  • jjdege
  • jjdege's Avatar
03 May 2025 15:55 - 03 May 2025 21:34
Hi guys
I couldn't resist and bought a new board, this time I opted for a 3-axis EC500,
it has LEDs that indicate the I/O status, I think it's more complete.
I tested it with Mach3 to make sure it was working well, given the previous ones,
and it worked on all three axes.
When loading the firmware, it got to 29% and timed out and everything froze,
the DAP wasn't receiving signals.
I reread page 115 of the thread that talks about how to unlock and after having
bridged BOOT_MO and 3V3 I managed to delete and write the new firmware!!
Now all 6 axes work.
Thanks again to Scott and to whoever made all this possible.
Hi
I connected to a small laser gantry structure the EC500 with Remora
and a small demo video .
I have to say it works great!!!
Thanks!
  • xlordofpainx
  • xlordofpainx
03 May 2025 15:54
Replied by xlordofpainx on topic mechanical limits switches wiring for 7i96s MESA
THANKS!!! WORKS!
Now i understand, because they are isolated you need to connect the common pin to a GND reference point to the voltage that will be applied to the input 1-11 pins. I connected everything as you said and it works flawlessly. !!!!
This feels like a bigger achievement than getting my Master's degree haha.
  • PCW
  • PCW's Avatar
03 May 2025 15:33
The isolated inputs will not work as expected unless you connect the
input common (TB3 pin 12)
For sinking inputs (pullup to a positive voltage to activate), input common should be
connected to  GND/power common. If you are using 5V from the 7I96S, this is the
stepgen connector GND.
And yes if you use a 24V supply and sinking inputs, the 7I96S input common would
connect to the 24V supply common (negative)
  • xlordofpainx
  • xlordofpainx
03 May 2025 15:04
Thank you very much.
I don't understand how this is different from what I am trying. here is the setup:
Switch NC to 5V from one of the pins (would it be okay to plug it in the stepper motor DC 24 power supply?)
Switch C to PIN 1 TB3.
IN this case I am missing the TB3 common pin - will it work if I connect it to the GND from the MESA where I am getting the 5V will it work? It is not working as it is right now.
Eitherway if you say it is safe I will connect the DC power supply 24V to the limit switch NC then C switch to TB3 pin and I can connect the Common TB12 pin to the Power supply DC GND.
  • PCW
  • PCW's Avatar
03 May 2025 14:40 - 03 May 2025 14:48
If you use NC limit switch contacts and sinking inputs, wiring would be:
7I96S input common (TB3 pin 12) = GND (24V common)
+24V --> Limit-Switch C --> Limit-Switch NC --> 7I96S Input (TB3 pin 1 through 11)
In hal, the input must be inverted.
You can use 5V instead of 24V but it's not as reliable long term with mechanical switches
  • Roger S
  • Roger S
03 May 2025 14:35
Replied by Roger S on topic Using POSIX realtime
Category: EtherCAT
The following results:
- ip a returns the result that the adapter is running without errors:
enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP
- the permissions are also correct:
crwxrwxrwx 1 root root 238, 0  3. Mai 16:22 /dev/EtherCAT0
nevertheless the link is DOWN and I cannot start a test configuration
Debug file information:
Note: Using POSIX realtime
Failed to reserve master: No such device
LCEC: requesting master 0 (index 0) failed
LCEC: failure, clearing config
LCEC: exiting
LCEC: returning -EINVAL
lcec: rtapi_app_main: Invalid argument (-22)
./axis_mm.hal:3: waitpid failed /usr/bin/rtapi_app lcec
./axis_mm.hal:3: /usr/bin/rtapi_app exited without becoming ready
./axis_mm.hal:3: insmod for lcec failed, returned -1
2306
Stopping realtime threads
Unloading hal components
  • PCW
  • PCW's Avatar
03 May 2025 14:33
Drive enbale active low - simple but yet it won´t do
OK, that's opposite of what the 7I77 enables do (they are on when enabled)
Probably easiest is to add a external relay, driven by a field I/O output
and wire the NC relay contacts to all drive enables.
  • xlordofpainx
  • xlordofpainx
03 May 2025 13:29 - 03 May 2025 14:33
hey i am having some trouble wiring switches to the board here is what I tried:
I am using pnc conf
I read that the inputs are opticallyisolated so I can put a lot of voltage on the input pins (haven't tried yet only 5v)
the mechanical switchers have NC NO and C
I tried connecting NC to 5V and V to pin1 doesn't stop during homing
inverting just began the turn on with an error about the switch limit
I tried connecting NC to GND and V to pin1 doesn't stop during homing
I tried connecting NO to 5V and V to pin1 doesn't stop during homing
I tried connecting NO to GNFand V to pin1 doesn't stop during homing
FInally i tried attaching NC to 5V, NO to GND and C to pin one and it worked but then the mesa card would get restarted ( apparently its shorting something when i hold the button too long
i saw some other people connecting NC to 24V and then to pin 1, but it should work with 5V as well and it doesn't. i tried pin 0 as well in case the pin was not working.
i am getting the 5V and gnd from the STEP 3 pins.
I am very interested what exactly is it that I am doing wrong.
THanks
  • SanzuiWorks
  • SanzuiWorks's Avatar
03 May 2025 13:16 - 09 May 2025 16:28
Replied by SanzuiWorks on topic Manual Toolchange + Abs Z Probe (QtDragon)
Category: Qtvcp
I created a diagram so that the offset value can be visually confirmed.
  • Groovecooper1
  • Groovecooper1's Avatar
03 May 2025 12:56 - 03 May 2025 13:48
Replied by Groovecooper1 on topic Need help with Linux 2.5 on a CNC lathe
Yes, the machine is on, it jogs and the icon for homing is grayed out, when I get to my shop next week I will upload pictures. Absolutely appreciate you guys are really awesome. Super helpful and responsive! Much appreciated! If there’s anyone in this forum that is for hire, let’s talk.
  • Rocky
  • Rocky
03 May 2025 12:30
Replied by Rocky on topic Hi everyone
Hi everyone
Got it to home but had to change the end stops to just home not home/min, I'll post up my files once I drag the pc upstairs to give it internet, I'm sure there is lots to still fix and do
  • SanzuiWorks
03 May 2025 12:05 - 16 May 2025 07:02
Manual Toolchange + Abs Z Probe (QtDragon) was created by SanzuiWorks
Category: Qtvcp
I'd like to share a structured and slightly modified version of `qt_auto_probe_tool.ngc` I'm using on my self-built 3-axis CNC with LinuxCNC 2.9.3 and the QtDragon GUI.
### ? My Goals:
- Separate tool length offset from work coordinate systems (WCS)
- Make the tool table intuitive and readable
- Ensure safe and efficient probing using machine coordinates
#### 1. Set the Probe Top:
I defined the probe top using the tip of the spindle body (with no tool/collet) as a consistent mechanical reference.
- For example, if the empty spindle is lowered to Z = -120 (machine coordinates), I input `-120` as PROBE HT in the QtDragon Probe tab.(I know this is not the intended use.)
- I do not use BLOCK HT at all.
#### 2. Define Work Coordinates:
Once a tool is mounted (e.g., Tool #1 with 30mm protrusion), I:
- Add `T1 Z30` into the tool table
- Set up the G54 (or other WCS) normally
This way, the tool length stored in the table is actual physical protrusion and independent from any WCS — much more intuitive for manual tool changers.
Use G43 to apply the offset.
- Tool table values are stable and logical (they represent actual tool lengths).
- Easy to estimate and input values for new tools before probing.
- Tool probing uses machine coordinates, so:
  - Probe start position can be calculated from tool length
  - No dependency on current WCS
  - Safer: if tool table Z is negative by mistake, start offset is clamped to zero
- Multi-WCS workflows (G54, G55...) work seamlessly — no need to re-probe per WCS
- Tool probing is simpler and can be single-pass since start is close
Thanks,
SanzuiWorks
  • andypugh
  • andypugh's Avatar
03 May 2025 11:30
  • dannym
  • dannym
03 May 2025 11:20
Resetting A-axis was created by dannym
Resetting A-axis
Category: G&M Codes
I did some manual G-code to use a 4th axis rotary basically like a lathe.  The A axis doesn't have a homing switch.  It advances a specified number of turns as the X and Y does its thing.
Part gets changed out, repeat.
What's the correct G-code to reset the A axis?  Numerically, it's spooled up like 1000 turns in one direction.  Moves aren't relative and I don't need the thing to unspool 1000 turns to get back to the absolute A-axis value the next G-code run will start at.
  • andypugh
  • andypugh's Avatar
03 May 2025 10:20
Replied by andypugh on topic Need help with Linux 2.5 on a CNC lathe
So, does it not respond to the home button? Is the home button greyed out?
Does it jog? Are the motors locked or free?
Displaying 16291 - 16305 out of 17066 results.
Time to create page: 0.455 seconds
