Using POSIX realtime
27 Apr 2025 13:00 #327145 by Roger S
Using POSIX realtime was created by Roger S
Hello everyone,
i have completed the Ethercat installation according to rodw
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
The installation went smoothly and the final test was positive:Component Pins:
Owner   Type  Dir         Value  Name
     4  u32   OUT    0x00000001  lcec.conf.master-count
     4  u32   OUT    0x00000004  lcec.conf.slave-count
The following version of Linuxcnc is installed:
6.1.0-30-rt-amd64 #1 SMP PREEMPT_RT Debian 6.1.124-1 (2025-01-12) x86_64 GNU/Linux
When I check if /sys/kernel/realtime exists, I get /sys/kernel/realtime
When I check the module cia 402 (halcmd loadrt cia402 count=1), I get Using POSIX realtime
Am I wrong as a layman if I assume that this is not real real time and that there may be problems with some modules?
27 Apr 2025 13:21 #327151 by tommylight
Replied by tommylight on topic Using POSIX realtime
That is correct.
The following user(s) said Thank You: Roger S
27 Apr 2025 13:29 #327153 by Roger S
Replied by Roger S on topic Using POSIX realtime
thank you very much tommylight
27 Apr 2025 14:00 #327158 by tommylight
You are welcomed, always.
02 May 2025 15:15 #327509 by Roger S
I need to reopen this topic. The installation went smoothly as described above. After reinstalling the system, I can no longer access the EK1100 (it worked before). I've spent hours searching for the error, but to no avail. What I noticed is that the EtherCAT master always has the status "Link DOWN."
Master0
  Phase: Waiting for device(s)...
  Active: no
  Slaves: 0
  Ethernet devices:
    Main: 80:ee:73:fd:0f:8b (waiting...)
      Link: DOWN
      Tx frames:   0
      Tx bytes:    0
      Rx frames:   0
      Rx bytes:    0
      Tx errors:   0
      Tx frame rate [1/s]:      0      0      0
      Tx rate [KByte/s]:      0.0    0.0    0.0
      Rx frame rate [1/s]:      0      0      0
      Rx rate [KByte/s]:      0.0    0.0    0.0
    Common:
      Tx frames:   0
      Tx bytes:    0
      Rx frames:   0
      Rx bytes:    0
      Lost frames: 0
      Loss rate [1/s]:          0      0      0
      Frame loss [%]:         0.0    0.0    0.0
  Distributed clocks:
    Reference clock:   None
    DC reference time: 0
    Application time:  0
                       2000-01-01 00:00:00.000000000
Could this also be the reason why no master is found when starting a test configuration?
The EK 1100 is powered and the network is connected. Is there something wrong with the network configuration?
02 May 2025 19:23 #327535 by andypugh
Replied by andypugh on topic Using POSIX realtime
The things that can be displayed are:
Using POSIX non-realtime (this is bad)
Using Posix reatlime (this is fine, it means that you are using a preempt-rt kernel)
Using LXRT realtime (this is fine too, but is pretty rare, it means you are using LinuxCNC-uspace with an RTAI or Xenomai kernel)
<Nothing> Probably means that you are using RTAI, which is also fine.
03 May 2025 06:48 #327586 by Roger S
I think the installation is fine. The system reports POSIX realtime, and the pins for testing are accessible:
When I now call EtherCAT Master, the system reports:
Master0
Active: no
Slaves: 0
Ethernet devices:
Link: DOWN
The network adapter is correctly entered in Ethercat.conf:
MASTER0_DEVICE="80:ee:73:fd:0f:8b"
DEVICE_MODULES="generic"
The permissions are also correct:
'KERNEL=="EtherCAT[0-9]", MODE="0777"'
However, I can no longer access the EK1100. The EK is connected to the network and shows no errors. As mentioned, everything worked fine with the same components before the reinstallation.
03 May 2025 07:12 #327588 by Hakan
Replied by Hakan on topic Using POSIX realtime
Looks like your network adapter is not upped correctly. The master can't access ethernet.
Check "ip a", it should say UP for the adapter but I guess it won't.
Follow one of the standard debian guides to bring it up, will involve the /etc/network/interfaces file.
Can be a permission problem, check "ls  -l /dev/EtherCAT0" should say crwxrwxrwx
Try with "sudo service ethercat restart"
Also check "sudo dmesg" the last say 50 lines for anything that can help.
03 May 2025 14:35 #327600 by Roger S
The following results:
- ip a returns the result that the adapter is running without errors:
enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP
- the permissions are also correct:
crwxrwxrwx 1 root root 238, 0  3. Mai 16:22 /dev/EtherCAT0
nevertheless the link is DOWN and I cannot start a test configuration
Debug file information:
Note: Using POSIX realtime
Failed to reserve master: No such device
LCEC: requesting master 0 (index 0) failed
LCEC: failure, clearing config
LCEC: exiting
LCEC: returning -EINVAL
lcec: rtapi_app_main: Invalid argument (-22)
./axis_mm.hal:3: waitpid failed /usr/bin/rtapi_app lcec
./axis_mm.hal:3: /usr/bin/rtapi_app exited without becoming ready
./axis_mm.hal:3: insmod for lcec failed, returned -1
2306
Stopping realtime threads
Unloading hal components
03 May 2025 16:11 #327606 by Hakan
The ethercat master doesn't have the right contact with the network interface.
Do "sudo service ethercat restart" and show here the lines from "sudo dmesg" from this restart, some 30 lines or so, check time.
Time to create page: 0.406 seconds
