  • Tinker
  • Tinker
21 Nov 2025 15:33
Replied by Tinker on topic Probe basic launch issue
I'm sure I messed something up again.. here's a copy of my HAL& INI files
HAL
# This file was created with the Mesa Configuration Tool on Nov 21 2025 06:35:29
# If you make changes to this file DO NOT run the configuration tool again!
# This file will be replaced with a new file if you do!
# kinematics
loadrt [KINS](KINEMATICS)
# motion controller
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_dio=6 num_aio=3
# hostmot2 driver
loadrt hostmot2
loadrt [HM2](DRIVER) board_ip=[HM2](ADDRESS) config="sserial_port_0=00000000"
setp hm2_[MESA](BOARD).0.watchdog.timeout_ns 10000000
loadrt pid names=pid.x,pid.y,pid.z
# THREADS
addf hm2_[MESA](BOARD).0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf hm2_[MESA](BOARD).0.write servo-thread
# amp enable
net motion-enable <= motion.motion-enabled
# Global PWM setup
setp hm2_[MESA](BOARD).0.pwmgen.pwm_frequency 75000
# Board: 7i97t
# Axis: X Joint: 0 Output: 0
# PID Setup
setp pid.x.Pgain [JOINT_0](P)
setp pid.x.Igain [JOINT_0](I)
setp pid.x.Dgain [JOINT_0](D)
setp pid.x.bias [JOINT_0](BIAS)
setp pid.x.FF0 [JOINT_0](FF0)
setp pid.x.FF1 [JOINT_0](FF1)
setp pid.x.FF2 [JOINT_0](FF2)
setp pid.x.deadband [JOINT_0](DEADBAND)
setp pid.x.maxoutput [JOINT_0](MAX_OUTPUT)
setp pid.x.error-previous-target True
# joint-0 enable chain
net joint-0-index-enable <=> pid.x.index-enable
net joint-0-index-enable <=> joint.0.index-enable
net joint-0-index-enable <=> hm2_[MESA](BOARD).0.encoder.00.index-enable
net joint-0-enable <= joint.0.amp-enable-out
net joint-0-enable => pid.x.enable
net joint-0-enable => hm2_[MESA](BOARD).0.pwmgen.00.enable
# PWM Generator setup
setp hm2_[MESA](BOARD).0.pwmgen.00.dither true
setp hm2_[MESA](BOARD).0.pwmgen.00.output-type 1 #PWM pin0
setp hm2_[MESA](BOARD).0.pwmgen.00.offset-mode 1 # offset mode so 50% = 0
setp hm2_[MESA](BOARD).0.pwmgen.00.scale [JOINT_0]SCALE
setp hm2_[MESA](BOARD).0.encoder.00.counter-mode 0
setp hm2_[MESA](BOARD).0.encoder.00.filter 1
setp hm2_[MESA](BOARD).0.encoder.00.index-invert 0
setp hm2_[MESA](BOARD).0.encoder.00.index-mask 0
setp hm2_[MESA](BOARD).0.encoder.00.index-mask-invert 0
setp hm2_[MESA](BOARD).0.encoder.00.scale [JOINT_0]ENCODER_SCALE
# position command and feedback
net joint-0-pos-cmd <= joint.0.motor-pos-cmd
net joint-0-pos-cmd => pid.x.command
net joint-0-pos-fb <= hm2_[MESA](BOARD).0.encoder.00.position
net joint-0-pos-fb => joint.0.motor-pos-fb
net joint-0-pos-fb => pid.x.feedback
# PID Output
net joint.0.output <= pid.x.output
net joint.0.output => hm2_[MESA](BOARD).0.pwmgen.00.value
# Encoder Setup
setp hm2_[MESA](BOARD).0.encoder.00.scale [JOINT_0](ENCODER_SCALE)
INI
# This file was updated with the Mesa Configuration Tool on Nov 21 2025 06:35:29
# Changes to most things are ok and will be read by the Configuration Tool
[MESA]
VERSION = 2.1.8
BOARD = 7i97
BOARD_NAME = 7i97t
FIRMWARE =
CARD_0 = None
CARD_1 = None
[EMC]
VERSION = 1.1
MACHINE = my mill
DEBUG = 0x00000000
[HM2]
DRIVER = hm2_eth
ADDRESS = 10.10.10.10
[DISPLAY]
DISPLAY = probe_basic
OPEN_FILE = ~/linuxcnc/nc_files/pb_examples/blank.ngc
CONFIRM_EXIT = False
LOG_FILE = sim.log
LOG_LEVEL = DEBUG
PREFERENCE_FILE = sim.pref
CONFIG_FILE = custom_config.yml
POSITION = 0x0
PROGRAM_PREFIX = /home/kris/linuxcnc/nc_files
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 2.000000
MIN_SPINDLE_OVERRIDE = 0.500000
DEFAULT_SPINDLE_SPEED = 300
MIN_LINEAR_VELOCITY = 0.016670
DEFAULT_LINEAR_VELOCITY = 10.00000
MAX_LINEAR_VELOCITY = 10.000000
DEFAULT_ANGULAR_VELOCITY = 36.000000
MAX_ANGULAR_VELOCITY = 360.000000
MIN_ANGULAR_VELOCITY = 1.666667
PROGRAM_PREFIX = ~/linuxcnc/nc_files
INCREMENTS = JOG .01in .001in .0001in
GEOMETRY = xyzac
USER_TABS_PATH = user_tabs/
USER_BUTTONS_PATH = user_buttons/
USER_DROS_PATH = user_dro_display/
DRO_DISPLAY = XYZ
OFFSET_COLUMNS = XYZR
TOOL_TABLE_COLUMNS = TZDR
KEYBOARD_JOG = true
KEYBOARD_JOG_SAFETY_OFF = true
ATC_TAB_DISPLAY = 0
USER_ATC_BUTTONS_PATH = user_atc_buttons/
CYCLE_TIME = 0.1
INTRO_TIME = 1
OPEN_FILE = ""
[KINS]
KINEMATICS = trivkins coordinates=XYZ
JOINTS = 3
[EMCIO]
EMCIO = iov2
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[RS274NGC]
RS274NGC_STARTUP_CODE = F10 S300 G20 G17 G40 G49 G54 G64 P.001 G80 G90 G91.1 G92.1 G94 G97 G98
PARAMETER_FILE = probe_basic.var
OWORD_NARGS = 1
NO_DOWNCASE_OWORD = 1
SUBROUTINE_PATH = subroutines
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 2000000
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
MAX_LINEAR_VELOCITY = 3.4
NO_FORCE_HOMING = 1
[HAL]
HALUI = halui
POSTGUI_HALFILE = probe_basic_postgui.hal
TWOPASS = on
HALFILE = main.hal
HALFILE = io.hal
[AXIS_X]
MIN_LIMIT = -14
MAX_LIMIT = 14
MAX_VELOCITY = 10
MAX_ACCELERATION = 10
[JOINT_0]
CARD = 0
TAB = 0
AXIS = X
MIN_LIMIT = -14
MAX_LIMIT = 14
MAX_VELOCITY = 10
TYPE = LINEAR
SCALE = 4
ANALOG_SCALE_MAX = 10
ANALOG_MIN_LIMIT = -10
ANALOG_MAX_LIMIT = 10
ENCODER_SCALE = -40000
FERROR = 25
MIN_FERROR = 25
DEADBAND = 0
P = 10
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0
BIAS = 0
MAX_OUTPUT = 100
MAX_ERROR = 25
HOME = 0
HOME_OFFSET = -14
HOME_SEARCH_VEL = -1
HOME_LATCH_VEL = 1
HOME_FINAL_VEL = 0
HOME_USE_INDEX = True
HOME_IGNORE_LIMITS = True
HOME_IS_SHARED = True
[AXIS_Y]
MIN_LIMIT = -9
MAX_LIMIT = 9
MAX_VELOCITY = 10
[JOINT_1]
CARD = 0
TAB = 1
AXIS = Y
MIN_LIMIT = -9
MAX_LIMIT = 9
MAX_VELOCITY = 10
TYPE = LINEAR
SCALE = 4
FERROR = 25
MIN_FERROR = 25
DEADBAND = 0
P = 10
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0
BIAS = 0
MAX_OUTPUT = 100
MAX_ERROR = 25
HOME = 0
HOME_OFFSET = -9
HOME_LATCH_VEL = 1
HOME_FINAL_VEL = 0
[AXIS_Z]
MIN_LIMIT = -17
MAX_LIMIT = 0
MAX_VELOCITY = 5
MAX_ACCELERATION = 5
[JOINT_2]
CARD = 0
TAB = 2
AXIS = Z
MIN_LIMIT = -17
MAX_LIMIT = 0
MAX_VELOCITY = 5
TYPE = LINEAR
SCALE = 4
ENCODER_SCALE = 40000
FERROR = 25
MIN_FERROR = 25
DEADBAND = 0
P = 10
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0
BIAS = 0
MAX_OUTPUT = 100
MAX_ERROR = 25
HOME = -1
HOME_OFFSET = 0
HOME_SEARCH_VEL = 1
HOME_LATCH_VEL = 1
HOME_FINAL_VEL = 0
[INPUTS]
# DO NOT change the inputs they are used by the configuration tool
INPUT_0_8 = Joint 0 Plus Minus Home
INPUT_INVERT_0_8 = True
INPUT_SLOW_0_8 = False
INPUT_0_9 = Joint 1 Minus Home
INPUT_INVERT_0_9 = True
INPUT_SLOW_0_9 = False
INPUT_0_10 = Joint 1 Plus
INPUT_INVERT_0_10 = True
INPUT_SLOW_0_10 = False
INPUT_0_11 = Joint 2 Plus Home
INPUT_INVERT_0_11 = True
INPUT_SLOW_0_11 = False
INPUT_0_12 = Joint 2 Minus
INPUT_INVERT_0_12 = True
INPUT_SLOW_0_12 = False
INPUT_0_14 = Lube Level
INPUT_INVERT_0_14 = False
INPUT_SLOW_0_14 = False
[OUTPUTS]
# DO NOT change the outputs they are used by the configuration tool
OUTPUT_0_0 = Spindle CW
OUTPUT_INVERT_0_0 = False
OUTPUT_0_1 = Spindle CCW
OUTPUT_INVERT_0_1 = False
OUTPUT_0_2 = Coolant Flood
OUTPUT_INVERT_0_2 = False
OUTPUT_0_3 = Lube Pump
OUTPUT_INVERT_0_3 = False
[OPTIONS]
# DO NOT change the options they are used by the configuration tool
LOAD_CONFIG = True
INTRO_GRAPHIC_TIME = 0
MANUAL_TOOL_CHANGE = True
CUSTOM_HAL = False
POST_GUI_HAL = False
SHUTDOWN_HAL = False
HALUI = False
PYVCP = False
GLADEVCP = False
LADDER = False
BACKUP = True
21 Nov 2025 15:26
Replied by tommylight on topic Probe basic launch issue
The ini file is pointing to an io.hal file that does not exist in that folder.
You can try omitting that entry in the ini file, but might be needed for the config to work, so better try to find the file if you are sure it is needed.
  • Aciera
  • Aciera's Avatar
21 Nov 2025 15:23
Replied by Aciera on topic Probe basic launch issue
twopass:CANNOT FIND FILE FOR:io.hal
seems that you are telling it to load 'io.hal' somewhere but don't have that file in your config.
  • Tinker
  • Tinker
21 Nov 2025 15:01
So i was able to get PB to launch and then i tried to do the modifications that were recomended on the start screen. I modified my HAL and INI files and now have the following error report..
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.4
Machine configuration directory is '/home/kris/linuxcnc/configs/my_mill'
Machine configuration file is 'my_mill.ini'
INIFILE=/home/kris/linuxcnc/configs/my_mill/my_mill.ini
VERSION=1.1
PARAMETER_FILE=probe_basic.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=probe_basic
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Starting LinuxCNC IO program: iov2
twopass:invoked with <> options
twopass:found ./main.hal
iov2: exiting
Debug file information:
Note: Using POSIX realtime
2139
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Fri Nov 21 08:56:05 AM CST 2025
UTC Date: Fri Nov 21 02:56:05 PM UTC 2025
this program: /usr/bin/linuxcnc_info
uptime: 08:56:05 up 3 min, 1 user, load average: 1.44, 0.72, 0.30
lsb_release -sa: Debian Debian GNU/Linux 13 (trixie) 13 trixie
linuxcnc: /usr/bin/linuxcnc
pwd: /home/kris/linuxcnc/configs/my_mill
USER: kris
LOGNAME: kris
HOME: /home/kris
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1920x1080 pixels (509x286 millimeters)
PATH: /usr/bin:/home/kris/linuxcnc/configs/my_mill/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: debian
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT_RT Debian 6.12.48-1 (2025-09-20)
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-6.12.48+deb13-rt-amd64 root=UUID=5efc6035-1184-4e51-acb6-e99aeeac4490 ro quiet isolcpus=3
model name: Intel(R) N100
cores: 4
cpu MHz: 1744.606
parport:
serial:
Versions:
gcc: gcc (Debian 14.2.0-19) 14.2.0
python: Python 3.13.5
git: not_in_PATH
git commit: NA
tcl: 8.6
/usr/bin/linuxcnc_info: line 159: wish: command not found
tk:
glade: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.9.4
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /usr/lib/linuxcnc/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
PYTHON: /usr/bin/python3
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linuxcnc <none> <none> (no description available)
un linuxcnc-dev <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-en 1:2.9.4-2 all motion controller for CNC machines and robots (English documentation)
un linuxcnc-doc-es <none> <none> (no description available)
un linuxcnc-doc-fr <none> <none> (no description available)
un linuxcnc-sim <none> <none> (no description available)
un linuxcnc-sim-dev <none> <none> (no description available)
ii linuxcnc-uspace 1:2.9.4-2 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.9.4-2 amd64 PC based motion controller for real-time Linux
  • Aciera
  • Aciera's Avatar
21 Nov 2025 14:39
  • abs32
  • abs32
21 Nov 2025 13:41
v2.9 and not the perpendicularity of X and Y
Внес исправления как написал, скомпилировал, запустил = РАБОТАЕТ! Ай да Пушкин, ай да сукин сын!
Made corrections as written, compiled, launched = WORKS! Oh yes Pushkin,
  • meister
  • meister
21 Nov 2025 13:32
Replied by meister on topic Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
hatte meine 7i92 auch letzte woche bekommen,
hab nicht viel getestet, aber läuft soweit.
  • abs32
  • abs32
21 Nov 2025 13:16 - 21 Nov 2025 13:24
probably, this is influenced only by that part of ini where the formula XXYYZ and then something like that? -
// Apply inverse matrix transform to the 3 cartesian coordinates
pos->tran.x = invdet * ( (e * i - f * h) * j[0]
+(c * h - b * i) * j[2]
+(b * f - c * e) * j[4]);
pos->tran.y = invdet * ( (f * g - d * i) * j[0]
+(a * i - c * g) * j[2]
+(c * d - a * f) * j[4]);
pos->tran.z = invdet * ( (d * h - e * g) * j[0]
+(b * g - a * h) * j[2]
+(a * e - b * d) * j[4]);
    // Pass rest of axes as identity
    //if (EMCMOT_MAX_JOINTS > 3) pos->a = j[3];
    //if (EMCMOT_MAX_JOINTS > 4) pos->b = j[4];
    if (EMCMOT_MAX_JOINTS > 5) pos->c = j[5];
    if (EMCMOT_MAX_JOINTS > 6) pos->u = j[6];
    if (EMCMOT_MAX_JOINTS > 7) pos->v = j[7];
    if (EMCMOT_MAX_JOINTS > 8) pos->w = j[8];
// Apply matrix transform to the 3 cartesian coordinates
j[0] = pos->tran.x * a + pos->tran.y * b + pos->tran.z * c;
j[1] = pos->tran.x * a + pos->tran.y * b + pos->tran.z * c;
j[2] = pos->tran.x * d + pos->tran.y * e + pos->tran.z * f;
j[3] = pos->tran.x * d + pos->tran.y * e + pos->tran.z * f;
j[4] = pos->tran.x * g + pos->tran.y * h + pos->tran.z * i;
   // if (EMCMOT_MAX_JOINTS > 3) j[3] = pos->a;
    //if (EMCMOT_MAX_JOINTS > 4) j[4] = pos->b;
    if (EMCMOT_MAX_JOINTS > 5) j[5] = pos->c;
    if (EMCMOT_MAX_JOINTS > 6) j[6] = pos->u;
    if (EMCMOT_MAX_JOINTS > 7) j[7] = pos->v;
    if (EMCMOT_MAX_JOINTS > 8) j[8] = pos->w;
This is certainly not a one-size-fits-all solution with automatic situation recognition, but for a specific situation
  • abs32
  • abs32
21 Nov 2025 13:03 - 22 Nov 2025 10:12
  • Aciera
  • Aciera's Avatar
21 Nov 2025 13:02
  • Tinker
  • Tinker
21 Nov 2025 12:56
So I installed python3-pyqt5.qtquick and now it works !!!! Thank you sooo much!!
  • abs32
  • abs32
  • Ul
  • Ul
21 Nov 2025 12:52 - 21 Nov 2025 13:26
Category: Deutsch
Habe meine Mesakarten vorgestern erhalten, gestern getestet. Sowohl die 7i92, als auch die 7i98 funktionieren einwandfrei mit originaler Mesa Firmware. Auch die Busschalter funktionieren so, wie sie sollen (inkl. Pegelwandlerfunktion). Die Widerstände an den Pins sind externe pull-up Widerstände.
Bei der 7i92 ist es wichtig, die richtige ZIP-Datei herunterzuladen (für die 7i92H oder 7i92TH). 7i92t.zip lässt sich nicht flashen.
Wichtig zu wissen ist, dass der Fallback-Jumper nicht funktioniert.
Falls die Karte vom Raspberry nicht erkannt wird, muss man zuerst die Verbindung über die Konsole herstellen:
sudo ip addr add 10.10.10.11/8 dev eth0
sudo ip link set eth0 up
Ich bin mit dem Kauf jedenfalls so zufrieden, dass ich eine weitere 7i98 bestellt habe, diesmal in 7i92-Größe: de.aliexpress.com/item/1005010164826951.html
  • Tinker
  • Tinker
21 Nov 2025 12:43
Sorry, I'm a total beginner when it comes to this stuff. I'm at the copy and paste stage and don't really know what I'm looking for on that link...Is there a specific package I should download?
  • unknown
  • unknown
21 Nov 2025 12:35
Replied by unknown on topic Probe basic launch issue
Sorry I may have given the wrong package.
Have a look at this one.
packages.debian.org/trixie/amd64/python3-pyqt5.qtquick
Many apologies I was working from memory and apparently my memory was corrupted. I apologise for any time wasted.
Regarding the python errors if yo get a ModuleNotFoundError you can search for the name of the module that is stated as missing .
Displaying 10651 - 10665 out of 12725 results.
Time to create page: 0.556 seconds
