  • miro199315
  • miro199315
16 Nov 2025 21:54
Replied by miro199315 on topic Configuration Schnider electric ILA2 Servo
Category: EtherCAT
linuxcnc@linuxcnc:~$ ethercat -p 0 sdos upload 0x1600 0
'sdos' takes no arguments!
ethercat sdos [OPTIONS]
List SDO dictionaries.
SDO dictionary information is displayed in two layers,
which are indented accordingly:
1) SDOs - Hexadecimal SDO index and the name. Example:
SDO 0x1018, "Identity object"
2) SDO entries - SDO index and SDO entry subindex (both
hexadecimal) followed by the access rights (see
below), the data type, the length in bit, and the
description. Example:
0x1018:01, rwrwrw, uint32, 32 bit, "Vendor id"
The access rights are specified for the AL states PREOP,
SAFEOP and OP. An 'r' means, that the entry is readable
in the corresponding state, an 'w' means writable,
respectively. If a right is not granted, a dash '-' is
shown.
If the --quiet option is given, only the SDOs are output.
Command-specific options:
--alias -a <alias>
--position -p <pos> Slave selection. See the help of
the 'slaves' command.
--quiet -q Only output SDOs (without the
SDO entries).
Numerical values can be specified either with decimal (no
prefix), octal (prefix '0') or hexadecimal (prefix '0x') base.
  • miro199315
  • miro199315
16 Nov 2025 21:39
Category: EtherCAT
[17147.638691] EtherCAT 0: Released.
[17147.638692] EtherCAT DEBUG: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[17147.638697] EtherCAT DEBUG: 00 00 00 00
[17147.638699] EtherCAT ERROR 0-0: Failed to receive AL state datagram: Datagram initialized.
[17147.638702] EtherCAT DEBUG 0: Datagram 000000007305a9ff already queued (skipping).
[17147.653272] EtherCAT DEBUG 0-0: Changing state from PREOP to PREOP (forced).
[17147.653276] EtherCAT DEBUG 0-0: Configuring...
[17147.653587] EtherCAT DEBUG 0-0: Now in INIT.
[17147.653587] EtherCAT DEBUG 0-0: Clearing FMMU configurations...
[17147.653831] EtherCAT DEBUG 0-0: Clearing sync manager configurations...
[17147.654076] EtherCAT DEBUG 0-0: Clearing DC assignment...
[17147.654320] EtherCAT DEBUG 0-0: Configuring mailbox sync managers...
[17147.654321] EtherCAT DEBUG 0-0: SM0: Addr 0x1000, Size 1024, Ctrl 0x26, En 1
[17147.654323] EtherCAT DEBUG 0-0: SM1: Addr 0x1400, Size 1024, Ctrl 0x22, En 1
[17147.654565] EtherCAT DEBUG 0-0: Assigning SII access to PDI.
[17147.655300] EtherCAT DEBUG 0-0: Now in PREOP.
[17147.655301] EtherCAT DEBUG 0-0: Assigning SII access back to EtherCAT.
[17147.655559] EtherCAT DEBUG 0-0: Finished configuration.
[17147.673277] EtherCAT WARNING: Datagram 000000007305a9ff (master-fsm) was SKIPPED 1 time.
[17149.457536] EtherCAT DEBUG 0: IDLE -> ORPHANED.
[17149.457539] EtherCAT DEBUG 0: Stopping master thread.
[17149.457556] EtherCAT DEBUG 0: Master IDLE thread exiting...
[17149.457620] EtherCAT 0: Master thread exited.
[17149.457733] EtherCAT 0: Releasing main device 00:0B:AB:B6:75:75.
[17149.477426] ec_generic: Unloading.
[17149.532305] EtherCAT: Master module cleaned up.
[17150.618596] EtherCAT: Master driver 1.6.8 1.6.8
[17150.618712] EtherCAT: 1 master waiting for devices.
[17150.623226] ec_generic: EtherCAT master generic Ethernet device module 1.6.8 1.6.8
[17150.623234] EtherCAT: Accepting 00:0B:AB:B6:75:75 as main device for master 0.
[17150.623242] ec_generic: Binding socket to interface 2 (enp2s0).
[17150.641322] EtherCAT 0: Starting EtherCAT-IDLE thread.
[17150.641454] EtherCAT 0: Link state of ecm0 changed to UP.
[17150.653291] EtherCAT 0: 1 slave(s) responding on main device. Re-scanning on next possibility.
[17150.653294] EtherCAT 0: Slave states on main device: PREOP.
[17150.653295] EtherCAT 0: Re-scanning now.
[17150.653617] EtherCAT 0: Scanning bus.
[17150.834164] EtherCAT 0: Bus scanning completed in 180 ms.
[17150.834168] EtherCAT 0: Using slave 0 as DC reference clock.
[17161.960782] EtherCAT 0: Master debug level set to 1.
[17164.670125] EtherCAT: Requesting master 0...
[17164.670128] EtherCAT DEBUG 0: IDLE -> OPERATION.
[17164.670129] EtherCAT: Successfully requested master 0.
[17164.670131] EtherCAT DEBUG 0: ecrt_master_create_domain(master = 0x0000000069b184e5)
[17164.670133] EtherCAT DEBUG 0: Created domain 0.
[17164.670134] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x0000000069b184e5, alias = 0, position = 1, vendor_id = 0x0800005a, product_code = 0x000022db)
[17164.670136] EtherCAT DEBUG 0: Creating slave configuration for 0:1, 0x0800005A/0x000022DB.
[17164.670139] EtherCAT DEBUG 0 0:1: Failed to find slave for configuration.
[17164.670175] EtherCAT DEBUG 0 0:1: ecrt_slave_config_dc(sc = 0x000000008a2cea03, assign_activate = 0x0300, sync0_cycle = 1000000, sync0_shift = 0, sync1_cycle = 0, sync1_shift = 0
[17164.670179] EtherCAT DEBUG 0 0:1: ecrt_slave_config_sync_manager(sc = 0x000000008a2cea03, sync_index = 2, dir = 1, watchdog_mode = 0)
[17164.670182] EtherCAT DEBUG 0 0:1: ecrt_slave_config_pdo_assign_clear(sc = 0x000000008a2cea03, sync_index = 2)
[17164.670184] EtherCAT DEBUG 0 0:1: ecrt_slave_config_pdo_assign_add(sc = 0x000000008a2cea03, sync_index = 2, pdo_index = 0x1600)
[17164.670186] EtherCAT DEBUG 0 0:1: ecrt_slave_config_pdo_mapping_clear(sc = 0x000000008a2cea03, pdo_index = 0x1600)
[17164.670188] EtherCAT DEBUG 0 0:1: ecrt_slave_config_pdo_mapping_add(sc = 0x000000008a2cea03, pdo_index = 0x1600, entry_index = 0x6040, entry_subindex = 0x00, entry_bit_length = 16)
[17164.670191] EtherCAT DEBUG 0 0:1: ecrt_slave_config_pdo_mapping_add(sc = 0x000000008a2cea03, pdo_index = 0x1600, entry_index = 0x6060, entry_subindex = 0x00, entry_bit_length = 8)
[17164.670193] EtherCAT DEBUG 0 0:1: ecrt_slave_config_pdo_mapping_add(sc = 0x000000008a2cea03, pdo_index = 0x1600, entry_index = 0x607A, entry_subindex = 0x00, entry_bit_length = 32)
[17164.670195] EtherCAT DEBUG 0 0:1: ecrt_slave_config_pdo_mapping_add(sc = 0x000000008a2cea03, pdo_index = 0x1600, entry_index = 0x60FF, entry_subindex = 0x00, entry_bit_length = 32)
[17164.670197] EtherCAT DEBUG 0 0:1: ecrt_slave_config_sync_manager(sc = 0x000000008a2cea03, sync_index = 3, dir = 2, watchdog_mode = 0)
[17164.670199] EtherCAT DEBUG 0 0:1: ecrt_slave_config_pdo_assign_clear(sc = 0x000000008a2cea03, sync_index = 3)
[17164.670200] EtherCAT DEBUG 0 0:1: ecrt_slave_config_pdo_assign_add(sc = 0x000000008a2cea03, sync_index = 3, pdo_index = 0x1A00)
[17164.670202] EtherCAT DEBUG 0 0:1: ecrt_slave_config_pdo_mapping_clear(sc = 0x000000008a2cea03, pdo_index = 0x1A00)
[17164.670204] EtherCAT DEBUG 0 0:1: ecrt_slave_config_pdo_mapping_add(sc = 0x000000008a2cea03, pdo_index = 0x1A00, entry_index = 0x6041, entry_subindex = 0x00, entry_bit_length = 16)
[17164.670206] EtherCAT DEBUG 0 0:1: ecrt_slave_config_pdo_mapping_add(sc = 0x000000008a2cea03, pdo_index = 0x1A00, entry_index = 0x6061, entry_subindex = 0x00, entry_bit_length = 8)
[17164.670208] EtherCAT DEBUG 0 0:1: ecrt_slave_config_pdo_mapping_add(sc = 0x000000008a2cea03, pdo_index = 0x1A00, entry_index = 0x6064, entry_subindex = 0x00, entry_bit_length = 32)
[17164.670210] EtherCAT DEBUG 0 0:1: ecrt_slave_config_pdo_mapping_add(sc = 0x000000008a2cea03, pdo_index = 0x1A00, entry_index = 0x606C, entry_subindex = 0x00, entry_bit_length = 32)
[17164.670211] EtherCAT DEBUG 0 0:1: ecrt_slave_config_pdo_mapping_add(sc = 0x000000008a2cea03, pdo_index = 0x1A00, entry_index = 0x6077, entry_subindex = 0x00, entry_bit_length = 16)
[17164.670235] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x0000000069b184e5, alias = 0, position = 1, vendor_id = 0x0800005a, product_code = 0x000022db)
[17164.670238] EtherCAT DEBUG 0 0:1: ecrt_slave_config_reg_pdo_entry(sc = 0x000000008a2cea03, index = 0x6040, subindex = 0x00, domain = 0x00000000e562637d, bit_position = 0x00000000935bf368)
[17164.670240] EtherCAT DEBUG 0: Domain 0: Added 11 bytes, total 11.
[17164.670242] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x0000000069b184e5, alias = 0, position = 1, vendor_id = 0x0800005a, product_code = 0x000022db)
[17164.670244] EtherCAT DEBUG 0 0:1: ecrt_slave_config_reg_pdo_entry(sc = 0x000000008a2cea03, index = 0x6060, subindex = 0x00, domain = 0x00000000e562637d, bit_position = 0x00000000ac012020)
[17164.670246] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x0000000069b184e5, alias = 0, position = 1, vendor_id = 0x0800005a, product_code = 0x000022db)
[17164.670247] EtherCAT DEBUG 0 0:1: ecrt_slave_config_reg_pdo_entry(sc = 0x000000008a2cea03, index = 0x607A, subindex = 0x00, domain = 0x00000000e562637d, bit_position = 0x000000001f67561c)
[17164.670249] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x0000000069b184e5, alias = 0, position = 1, vendor_id = 0x0800005a, product_code = 0x000022db)
[17164.670251] EtherCAT DEBUG 0 0:1: ecrt_slave_config_reg_pdo_entry(sc = 0x000000008a2cea03, index = 0x60FF, subindex = 0x00, domain = 0x00000000e562637d, bit_position = 0x00000000adab25ff)
[17164.670253] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x0000000069b184e5, alias = 0, position = 1, vendor_id = 0x0800005a, product_code = 0x000022db)
[17164.670255] EtherCAT DEBUG 0 0:1: ecrt_slave_config_reg_pdo_entry(sc = 0x000000008a2cea03, index = 0x6041, subindex = 0x00, domain = 0x00000000e562637d, bit_position = 0x00000000ca53a04f)
[17164.670256] EtherCAT DEBUG 0: Domain 0: Added 13 bytes, total 24.
[17164.670258] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x0000000069b184e5, alias = 0, position = 1, vendor_id = 0x0800005a, product_code = 0x000022db)
[17164.670259] EtherCAT DEBUG 0 0:1: ecrt_slave_config_reg_pdo_entry(sc = 0x000000008a2cea03, index = 0x6061, subindex = 0x00, domain = 0x00000000e562637d, bit_position = 0x00000000a5c96db3)
[17164.670261] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x0000000069b184e5, alias = 0, position = 1, vendor_id = 0x0800005a, product_code = 0x000022db)
[17164.670263] EtherCAT DEBUG 0 0:1: ecrt_slave_config_reg_pdo_entry(sc = 0x000000008a2cea03, index = 0x6064, subindex = 0x00, domain = 0x00000000e562637d, bit_position = 0x0000000065407bda)
[17164.670265] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x0000000069b184e5, alias = 0, position = 1, vendor_id = 0x0800005a, product_code = 0x000022db)
[17164.670267] EtherCAT DEBUG 0 0:1: ecrt_slave_config_reg_pdo_entry(sc = 0x000000008a2cea03, index = 0x606C, subindex = 0x00, domain = 0x00000000e562637d, bit_position = 0x0000000094304504)
[17164.670269] EtherCAT DEBUG 0: ecrt_master_slave_config(master = 0x0000000069b184e5, alias = 0, position = 1, vendor_id = 0x0800005a, product_code = 0x000022db)
[17164.670270] EtherCAT DEBUG 0 0:1: ecrt_slave_config_reg_pdo_entry(sc = 0x000000008a2cea03, index = 0x6077, subindex = 0x00, domain = 0x00000000e562637d, bit_position = 0x00000000ca6b8c7f)
[17164.670281] EtherCAT DEBUG 0: ecrt_domain_external_memory(domain = 0x00000000e562637d, mem = 0x0000000053c8073c)
[17164.670282] EtherCAT DEBUG 0: ecrt_master_callbacks(master = 0x0000000069b184e5, send_cb = 0x000000000166930d, receive_cb = 0x00000000a879b1f0, cb_data = 0x0000000069b184e5)
[17164.670284] EtherCAT DEBUG 0: ecrt_master_activate(master = 0x0000000069b184e5)
[17164.670286] EtherCAT DEBUG 0: Adding datagram pair with expected WC 3.
[17164.670286] EtherCAT 0: Domain0: Logical address 0x00000000, 24 byte, expected working counter 3.
[17164.670288] EtherCAT 0:   Datagram domain0-0-main: Logical offset 0x00000000, 24 byte, type LRW.
[17164.670289] EtherCAT DEBUG 0: Stopping master thread.
[17164.670294] EtherCAT DEBUG 0: Master IDLE thread exiting...
[17164.670301] EtherCAT 0: Master thread exited.
[17164.670303] EtherCAT DEBUG 0: FSM datagram is 0000000086147210.
[17164.670303] EtherCAT 0: Starting EtherCAT-OP thread.
[17164.670332] EtherCAT DEBUG 0: Operation thread running with fsm interval = 4000 us, max data size=45000
[17164.670336] EtherCAT DEBUG 0: mmap()
[17164.670339] EtherCAT DEBUG 0: Vma fault, offset = 0, page = 000000002a6bf26c
[17164.709084] EtherCAT DEBUG 0: Configuration changed (aborting state check).
[17164.709087] EtherCAT DEBUG 0-0: Checking system time offset.
[17164.717079] EtherCAT DEBUG 0-0: DC 32 bit system time offset calculation: system_time=1033070246 (corrected with 8000000), app_time=816644270944702775, diff=-988527
[17164.717083] EtherCAT DEBUG 0-0: Not touching time offset.
[17164.725117] EtherCAT DEBUG 0: Requesting OP...
[17164.725120] EtherCAT DEBUG 0: After requesting OP, rescan_required is 0.
[17164.741097] EtherCAT DEBUG 0-0: Changing state from PREOP to OP.
[17164.741102] EtherCAT DEBUG 0-0: Configuring...
[17164.743878] EtherCAT DEBUG 0-0: Now in INIT.
[17164.743880] EtherCAT DEBUG 0-0: Clearing FMMU configurations...
[17164.744877] EtherCAT DEBUG 0-0: Clearing sync manager configurations...
[17164.745877] EtherCAT DEBUG 0-0: Clearing DC assignment...
[17164.746877] EtherCAT DEBUG 0-0: Configuring mailbox sync managers...
[17164.746878] EtherCAT DEBUG 0-0: SM0: Addr 0x1000, Size 1024, Ctrl 0x26, En 1
[17164.746880] EtherCAT DEBUG 0-0: SM1: Addr 0x1400, Size 1024, Ctrl 0x22, En 1
[17164.747878] EtherCAT DEBUG 0-0: Assigning SII access to PDI.
[17164.750882] EtherCAT DEBUG 0-0: Now in PREOP.
[17164.750883] EtherCAT DEBUG 0-0: Assigning SII access back to EtherCAT.
[17164.751879] EtherCAT DEBUG 0-0: SM2: Addr 0x1800, Size  22, Ctrl 0x64, En 1
[17164.751881] EtherCAT DEBUG 0-0: SM3: Addr 0x1C00, Size  24, Ctrl 0x20, En 1
[17164.754878] EtherCAT ERROR 0-0: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
[17164.755877] EtherCAT ERROR 0-0: AL status message 0x001E: "Invalid input configuration".
[17164.757879] EtherCAT 0-0: Acknowledged state PREOP.
  • Hakan
  • Hakan
16 Nov 2025 21:20 - 06 Mar 2026 08:42
Replied by Hakan on topic Configuration Schnider electric ILA2 Servo
Category: EtherCAT
"Invalid output configuration" means SM2 isn't configured correct. You ethercat-conf.xml now looks fine.
It can be that you may need to configure sm2 yourself using initcmds.
Let's investigate a bit first. Enable ethercat debug with "ethercat debug 1", try to start linuxcnc
and show the contents of syslog from that start attempt. There should now be more output in there.
Secondly, investigate what's in SM2.
Show the output of
ethercat -p 0 upload 0x1600 0
ethercat -p 0 upload 0x1600 1
ethercat -p 0 upload 0x1600 2
ethercat -p 0 upload 0x1600 3
... as many as the output of the first command says. It should say 4 I guess.
This output should match what you have in ethercat-conf.xml Index subIndx and length in 2+1+1 bytes,
like 0x60400010 for index 1. If one find that this mapping is wrong, one can download the wanted mapping.
And -p 0, the zero is the slave number of your servo.
  • tcbmetalworks
  • tcbmetalworks
16 Nov 2025 20:48
Looking for a freelancer to assist in drawing schematics for cnc plasma table
Category: User Exchange
Hello. I am looking for a free lancer who would be interested in drawing schematics for a cnc plasma table i am building and assisting in choosing the correct parts etc. My goals for the table is for it to be reliable against tough environments and have strength against interference. If someone is interested I can get them up to speed on the project. If someone is interested please reply here and we can exchange information.
  • miro199315
  • miro199315
16 Nov 2025 20:28 - 16 Nov 2025 20:29
Category: EtherCAT
File Name: ethercat-c...16-2.xml
File Size:1 KB
I actually mixed up the files earlier. Here is the proper configuration file I'm using now.
  • Hakan
  • Hakan
16 Nov 2025 18:24
Category: EtherCAT
Looks good so far. Those Unmatched might have been an EoE effect.
How come you put in those idx="0000" pdos in the ethercat-conf.xml?
I have never seen such before and that can't be right?
I would remove all those pdo idx="0000"
  • andypugh
  • andypugh's Avatar
16 Nov 2025 18:22
Replied by andypugh on topic carousel component integration
pin in signed scale = 100 "The number of stepgen or encoder counts between successive pockets";
This is likely to cause rounding errors when the number of encoder counts per pocket position is not an integer. You might need to convert the pin to "float" so that it can take a value of 682.6666666666666 (which means that the rounding error won't be noticed for several million full rotations of the carousel)
Luckily "carousel" is just an ordinary ".comp" file and so it can be re-installed after editing with halcompile.
sudo halcompile --install carousel.comp
If you get a "command not found" error then you may need to sudo apt get install linuxcnc-uspace-dev,
  • andypugh
  • andypugh's Avatar
16 Nov 2025 18:08
I think that carousel.scale needs to be 8192/12 = 682.666666666 (which is unfortunate, as there is a possibility of rounding errors.
The "width" is how many counts you can be away from the target and still consider the carousel to be aligned. On reflection I might have been able to think of a better name for it. But it corresponds to the "width" of the typical flag or proximity sensor used to detect carousel alignment.
Carousel can be configured in many different ways, and some setups simply don't require certain inputs and outputs.
  • andypugh
  • andypugh's Avatar
16 Nov 2025 17:57
  • andypugh
  • andypugh's Avatar
16 Nov 2025 17:31
Replied by andypugh on topic Subroutine error
Subroutine error
You might want to switch your Z axis round, so 0 is at the top and -300 at the bottom. Some CAM packages assume that G53 G0 Z0 is a safe retract.
  • andypugh
  • andypugh's Avatar
16 Nov 2025 17:29
Subroutine error
Thanks for saying what the problem was, I will try to file that one away in my mental list of causes of tool change errors.
  • gravedigger
  • gravedigger
16 Nov 2025 17:02
Replied by gravedigger on topic 7i96 with analog Spindle Servo
Category: Driver Boards
Thanks.
The circuit diagram is OK?
I'm using Output 5 for Spindle ON and a contactor with the emergency stop button circuit.
  • Aciera
  • Aciera's Avatar
16 Nov 2025 16:51 - 16 Nov 2025 16:52
  • abs32
  • abs32
16 Nov 2025 16:42
v2.9 and not the perpendicularity of X and Y
Thank you, the comments in the source code are much less detailed than in man (this is strange). It would be right to bring the man to the proper level. Thanks again. When I install 2.9.x I will publish detailed startup instructions.
Displaying 10981 - 10995 out of 12724 results.
Time to create page: 0.312 seconds
