  • Japoo_Ness
  • Japoo_Ness
01 Sep 2025 12:27
Retrofitting a 3-axis VMC with DC servos - guidance needed
Category: Driver Boards
Hello again,
While checking availability, I noticed that in terms of cost and stock it might be more convenient to go with the 6i24, since it is currently available directly from Mesa USA. Otherwise, I would need to buy everything from Eurosurplus, which ends up being more expensive overall.
Could someone please confirm the main differences between the 6i25 and the 6i24? From what I see, the 6i24 has no limitations on its connectors, so in the future I could also leave an extra port available to add another servo control board if needed.
Thanks a lot for your help!
  • Aciera
  • Aciera's Avatar
01 Sep 2025 12:22
Replied by Aciera on topic LinuxCnc and Industrial Robot?
Category: CNC Machines
It is possible to use LinuxCNC to run cartesian (ie xyz) gcode on an industrial robot. However, since the planner has no information about the kinematics used and 'assumes' a cartesian joint/axes configuration you will not get uniform velocities over the robot's work space.
If accurate path velocities are important for your application then you are going to have a hard time using LinuxCNC with a manipulator.
01 Sep 2025 12:17
Building a 3-axis plasma table with mesa 7i96s, THCad-2 and nema23 steppers
Category: Show Your Stuff
Are the following components suitable for making a voltage divider? My plasma has a 1:1 arc output.
Yes.
I'm using a TH-CAD2 in combination with two resistors in series and a 0.1uF capacitor to absorb the voltage spikes. Am I doing this correctly?
Yes, but wire one resistor to each side of the arc voltage, not both on the same wire. That makes it much safer in case the cable is kicked somewhere on the way to electronics and lowers the interference caused by plasma source.
And you can skip the capacitor as it does work without it, but i like to have it as it smooths the voltage readout and subsequently the torch motion up/down while cutting, but it will limit a bit the reaction speed.
What happens if a voltage spike does occur? Will the capacitor fail?
Usually nothing, if the polarity is correct.
Can I connect the start arc and arc OK signals directly to the Mesa board, or is it better to use a relay to protect the mesa board?
Yes you can, 7i96S has two fully isolated outputs ( 4 and 5 i think, double check that), so no need for relay.
Can I route these signals to the plasma cutter through the same cable as the THC?
Yes, if the resistors are mounted inside or outside the plasma source, but close to the plasma source.
  • arijitdutta
  • arijitdutta
01 Sep 2025 11:55
Replied by arijitdutta on topic Problems with starting linuxcnc
The new power supply worked. No more such errors. Thanks!
I would like to add a fuse to the incoming +5v to the 7i96s. What rated fuse should i use for this?
  • Rookie0
  • Rookie0
01 Sep 2025 11:44
Replied by Rookie0 on topic Stepperonline A6-1000EC driver
Category: EtherCAT
# spindle.hal
# use cia402 comp.  link: https://github.com/dbraun1981/hal-cia402
loadrt cia402 names=cia-s
addf cia-s.read-all           servo-thread
addf cia-s.write-all          servo-thread
# value = resolution_servo_encoder ÷ 60
# if gearbox exists, then * reduction_ratio(input:ouput)
setp cia-s.velo-scale 800
net s-statusword      <= lcec.0.N.cia-statusword   => cia-s.statusword
net s-opmode-display  <= lcec.0.N.opmode-display   => cia-s.opmode-display
net s-drv-act-velo    <= lcec.0.N.actual-velocity  => cia-s.drv-actual-velocity
net s-controlword     <= cia-s.controlword         => lcec.0.N.cia-controlword
net s-opmode          <= cia-s.opmode              => lcec.0.N.opmode
net s-drv-target-velo <= cia-s.drv-target-velocity => lcec.0.N.target-velocity
net s-enable          <= spindle.0.on              => cia-s.enable
net s-velo-fb         <= cia-s.velocity-fb         => spindle.0.speed-in
net s-velo-cmd        <= spindle.0.speed-out       => cia-s.velocity-cmd
hope it helps.
  • russkinch
  • russkinch's Avatar
01 Sep 2025 11:14
Stepperonline A6-1000EC driver was created by russkinch
Category: EtherCAT
Hi again. I have sorted the power issue (manual was no help at all). Now, I have it set to Linuxcnc using ethercat. It is all communication etc. I want to run the servo as a spindle motor so just have the target-velocity (60FE). How do I create the 'pins' to tell the drive to turn at say 1000rpm with an M3 command is given. I have done the many times using a VFD (much easier but space and weight limits force me to use a servo).
I am soooo out of my depth here, any help is always hugely appreciated. (I have already looked through the various threads and found no help after hours of scrolling)
  • Japoo_Ness
  • Japoo_Ness
01 Sep 2025 11:07
Excellent, thanks again for the help. Now, looking at what @Andy mentioned, what would be the advantage of the 6i24-16 (I understand this is the one being referred to) over the 6i25? I see that it has more expansion possibilities for the future, but in terms of processing capability and other aspects, is there any difference?
From what I’ve checked, I think that with the 6i25, 7i77 and 7i74 I already have a very large working possibility. Also, I couldn’t find a way to use a 4th axis in the future with the 50-pin options, since they come with control for 4 analog servos, and I understand that one of them would have to be used for the spindle. That means I’d have to use one of the 6i24 configurations that allows 8 servos (which in my case seems unnecessary). So I’d like to know what would be the advantages of using a configuration with the 6i24.
@Tommy, thank you very much as well for your reply to Andy. I was checking which workstation models I could use with these configurations, and I noticed that the ones you mentioned are actually available here in my country (Argentina, which has a lot of issues with getting certain hardware). So thanks to both of you, I’ll keep researching the advantages and options.
  • Yippiekae
  • Yippiekae
01 Sep 2025 07:37
Fresh start with linuxCNC and Ethercat was created by Yippiekae
Hey !
I'm building a cnc mill with a german FS4GM epoxy granite gantry and a Spinogy X22 spindle. It's a small but rigid setup that I'd Iike to control with 400W servos, LinuxCNC and EtherCat.
Since I only ordered the mechanical parts+spindle, I still can avoid some problems (ie latency issues) by choosing the right things on the electronic/control/computer side. Hence this newbie message :
What servo/drivers/computer/other things-I-still-don't-know-about would you go if you had to get them again ?
Cheers,
Flo
  • arijitdutta
  • arijitdutta
01 Sep 2025 07:23
I hope a 5V 2A power supply will be enough for this work.
  • Daan96
  • Daan96
01 Sep 2025 07:23 - 01 Sep 2025 07:39
@tommylight
Sorry for the questions, but I'd like to get it right the first time. I'm not yet that good with various electrical components at a detailed level.
I've read through your other threads and I think I found the right info, thank you very much!!
I have another question.
  • arijitdutta
  • arijitdutta
01 Sep 2025 07:19
I will try changing the 5V power supply today and update back. Thanks..
  • GDTH
  • GDTH's Avatar
01 Sep 2025 06:27
Solved: Help with Busellato JET 2 spindle retrofit – VFD overload
Yesterday I tried running the VFD with a potentiometer, but had no luck. I experimented by slowly adjusting the frequency and changing some basic parameters to see if I could get any results. The only thing that seemed to have some effect was changing the V/f pattern.
  • GDTH
  • GDTH's Avatar
01 Sep 2025 06:24
Solved: Bitfile needed for 6i25 + 7i77 + Chinese BoB
Thanks! i got it running. i was able control the pins. Weirldy enough i was not able to get the stepgen running. i was not able to see anything on the oscilloscope. i did not plug the 12/24v as i thought it is not needed. I was able to pull both the dir and pulse pin high by inverting it.
Any tips are appreciated, gonna continue working on it tommorow
  • PCW
  • PCW's Avatar
01 Sep 2025 04:39
Replied by PCW on topic Problems with starting linuxcnc
The /DONE LED (CR7) lighting means a power cycle.
This suggests an issue with 5V power.
  • arijitdutta
  • arijitdutta
01 Sep 2025 03:54 - 01 Sep 2025 03:56
Problems with starting linuxcnc was created by arijitdutta
So i have been running 7i96s with my lathe for around a year now. It is running without any issues till a couple of days ago. I never do any kind of changes to hal or anything. I have been getting this error so much that it is almost unusable now. Upon starting the interface, 80% of the time, it ends up with an error. I have attached the debug file report for reference. 20% of the time it runs but within 5-10 minutes it shows "error finishing read iter = 957938" even during operations suddenly. I pinged my card and ran it for sometime, and saw some packet losses for reasons I dont know. Attached a picture for that too.When i startup, the PWR led stays on, others off. The cr6 and  cr7 blinks in turns sometimes during the error and when the packet loss happens and it doesnt turn off after that. Debug as follows:
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.3
Machine configuration directory is '/home/arijitdutta/linuxcnc/configs/lathe'
Machine configuration file is 'lathe.ini'
INIFILE=/home/arijitdutta/linuxcnc/configs/lathe/lathe.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XZ
KINEMATICS=trivkins coordinates=XZ
Starting LinuxCNC...
libnml/buffer/shmem.cc 320: Shared memory buffers toolCmd and toolCmd may conflict. (key=1004(0x3EC))
libnml/buffer/shmem.cc 320: Shared memory buffers toolSts and toolSts may conflict. (key=1005(0x3ED))
libnml/buffer/shmem.cc 320: Shared memory buffers emcError and emcError may conflict. (key=1003(0x3EB))
Found file(REL): ./lathe.hal
Running HAL shutdown script
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:16:88:df
hm2_eth: discovered 7I96S
hm2/hm2_7i96s.0: Low Level init 0.15
hm2/hm2_7i96s.0: Smart Serial Firmware Version 43
board fails HM2 registration
hm2_eth: in hm2_eth_reset
hm2: unloading
Debug file information:
Note: Using POSIX realtime
hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11)
./lathe.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./lathe.hal:9: /usr/bin/rtapi_app exited without becoming ready
./lathe.hal:9: insmod for hm2_eth failed, returned -1
7688
Stopping realtime threads
Unloading hal components
Displaying 13531 - 13545 out of 13759 results.
Time to create page: 0.956 seconds
