  • Plasmanfm
  • Plasmanfm
02 Nov 2025 09:15 - 02 Nov 2025 09:24
Replied by Plasmanfm on topic MESA 7i76eu – I/O - Spannungsversorgung
Category: Deutsch
Wenn das Alarmsignal des Steppmotors nur 5 V liefert dann schalte doch mit dieser ein Relais das die 12 V Ein und Ausschaltet
und lege die 12 V auf den PIN
Juergen
  • Hakan
  • Hakan
02 Nov 2025 08:18
New ethercat / probe basic control for minimonster
Category: CNC Machines
Start with controlword, statusword, opmode and opmode-display.
  • 2tinker
  • 2tinker
02 Nov 2025 07:29
Replied by 2tinker on topic MESA 7i76eu – I/O - Spannungsversorgung
Category: Deutsch
Ich habe das Support Manual.
"The 7I76EU field inputs have a nominal input resistance of 10K Ohms to field power ground. 7I76EU inputs sense positive input voltages above a preset threshold. For best general purpose use, default input threshold is 50% of the field power supply voltage with 10% hysteresis. That is with a 24V field voltage an input must be brought to 60% of 24V= 14.4V to be sensed as high and then brought to 40% of 24V = 9.6V to be sensed as low.These accurate thresholds and hysteresis allow high speed field signal detection whilemaintaining excellent noise immunity."
So wie ich das verstehe müssten bei 12V mindestens 7,2V anliegen um ein "High"-Signal zu erhalten.
Damit komme ich ohne eine kleine Verstärkerschaltung nicht weiter.
Richtig?
Als Schrittmotor möchte ich gerne diese verwenden...
www.omc-stepperonline.com/ess-series-2-2...vdc-1000cpr-ess23-20
  • ihavenofish
  • ihavenofish
02 Nov 2025 02:42
Replied by ihavenofish on topic Mini wannabe datron build
wheeeee
  • Lcvette
  • Lcvette's Avatar
02 Nov 2025 02:32 - 02 Nov 2025 02:49
Please help at wits end with strange offset tool paths
Category: QtPyVCP
0.97mm calibration offset is HUGE, you have wrong going on there, that should just be the trigger distance of the probe. You should use a larger calibration object so you aren't in an acceleration state. The cal offset should be a really small number, 0.04-0.08mm for most decent mechanical hobby probes. The probe tip diameter must be entered into the tool table in the column. (I this is where you're issue is coming from and why your cal offset is so large. Use only fast probe feed rate (set slow probe feed to 0.000). Use something like 200mm/m fast probe feed rate.. Be sure to reset the offset prior to running calibration. Run in probe position only mode for calibration. Make sure your step of width is a decent amount past the edge, at least 10mm or so.
02 Nov 2025 02:28
Replied by tommylight on topic Hypertherm hsd130 interface
Category: Plasma & Laser
Whatever is the lowest you might use.
Last china one i had needed 3 turns to work reliably at 20A, and that was the lowest it could be set despite the knob being marked as 10A as well as showing 10A on the display. At 33A shown/set it would do 45A, and at 60A it would do 60A.
  • farmer_mike
  • farmer_mike
02 Nov 2025 02:24
RaspberryPi 4/5 Ethercat Rtelligent ECT60 Synchronization error
Category: EtherCAT
I haven’t run my ect60 drive for more than 30 minutes, so I haven’t seen this problem.
I appreciate all your documentation however. I’m also running a pi4b.
When you installed the Ethernet switch, did you maintain the series cabling for all the drives? Put another way, do you have just the pi and the first ect60 connected to the switch?
I wonder if a loop configuration using the Ethernet port on the pi, plus one more usb dongle Ethernet port would also solve the problem.
  • ffffrf
  • ffffrf
02 Nov 2025 02:17
Category: QtPyVCP
I probably worded the statement poorly - but the table, vise material column is 100% trammed with each other no question
I would just disregard that statement, what I meant was when I probe the corner the probe does appear to be in the correct location, at least close enough that if I brush the probe along that wall, the ball (whose central axis is now along X or Y) deflects enough to re-trigger, meaning the probe is fairly close to the true corner.
However, the easier statement is that when I compared the origins, the probed origin is around 0.815mm off the true corner (as compared to using a mechanical edge finder). So for some reason, when I use my probe, the origin that is recorded is 0.815mm AWAY or INTO the actual wall.
I use a dial test indicator to make sure the probe ball tip is concentric so its definitely not that.
Can there be some issue in probe-basic or linuxcnc that is not correctly applying the diameter? Or miscalibrated somehow internally but on the UI shows the correct value??
  • bentiggin
  • bentiggin
02 Nov 2025 02:08
Replied by bentiggin on topic Hypertherm hsd130 interface
I only tried at 45 amps. How low is worth testing?
  • unknown
  • unknown
02 Nov 2025 01:35 - 02 Nov 2025 01:52
Replied by unknown on topic mqtt-publisher
mqtt-publisher
Try this for the keys
keys=halui.axis.a.pos-feedback,halui.axis.b.pos-feedback,\
halui.axis.c.pos-feedback,halui.axis.u.pos-feedback,\
halui.axis.v.pos-feedback,halui.axis.w.pos-feedback,\
halui.axis.x.pos-feedback,halui.axis.y.pos-feedback,\
halui.axis.z.pos-feedback \
keys=halui.estop.is-activated, halui.joint.0.is-homed,\
halui.joint.1.is-homed,halui.joint.2.is-homed,halui.joint.3.is-homed,\
halui.joint.4.is-homed,halui.joint.5.is-homed,halui.joint.6.is-homed,\
halui.joint.7.is-homed,halui.joint.8.is-homed \
keys=halui.machine.is-on,halui.max-velocity.value,halui.mode.is-auto,\
halui.mode.is-manual,halui.mode.is-mdi,halui.mode.is-teleop,\
halui.program.is-running
I see what you mean, even when it starts with multiple key entries only the last group of keys get sent
02 Nov 2025 01:33
Category: QtPyVCP
also if I use the probe to probe the edge, then move to the origin and slide the probe across either X or Y wall of the metal at the 0 value for that axis, it does retrigger the probe, doesn't that mean the probe is functioning correctly and its a linuxcnc side issue?
No, from what i can gather it means the machine/table/material is not trammed properly.
Or what am i missing?
  • ffffrf
  • ffffrf
02 Nov 2025 01:09 - 02 Nov 2025 01:24
Category: QtPyVCP
Hey so I did another test - setting the origin manually with an edge finder makes it work as expected.
However, I can't for the life of me think of what the actual issue is in that case then? The probe calibration all looks correct, the diameter is set in the tool table.
When I compared the edge finder origin vs the probed origin, the probed origin is about 0.815mm off in each of the axis. The probe diameter is 1.95mm, calibration seems correct.
Do you think it is more likely a probe issue or a linuxcnc issue? Clearly the post processor/CAM is correct
I just can't think of anything mechanical with the probe being the actual issue
edit: My probe tip diameter is 2mm, when I do probe cal it says the probe cal offset is 0.97mm - and measures the circle as 5mm
EDIT2(MORE IMPORTANT): also if I use the probe to probe the edge, then move to the origin and slide the probe across either X or Y wall of the metal at the 0 value for that axis, it does retrigger the probe, doesn't that mean the probe is functioning correctly and its a linuxcnc side issue?
02 Nov 2025 00:44
Do you think using a reed switch would have much of an effect on pierce delay?
No, they are pretty fast but i can not recall the exact Ton/Toff time, it was 40 years ago when i started using them, but i am sure it is negligible.
You might have another issue, failing to trigger, so did you check that it does reliably trigger at lowest current setting?
  • Hendrixx
  • Hendrixx
02 Nov 2025 00:41
Replied by Hendrixx on topic Any progress on QTLazerC or
Category: Other User Interfaces
Once you get hypersensing figured out its a no brainer float switch is your backup, Hypersening allows you to probe surface so quick its scary, I use Hypersensing to set tool height offsets on my router had to modify the g38s with digita on offs to stop the probing erros i think theorically it is the most accurate method with known physics to measure that i have a isolated touchplate mounted to the machine and just set up my work offset with my probe then ehen every M6 asks to to load new tool it will check if then go to town untill i get ATC this is the best metod i could think up
Displaying 11656 - 11670 out of 12798 results.
Time to create page: 0.419 seconds
