  • SPH
  • SPH's Avatar
23 Oct 2025 02:17
Help with Delta E3 Ethercat drives - hal and ethercat-conf.xml
Category: EtherCAT
Thanks for the help! I've adjusted the file and get the attached error. Not sure what inputs I'd trim out.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.4
Machine configuration directory is '/home/cnc/linuxcnc/configs/sim.axis.gantry'
Machine configuration file is 'gantry.ini'
INIFILE=/home/cnc/linuxcnc/configs/sim.axis.gantry/gantry.ini
VERSION=1.1
PARAMETER_FILE=sim.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=XYZY
KINEMATICS=trivkins coordinates=XYZY kinstype=BOTH
Starting LinuxCNC...
emc/iotask/ioControl.cc 786: can't load tool table.
Found file(REL): ./ethercat.hal
Debug file information:
Note: Using POSIX realtime
LCEC: slave 0.D1: FAILURE: FAILURE: more input PDO entries configured than your hardware supports.
Axis 1 has 13 PDO entries, vs a configured limit of 8.  You will need to edit your XML
configuration and either remove some <modParam name="enable*"> entries or increase
<modParam name="ciaTxPDOEntryLimit">. Check your CiA 402 slave's hardware manual to determine the
correct limit.
Enabled features that impact this limit are:
  -  <modParam name="enableActualCurrent" value="true">
  -  <modParam name="enableActualFollowingError" value="true">
  -  <modParam name="enableActualTorque" value="true">
  -  <modParam name="enableErrorCode" value="true">
  -  <modParam name="enablePositionDemand" value="true">
  -  <modParam name="enableProbeStatus" value="true">
  -  <modParam name="enableTorqueDemand" value="true">
  -  <modParam name="enableVelocityDemand" value="true">
In addition, disabling unneeded CiA 402 modes may help, as some implicitly add additional PDO entries:
  -  <modParam name="enablePP" value="true">
  -  <modParam name="enablePV" value="true">
  -  <modParam name="enableCSP" value="true">
  -  <modParam name="enableCSV" value="true">
  -  <modParam name="enableCST" value="true">
  -  <modParam name="enableHM" value="true">
  -  <modParam name="enableTQ" value="true">
HAL: ERROR: thread 'servo-thread' not found
./ethercat.hal:3: addf failed
17208
Stopping realtime threads
Unloading hal components
  • Hakan
  • Hakan
23 Oct 2025 02:05
Category: EtherCAT
Those 2xxx sdo numbers are not universal and probably differ between your drive and rodw's.
Put the output of the command "lcec_configgen" into ethercat-conf.xml.
Modify the master line if needed and look over the naming of pins.
  • SPH
  • SPH's Avatar
23 Oct 2025 01:49
Category: EtherCAT
I've tried updating the first device in Rodw's .xml file with my drives id's as returned from ethercat-slaves and trimming the other devices out of the file. File is attached.Generates the following error when run.
  • SPH
  • SPH's Avatar
23 Oct 2025 01:40
Category: EtherCAT
Hoping I can get some help getting my new Delta E3 drives up and running.
I've done a fresh install on a mini pc with two realtek 2.5gb nics.
Followed all of the instructions in RodW's very helpful guide and have gotten as far as trying to get my drives setup in the ethercat-conf.xml file, at least that's where I think I'm at.
I ran lcnc for the first time and made a sim gantry setup to get a hal and ini file.
Added the ethercat.hal
added the link to the ethercat-conf.xml and downloaded the xml file from Rod's github.
My drive is powered on and in Ethercat mode.
When I run ethercat slaves from the command line I get the following info
cnc@CNC:~$ ethercat slaves
0  0:0  PREOP  +  0x000001dd:0x10306081
cnc@CNC:~$
Ethercat master returns the following
cnc@CNC:~$ ethercat master
Master0
  Phase: Idle
  Active: no
  Slaves: 1
  Ethernet devices:
    Main: 84:47:09:4b:f6:48 (attached)
      Link: UP
      Tx frames:   495013
      Tx bytes:    29781420
      Rx frames:   495012
      Rx bytes:    29781360
      Tx errors:   0
      Tx frame rate [1/s]:    120    122    121
      Tx rate [KByte/s]:      7.0    7.1    7.1
      Rx frame rate [1/s]:    120    122    121
      Rx rate [KByte/s]:      7.0    7.1    7.1
    Common:
      Tx frames:   675263
      Tx bytes:    40660804
      Rx frames:   675254
      Rx bytes:    40660264
      Lost frames: 9
      Loss rate [1/s]:          0      0      0
      Frame loss [%]:         0.0    0.0    0.0
  Distributed clocks:
    Reference clock:   Slave 0
    DC reference time: 0
    Application time:  0
                       2000-01-01 00:00:00.000000000
cnc@CNC:~$
I'm a little lost on how to progress from here though. Obviously rod's ethercat-config.xml file is setup for his devices and doesn't load for me. I get the following error report.
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.4
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=XYZY
Failed to execute SDO download: Input/output error
LCEC: slave 0.0: Failed to execute SDO download (0x2000:0x00, size 2, byte0=112, error -5, abort_code 06010002)
LCEC: failed to configure slave 0.0 sdo 2000:00
LCEC: slave 0.0: Failed to execute SDO download (0x2007:0x06, size 1, byte0=5, error -5, abort_code 06020000)
LCEC: failed to configure slave 0.0 sdo 2007:06
LCEC: slave 0.0: Failed to execute SDO download (0x2007:0x05, size 1, byte0=5, error -5, abort_code 06020000)
LCEC: failed to configure slave 0.0 sdo 2007:05
Failed to execute SDO download: Invalid argument
LCEC: slave 0.1: Failed to execute SDO download (0x2000:0x00, size 2, byte0=112, error -22, abort_code f67e76d4)
LCEC: failed to configure slave 0.1 sdo 2000:00
LCEC: slave 0.1: Failed to execute SDO download (0x2007:0x06, size 1, byte0=5, error -22, abort_code f67e76d4)
LCEC: failed to configure slave 0.1 sdo 2007:06
LCEC: slave 0.1: Failed to execute SDO download (0x2011:0x00, size 2, byte0=1, error -22, abort_code f67e76d4)
LCEC: failed to configure slave 0.1 sdo 2011:00
LCEC: slave 0.2: Failed to execute SDO download (0x2000:0x00, size 2, byte0=88, error -22, abort_code f67e76d4)
LCEC: failed to configure slave 0.2 sdo 2000:00
LCEC: slave 0.2: Failed to execute SDO download (0x2007:0x06, size 1, byte0=5, error -22, abort_code f67e76d4)
LCEC: failed to configure slave 0.2 sdo 2007:06
LCEC: slave 0.2: Failed to execute SDO download (0x2011:0x00, size 2, byte0=0, error -22, abort_code f67e76d4)
LCEC: failed to configure slave 0.2 sdo 2011:00
Failed to register PDO entry: No such file or directory
LCEC: master 0 PDO entry registration failed
LCEC: failure, clearing config
LCEC: exiting
LCEC: returning -EINVAL
lcec: rtapi_app_main: Invalid argument (-22)
./ethercat.hal:2: waitpid failed /usr/bin/rtapi_app lcec
./ethercat.hal:2: /usr/bin/rtapi_app exited without becoming ready
./ethercat.hal:2: insmod for lcec failed, returned -1
12547
Info report created by linuxcnc_info:
The file:    /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
     http://pastebin.com
in order to provide information about the linuxcnc
system and configuration.
                Date: Thu 23 Oct 2025 12:29:51 AEDT
            UTC Date: Thu 23 Oct 2025 01:29:51 UTC
        this program: /usr/bin/linuxcnc_info
              uptime: 12:29:51 up 1:27, 1 user, load average: 4.59, 4.92, 4.60
     lsb_release -sa: Debian Debian GNU/Linux 12 (bookworm) 12 bookworm
            linuxcnc: /usr/bin/linuxcnc
                 pwd: /home/cnc/linuxcnc/configs/sim.axis.gantry
                USER: cnc
             LOGNAME: cnc
                HOME: /home/cnc
              EDITOR:
              VISUAL:
            LANGUAGE: en_AU:en
                TERM: dumb
           COLORTERM:
             DISPLAY: :0.0
             DESKTOP: lightdm-xsession
        display size: 1920x1080 pixels (508x285 millimeters)
                PATH: /usr/bin:/home/cnc/linuxcnc/configs/sim.axis.gantry/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
         nodename -n: CNC
      kernel-name -s: Linux
      kernel-vers -v: #1 SMP PREEMPT_RT Debian 6.1.124-1 (2025-01-12)
          machine -m: x86_64
        processor -p: unknown
         platform -i: unknown
      oper system -o: GNU/Linux
/proc items:
             cmdline: BOOT_IMAGE=/boot/vmlinuz-6.1.0-30-rt-amd64 root=UUID=0f3a6e83-8d9a-4590-a5d4-e505f6df4f87 ro quiet
          model name: AMD Ryzen 7 5825U with Radeon Graphics
               cores: 8
             cpu MHz: 3594.461
             parport:
              serial:
Versions:
                 gcc: gcc (Debian 12.2.0-14) 12.2.0
              python: Python 3.11.2
                 git: git version 2.39.5
          git commit: NA
                 tcl: 8.6
                  tk: 8.6
               glade: not_in_PATH
linuxcnc_var all:
     LINUXCNCVERSION: 2.9.4
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
            REALTIME: /usr/lib/linuxcnc/realtime
                 RTS: uspace
          HALLIB_DIR: /usr/share/linuxcnc/hallib
              PYTHON: /usr/bin/python3
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                Version           Architecture Description
un  linuxcnc            <none>            <none>       (no description available)
un  linuxcnc-dev        <none>            <none>       (no description available)
un  linuxcnc-doc        <none>            <none>       (no description available)
ii  linuxcnc-doc-de     1:2.9.4           all          motion controller for CNC machines and robots (German documentation)
ii  linuxcnc-doc-en     1:2.9.4           all          motion controller for CNC machines and robots (English documentation)
ii  linuxcnc-doc-es     1:2.9.4           all          motion controller for CNC machines and robots (Spanish documentation)
ii  linuxcnc-doc-fr     1:2.9.4           all          motion controller for CNC machines and robots (French documentation)
ii  linuxcnc-ethercat   1.40.0.g8a607c0-0 amd64        LinuxCNC EtherCAT HAL driver
un  linuxcnc-sim        <none>            <none>       (no description available)
un  linuxcnc-sim-dev    <none>            <none>       (no description available)
ii  linuxcnc-uspace     1:2.9.4           amd64        motion controller for CNC machines and robots
ii  linuxcnc-uspace-dev 1:2.9.4           amd64        PC based motion controller for real-time Linux
  • Dumitrus
  • Dumitrus's Avatar
22 Oct 2025 23:57
Replied by Dumitrus on topic Spindle and VFD control in LINUXCNC
It's working! Thank you!
  • PCW
  • PCW's Avatar
22 Oct 2025 23:42 - 22 Oct 2025 23:42
Replied by PCW on topic Spindle and VFD control in LINUXCNC
Pin 17 on the parallel port activates the relay on the breakout board
That was a suggestion based on the fact that the VFD in your picture
is connected to the breakout boards relay contacts.
  • unknown
  • unknown
22 Oct 2025 23:23
Replied by unknown on topic 7i92H
7i92H
Actually the RPi5 seems to handle longer cables better than the RPi4. Only noticed when bench testing my Frankenstien boards.
Ethernet is definitely the go.
  • unknown
  • unknown
22 Oct 2025 23:21
Replied by unknown on topic Retrofitting a TANK!
Category: Show Your Stuff
Could do with some of them Down Under when our PM lets China invade.
22 Oct 2025 23:19
Replied by tommylight on topic 7i92H
7i92H
You sticking up for the RPi now ? ;)
No, not at all, just for what is right.
Despite me not liking RPI i do understand why humans are obsessed with it, still, ethernet is much better than SPI, and the only option if the other board is 15CM or more far away from RPI.
Sorry to the OP for derailing the thread, but the Ethernet comment really needs to be addressed.
+1
22 Oct 2025 23:13
Replied by tommylight on topic Retrofitting a TANK!
Posted another video, a compilation with only a smidge of editing, should be more coherent.
  • unknown
  • unknown
22 Oct 2025 23:09
7i92H
..... connection via ethernet seems a bit stupid.
Now why the hell would you say that ???
And, just in case, do not say "SPI is.... " as it is not.
  • Dumitrus
  • Dumitrus's Avatar
22 Oct 2025 23:02
So I have to connect pin 17 to the VFD? Thank you!
22 Oct 2025 22:50
7i92H
  • ShemJ
  • ShemJ's Avatar
22 Oct 2025 22:48
Step By Step Help Needed . EL8 Leadshine to PI 5
Category: EtherCAT
Hi Will, I am using the waveshare PCIe TO Gigabit ETH USB3.2 HAT+ which is working well and has some extra USB ports if needed. I was getting some power dropouts when using a 5v 3a power supply so be sure to use a 5v 5a one that works.
I’ve made some further progress and have probe basic working well. I might be able to help you out with the homing issues more directly.
unknown, I might be looking to test an Odroid H4+ and you seem to be the main proponent for them. I have had some slowness on the pi in a couple of cases with ethercat chatter to and from the drives and monitoring Ferror. But I think they’re just fine generally. Have you tried the H4+? I believe it has 2x 2.5gb intel I226-v NICs so avoids the realtek issue. Is there any other tweaking involved in getting them set up?
  • PCW
  • PCW's Avatar
22 Oct 2025 22:37 - 22 Oct 2025 22:46
Yes, typical VFDs have an analog 0 to 10V control method.
The breakout shown converts a PWM signal from the PC parallel
port to a 0 to 10V analog signal for the VFD.
Stepconf can set this up:
Displaying 12331 - 12345 out of 12816 results.
Time to create page: 1.290 seconds
