Using POSIX realtime
03 May 2025 16:30 #327607 by Roger S
Replied by Roger S on topic Using POSIX realtime
Thank you very much Hakan, I have attached the result as a file
File Name: dmesg.txt
File Size:54 KB
03 May 2025 18:01 #327616 by Hakan
Replied by Hakan on topic Using POSIX realtime
It's on the right track but I wonder how to pin-point exact reason and solution.
I have seen spelling mistakes cause this, but yours seems fine.
Can be the old network driver not unloading.
It's along those lines, the master can not get control over the network interface.
Can you set debug "ethercat debug 1", restart the ethercat server and show the dmesg again?
03 May 2025 18:18 #327621 by Roger S
I can't enable debug mode. Could this be part of the problem?
roger@roger:~$ echo 1 | sudo tee /sys/module/ethercat/parameters/debug
[sudo] Passwort für roger:
tee: /sys/module/ethercat/parameters/debug: Datei oder Verzeichnis nicht gefunden
1
roger@roger:~$ sudo modprobe -r ethercat
modprobe: FATAL: Module ethercat not found.
roger@roger:~$ sudo systemctl stop ethercat
03 May 2025 21:08 #327635 by Hakan
Just type the command "ethercat debug 1"
04 May 2025 12:41 #327673 by Roger S
I tried again and hope it is now correct
File Name: dmesg_2025-05-04.txt
File Size:54 KB
04 May 2025 13:02 #327675 by Hakan
Yes debug is switched on. But restart the master "sudo service ethercat restart" so one can see messages from the startup of the server and hopefully figure out why it doesn't take control over the network interface.
04 May 2025 14:54 #327680 by Roger S
I did the following:
ethercat debug 1
sudo dmesg
The log file says the following:
[    5.747038] ec_master: loading out-of-tree module taints kernel.
[    5.748211] ec_master: module verification failed: signature and/or required key missing - tainting kernel
[    5.765973] EtherCAT: Master driver 1.6.4 1.6.4.g703b611-1+17.1
[    5.766146] EtherCAT: 1 master waiting for devices.
is that the problem?
File Name: dmesg_2025...04-2.txt
File Size:54 KB
04 May 2025 15:16 - 04 May 2025 15:20 #327683 by Hakan
Mine looks like
[    3.850145] EtherCAT: 1 master waiting for devices.
[    3.868627] ec_generic: EtherCAT master generic Ethernet device module 1.6.3 1.6.3.g805e407-1+15.3
[    3.868649] EtherCAT: Accepting C4:62:37:06:66:54 as main device for master 0.
[    3.868658] ec_generic: Binding socket to interface 4 (enp2s0).
[    3.892744] EtherCAT 0: Starting EtherCAT-IDLE thread.
so my installation goes on and loads the ec_generic module from igh ethercat.
And thinking of your "tainted kernel" message, do you actually have the ethercat network drivers installed?
I search for them here and find them as below
debian@plasma:~$ find / -type f -name ec_gener\* -ls 2>/dev/null
 14316846     20 -rw-r--r--   1 root     root        20333 apr  3 09:42 /usr/lib/modules/6.1.0-32-rt-amd64/updates/dkms/ec_generic.ko
 20982238     24 -rw-r--r--   1 root     root        24213 apr 16 12:24 /var/lib/dkms/ethercat-dkms/1.6.3/6.12.0-rc7-rt8/x86_64/module/ec_generic.ko
 21235711     24 -rw-r--r--   1 root     root        24397 apr 17 08:30 /var/lib/dkms/ethercat-dkms/1.6.3/6.14.0-rt8/x86_64/module/ec_generic.ko
 20982170     20 -rw-r--r--   1 root     root        20333 apr  3 09:42 /var/lib/dkms/ethercat-dkms/1.6.3/6.1.0-32-rt-amd64/x86_64/module/ec_generic.ko
Last edit: 04 May 2025 15:20 by Hakan. Reason: Wider search for ec_generic
04 May 2025 15:28 #327684 by Roger S
I performed the installation according to the instructions from rodw
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
04 May 2025 16:05 #327691 by Hakan
Search for the ec_generic.so files like  I did.
Time to create page: 0.353 seconds
