  • cakeslob
  • cakeslob
23 Jul 2025 20:47
Replied by cakeslob on topic Is mini still available?
Category: Other User Interfaces
I liked it also, after 2.7 it went to joints/axis(something like that) and mini was not maintained after that.
  • Ac1dburn
  • Ac1dburn
23 Jul 2025 20:15 - 23 Jul 2025 20:21
"Thread": "Servo",
"Type": "Digital Pin",
"Comment": "Index",
"Pin": "1.28",
"Mode": "Input",
"Invert": "True",
"Data Bit": 6
"Thread": "Servo",
"Type": "QEI",
"Comment": "spindle-encoder",
"Modifier": "Pull Up",
"PV[i]": 0,
"Data Bit": 2,
"Enable Index": "True"
well, maybe you dont need to use the preassigned index, you will find out i guess
[code]# Spindle QEI encoder
setp encoder.0.position-scale 800.000000
net encoder-count <= remora.PV.0 => encoder.0.raw_count
net encoder-phaseZ <= remora.input.6 => encoder.0.phase-Z
# setp encoder.0.index-enable true
i dont think you are connecting your spindle pins correctly thought. its waiting for the index enable probably
compare to this one
https://github.com/cakeslob/RRW_LAB/blob/inc/LinuxCNC/ConfigSamples/remora-RRW_LAB_latheng/remora-xyz.hal#L128
[/i][/code]
Awesome, yeah my hal was a mess. I ended up just grabbing that example and tweaking what I need to to have things make sense for my machine and I'm happy to say, everything is working now. Exactly how it should, and we have threads! Thanks again!
https://imgur.com/a/dP7VYhM
  • JPL
  • JPL
23 Jul 2025 19:59 - 07 Aug 2025 00:52
New Mesa cards for sale: 7i92 + 7i73
Category: User Exchange
I have 3 new Mesa cards for sale. I bought those as a spare for a project but never needed them. All three are brand new, never used.
Mesa 7i77:  $180.00 USD     Come with a free set of 2 new din rail adapter
Mesa 7i92   $  85.00 USD     Come with a free EPP-M parallel cable  (6 feet)
Mesa 7i73   $  40.00 US
Will ship USA lower 48 only
Shipping for 1 item: $10.00
Shipping for 2-3 items: $15.00
I will list on e-Bay if no interest here.
  • rubinstu
  • rubinstu
23 Jul 2025 19:31
Replied by rubinstu on topic Weird G54 orientation
Can you explain the "tool offsets...X and Y which is a bit unusual", please? The way I HAD been working was to (1) home my machine, (2) jog to the origin of my workpiece, (3) click the "touch off" button for x and y, (4) move my z to the the surface of my part and "touch off" z. (I also made a script with uses the tool setter for Z, but I'm leaving that out for this experiment.)
I don't think Fusion is setting G54.
@aciera thanks for the reply. I appreciate your comments!
  • Aciera
  • Aciera's Avatar
23 Jul 2025 18:35
Replied by Aciera on topic How to control brake before moving ?
Category: HAL
The usual reason for brakes on non-indexing axes is to avoid unwanted motion when a driver is disabled. So, my first question would be as to why the motors on your machine need to have the brake applied while the motor drive is enabled.
  • skunkworks
  • skunkworks
23 Jul 2025 18:29
Replied by skunkworks on topic Display motion.current-vel ?
Category: Plasmac
lol - never mind.. I think I found it.. I will test tonight..
If Use Auto Volts is checked then the actual cut voltage is sampled at the end of the THC Delay time and this is used as the target voltage to adjust the height of the torch.
If Use Auto Volts is not checked then the voltage displayed as Cut Volts in the MATERIAL section of the PARAMETERS Tab is used as the target voltage to adjust the height of the torch.
  • skunkworks
  • skunkworks
23 Jul 2025 18:25
Category: Plasmac
Short video
photos.app.goo.gl/sL9v2GkA7igL8KGU9
also - (I have just started using it and only have the 1 material in which is 1/4 inch. ) Made a sample program using conversational to get the jest of the gcode.
See below for the gcode I used as reference.
It uses tool 0 as far as I can tell - and as far as feed rate this seems correct - when I change tool 0's feed rate - it changes the programs feed rate.  OK..
But - I have the arc voltage set to 120.   When the program runs - the arc voltage is a constant 115.  I actually added 5v on the override so it actually shows 120 when cutting.
am I doing something wrong?
G20 G64P0.004 G40 G49 G80 G90 G92.1 G94 G97 (preamble)
(conversational circle)
;using material #0: Basic default Material
M190 P0
M66 P3 L3 Q1
f#<_hal[plasmac.cut-feed-rate]>
g0 x0.152304 y0.152304
m3 $0 s1
g2 x0.152304 y0.152304 i0.367696 j0.367696
m5 $0
G20 G64P0.004 G40 G49 G80 G90 G92.1 G94 G97 (postamble)
m2
  • skunkworks
  • skunkworks
23 Jul 2025 18:06
Display motion.current-vel ? was created by skunkworks
Category: Plasmac
Am I missing it?  Is there a way to display the current velocity of the machine while cutting?
Thanks!
BTW - Just setup Plasmac using pncconf - It was painless and QTPlasmac is a really nice gui.   No problems..  (mesa style board with thc10)
Great work!
sam
  • Cerezas
  • Cerezas
23 Jul 2025 16:38
Inverting jogging sense of X Axis on a VistaCNC P1A-S pendant
Category: HAL
Since this is for a lathe, there are only 2 joints in the HAL parameters. LinuxCNC requires that the joints are numbered from 0 consecutively, that is, I can only have joints 0 and 1. The association between joint 1 and the z axis is done in the HAL files. With that association, GCode works properly.
As I mentioned before, the pendant was jogging the X axis as I wanted in Step, Velocity and Continuous mode before I moved to the mesa card. I was using exactly the same vc-p1as.hal file as the one I'm trying to use now. Something very subtle changed and that's what I'm trying to figure out.
I tried debugging with halmeter and see what signals were triggered when I used the pendant, but that didn't help much. I'm still learning about the HAL.
Thanks once again for looking into this issue.
  • PCW
  • PCW's Avatar
23 Jul 2025 16:03
Replied by PCW on topic How to control brake before moving ?
Category: HAL
The gcode (M62,M63,M66) method with digital I/O will work for any motion but you need to change the gcode.
  • bladekel
  • bladekel
23 Jul 2025 15:35 - 23 Jul 2025 15:40
Replied by bladekel on topic How to control brake before moving ?
Category: HAL
The intended use is for indexing rotaries as described in this section:
linuxcnc.org/docs/stable/html/config/ini...:ini:sec:axis-letter
If you need more than just G0 moves then you would likely need to make something up in HAL.
I can only control the brake with G0 moves.
here is the way;
[EMCMOT]
EMCMOT = motmod unlock_joints_mask=0x08
[AXIS_A]
LOCKING_INDEXER_JOINT = 3
[JOINT_3]
LOCKING_INDEXER = 1
I have to control the brake for G0,G1,G2,G3 and manuel movements. Because that axis' motor has mechanical brake.
In any type of movement, brake is have to be deactivated and after the movement it has to be activated again.
Do you have any opinion else ? What else I have to try?
  • Aciera
  • Aciera's Avatar
23 Jul 2025 15:23
Category: HAL
  • RotarySMP
  • RotarySMP's Avatar
23 Jul 2025 14:42
Replied by RotarySMP on topic Un-lobotomizing a Maho MH600T
Category: CNC Machines
Nice work you have done on that DIY EXE, with DIN rail mounting.
  • jjdege
  • jjdege's Avatar
23 Jul 2025 14:18
Replied by jjdege on topic Axis and tool length sensor troubles
Check the Z travel to reach the probe in the .ini file.
[TOOLSENSOR]
MAXPROBE = XXX
  • JT
  • JT's Avatar
23 Jul 2025 13:32
Replied by JT on topic Is mini still available?
buildbot.linuxcnc.org/dists/
is debs you can see if your OS is there and 2.7 is built for that OS version.
JT
Displaying 13861 - 13875 out of 14618 results.
Time to create page: 0.564 seconds
