: 7c81_7i78x2d.bit
Do you need MPG encoders or high speed encoders+index?
  • Aciera
  • Aciera's Avatar
  • jaro_p
  • jaro_p's Avatar
15 Dec 2025 14:44
Alternatively, could someone please create a bitfile for me for 7c81 with one 7i78 and port P2 entirely for encoders (i.e. at least 3)?
Displaying 8086 - 8100 out of 14062 results.
Time to create page: 0.631 seconds
