Using POSIX realtime
07 May 2025 15:13 #327949 by Roger S
Replied by Roger S on topic Using POSIX realtime
this is the result:
35375     20 -rw-r--r--   1 root     root        20333 Mai  5 16:57 /usr/lib/modules/6.1.0-34-rt-amd64/updates/dkms/ec_generic.ko
  7093046     20 -rw-r--r--   1 root     root        20333 Mai  5 16:55 /usr/lib/modules/6.1.0-30-rt-amd64/updates/dkms/ec_generic.ko
   526822     20 -rw-r--r--   1 root     root        20333 Mai  5 16:57 /var/lib/dkms/ethercat-dkms/1.6.4/6.1.0-34-rt-amd64/x86_64/module/ec_generic.ko
   526812     20 -rw-r--r--   1 root     root        20333 Mai  5 16:55 /var/lib/dkms/ethercat-dkms/1.6.4/6.1.0-30-rt-amd64/x86_64/module/ec_generic.ko
08 May 2025 06:18 - 08 May 2025 06:19 #327980 by Hakan
Replied by Hakan on topic Using POSIX realtime
I guess you installed ethercat-dkms, the modules seem to be generated a couple of days ago.
It works now?
If it doesn't I would say to reinstall ethercat master and the drivers
sudo apt remove ethercat-master ethercat-dkms
sudo apt install ethercat-master ethercat-dkms
# edit /etc/ethercat.conf again
and make sure that the rather lengthy part where the modules are being built for the kernel succeeds.
Last edit: 08 May 2025 06:19 by Hakan.
08 May 2025 17:45 #328022 by Roger S
Unfortunately, it still doesn't work. I've since reinstalled the system, but there's no improvement. I don't understand it. The system worked before the reinstallation. I performed the installation according to the instructions. Anything else isn't possible for me anyway, as I'm just a user and don't know enough to try anything myself.
[  100.533257] EtherCAT: Master module cleaned up.
[  101.670667] EtherCAT: Master driver 1.6.4 1.6.4.g703b611-1+17.1
[  101.670804] EtherCAT: 1 master waiting for devices.
Master0
  Phase: Waiting for device(s)...
  Active: no
  Slaves: 0
  Ethernet devices:
    Main: 80:ee:73:fd:0f:8b (waiting...)
      Link: DOWN
the only thing I noticed:
8.198677] ec_master: module verification failed: signature and/or required key missing - tainting kernel
08 May 2025 18:41 - 09 May 2025 06:17 #328025 by Hakan
There is something odd with your installation.
I just tried myself to "apt remove ethercat-master ethercat-dkms" followed by "apt install ethercat-master ethercat-dkms" and it worked just fine.
I do not get the "tainted kernel" message.
Can it be that you have compiled the ethercat master yourself at one point? And that the runnning ethercat master is looking for ec_generic in a place where it isn't?
It's a bit of guesswork and searching now.
Can you the command "sudo service ethercat status" and compare the ouput with mine?
debian@plasma:~$ sudo service ethercat status
● ethercat.service - EtherCAT Master Kernel Modules
     Loaded: loaded (/lib/systemd/system/ethercat.service; enabled; preset: enabled)
     Active: active (exited) since Thu 2025-05-08 20:32:57 CEST; 7min ago
    Process: 78578 ExecStart=/usr/sbin/ethercatctl start (code=exited, status=0/SUCCESS)
   Main PID: 78578 (code=exited, status=0/SUCCESS)
        CPU: 25ms
maj 08 20:32:57 plasma systemd[1]: Starting ethercat.service - EtherCAT Master Kernel Modules...
maj 08 20:32:57 plasma systemd[1]: Finished ethercat.service - EtherCAT Master Kernel Modules.
Edit. Can you also repeat the search for ec_generic, but this time search for ec_master, in the same way?
Edit 2. No need to search. Instead show the output of the command "sudo modinfo ec_master", especially the first filename line.
Last edit: 09 May 2025 06:17 by Hakan. Reason: Ask to search for ec_master
09 May 2025 11:56 #328059 by Roger S
Hello Hakan
Here are the results of both checks:
sudo service ethercat status:
     Active: active (exited) since Fri 2025-05-09 13:44:10 CEST; 1min 16s ago
    Process: 542 ExecStart=/usr/sbin/ethercatctl start (code=exited, status=0/SUCCESS)
   Main PID: 542 (code=exited, status=0/SUCCESS)
        CPU: 29ms
Mai 09 13:44:10 roger systemd[1]: Starting ethercat.service - EtherCAT Master Kernel Modules...
Mai 09 13:44:10 roger systemd[1]: Finished ethercat.service - EtherCAT Master Kernel Modules.
sudo modinfo ec_master:
roger@roger:~$ sudo modinfo ec_master
[sudo] Passwort für roger:
filename:       /lib/modules/6.1.0-30-rt-amd64/updates/dkms/ec_master.ko
version:        1.6.4 1.6.4.g703b611-1+17.1
license:        GPL
description:    EtherCAT master driver module
author:         Florian Pose <This email address is being protected from spambots. You need JavaScript enabled to view it.>
srcversion:     976B904C4EBCA2C98AAB9AC
depends:
retpoline:      Y
vermagic:       6.1.0-30-rt-amd64 SMP preempt_rt mod_unload modversions
sig_id:         PKCS#7
signer:         DKMS module signing key
sig_key:        0C:21:72:1B:F5:21:65:8B:7F:BF:48:64:17:62:5D:68:85:79:BA:BF
sig_hashalgo:   sha256
signature:      4A:E3:8A:17:F3:B0:9F:77:3C:AC:E0:3A:0E:17:7C:E5:BD:73:15:D5:
        8F:E7:72:79:94:A6:2E:EC:4D:F8:90:8C:9A:D3:02:F1:CA:78:59:46:
        5C:C6:5D:40:72:1D:E6:28:B9:F8:DD:C5:87:DE:C3:11:35:50:E7:EC:
        71:78:C7:43:5F:AE:E9:E1:11:FD:28:8E:58:2A:E8:38:AE:84:80:CE:
        BE:16:8A:8F:86:EE:68:3C:33:EA:39:0C:23:F6:C0:A7:CA:6F:95:BB:
        E2:72:1E:47:C4:62:82:4A:09:A2:7D:FB:3B:F3:7C:ED:E3:FC:8D:36:
        62:9F:47:0B:71:CD:04:8D:69:F6:D5:44:AD:A3:00:44:B5:5A:36:C3:
        CA:5B:E0:D5:B5:5A:50:C0:44:2A:42:63:7A:CC:8E:FB:DE:E7:21:1F:
        06:C9:6D:41:F3:60:3A:0A:AA:AE:4F:51:DF:17:17:0C:25:1D:C3:33:
        71:45:9A:5E:14:73:A9:4C:4E:D0:C4:70:DA:00:EA:57:6D:41:EA:63:
        A5:CE:8A:E4:9D:91:01:54:FC:EE:90:5A:FC:96:8A:94:FE:C4:8D:07:
        9C:8E:82:A8:5F:43:4F:86:49:8C:E6:0D:BF:69:D7:53:C4:5D:8B:C6:
        81:05:63:EC:0F:7E:F1:27:C8:FE:46:15:AD:C1:03:28
parm:           main_devices:MAC addresses of main devices (array of charp)
parm:           backup_devices:MAC addresses of backup devices (array of charp)
parm:           debug_level:Debug level (uint)
parm:           run_on_cpu:Bind kthreads to a specific cpu (uint)
To summarize how I installed it:
I followed the procedure described by rodw exactly. I didn't leave anything out, and I didn't add anything. I also lack the knowledge to do that. I've reinstalled the PC three times now, each time with the same result: Master0 link down. The network adapter settings are as I posted them (IPv4 Local Link and IPv6 disabled). UEFI is not active, and the installation itself didn't report any errors.
09 May 2025 15:18 #328079 by Hakan
I think it looks ok, maybe there is something with the exact kernel version and the module version but it should still work even with the "tainted" message.
We are just trying to find out why it doesn't work and make it work.
Actually, maybe the interface settings.
You showed some screenshots early in the thread with IPv4 settings and more.
Actually, ethercat and IPv4 are not compatible and one should not configure any IPv4 things on the interface.
On my system, the ethercat interface doesn't even show up on the first screen of that application that lists the interfaces.
This is how my interface is started, in /etc/network/interfaces
auto enp2s0
iface enp2s0 inet manual
        hardware-irq-coalesce-rx-usecs 0
        pre-up /sbin/ifconfig $IFACE up
        post-down /sbin/ifconfig $IFACE down
That hardware-irq-coelesce setting is a Intel card setting.
The output of my ethercat interface fromthe commadn "ip a"
4: enp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether c4:62:37:06:66:54 brd ff:ff:ff:ff:ff:ff
    inet6 fe80::c662:37ff:fe06:6654/64 scope link
       valid_lft forever preferred_lft forever
no ipv4 address
10 May 2025 06:26 #328128 by Roger S
My Ethercat Interface:
2: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 80:ee:73:fd:0f:8b brd ff:ff:ff:ff:ff:ff
    inet6 fe80::d771:e69b:b8c8:1f5e/64 scope link noprefixroute
10 May 2025 07:57 #328134 by Hakan
This is interesting...
Looks the same. I changed my device to the same settings you have and it still works.
Is it a Realtek device? Which kernel module does it use? Find with the command "lspci -k" and find the network adapter.
I looked in the source code for when it rejects a device and this is what it says in the ecdev_offer() function in module.c:
* The master decides, if it wants to use the device for EtherCAT operation,
 * or not. It is important, that the offered net_device is not used by the
 * kernel IP stack. If the master, accepted the offer, the address of the
 * newly created EtherCAT device is returned, else \a NULL is returned.
There are some debug outputs that can be interesting. Unfortunately the debug attempt before failed
because the master is configured before the debug can be set in the way we tried before.
But here is a way.
First stop the ethercat server with the command "sudo /usr/sbin/ethercatctl stop".
Then copy the the file /usr/sbin/ethercatctl (it is a script) to a new name like ectl and change the line as shown
sudo cp /usr/sbin/ethercatctl ectl
# ... edit ectl and add debug_level=1 to this line a shown around line 126 in ectl
    # load master module
    if ! ${MODPROBE} ${MODPROBE_FLAGS} ec_master \
            main_devices="${DEVICES}" backup_devices="${BACKUPS}" debug_level=1; then
        exit 1
    fi
# Make executable
chmod +x ectl
# and start the ethercat master, then reset debug level to 0. It produces a lot of info
sudo ./ectl start
ethercat debug 0
sudo dmesg
Then have a look at the output, the lines around the configuration is important.
10 May 2025 09:14 - 10 May 2025 09:23 #328135 by Roger S
Hello Hakan
I hope I did everything correctly. Here's the result of lspci -k:
00:00.0 Host bridge: Intel Corporation Device 461c
    DeviceName: Onboard - Other
    Subsystem: Holco Enterprise Co, Ltd/Shuttle Computer Device 4164
00:02.0 VGA compatible controller: Intel Corporation Alder Lake-N [UHD Graphics]
    DeviceName: Onboard - Video
    Subsystem: Holco Enterprise Co, Ltd/Shuttle Computer Alder Lake-N [UHD Graphics]
    Kernel driver in use: i915
    Kernel modules: i915
00:14.0 USB controller: Intel Corporation Alder Lake-N PCH USB 3.2 xHCI Host Controller
    Subsystem: Holco Enterprise Co, Ltd/Shuttle Computer Alder Lake-N PCH USB 3.2 xHCI Host Controller
    Kernel driver in use: xhci_hcd
    Kernel modules: xhci_pci
00:14.2 RAM memory: Intel Corporation Alder Lake-N PCH Shared SRAM
00:16.0 Communication controller: Intel Corporation Alder Lake-N PCH HECI Controller
    Subsystem: Holco Enterprise Co, Ltd/Shuttle Computer Alder Lake-N PCH HECI Controller
    Kernel driver in use: mei_me
    Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Alder Lake-N SATA AHCI Controller
    DeviceName: Onboard - SATA
    Subsystem: Holco Enterprise Co, Ltd/Shuttle Computer Alder Lake-N SATA AHCI Controller
    Kernel driver in use: ahci
    Kernel modules: ahci
00:1c.0 PCI bridge: Intel Corporation Alder Lake-N PCI Express Root Port
    Subsystem: Holco Enterprise Co, Ltd/Shuttle Computer Alder Lake-N PCI Express Root Port
    Kernel driver in use: pcieport
00:1c.1 PCI bridge: Intel Corporation Alder Lake-N PCI Express Root Port
00:1d.0 PCI bridge: Intel Corporation Alder Lake-N PCI Express Root Port
00:1f.0 ISA bridge: Intel Corporation Alder Lake-N PCH eSPI Controller
    Subsystem: Holco Enterprise Co, Ltd/Shuttle Computer Alder Lake-N PCH eSPI Controller
00:1f.3 Audio device: Intel Corporation Alder Lake-N PCH High Definition Audio Controller
    DeviceName: Onboard - Sound
    Subsystem: Holco Enterprise Co, Ltd/Shuttle Computer Alder Lake-N PCH High Definition Audio Controller
    Kernel driver in use: snd_hda_intel
    Kernel modules: snd_hda_intel, snd_sof_pci_intel_tgl
00:1f.4 SMBus: Intel Corporation Alder Lake-N SMBus
    Subsystem: Holco Enterprise Co, Ltd/Shuttle Computer Alder Lake-N SMBus
    Kernel driver in use: i801_smbus
    Kernel modules: i2c_i801
00:1f.5 Serial bus controller: Intel Corporation Alder Lake-N SPI (flash) Controller
    Subsystem: Holco Enterprise Co, Ltd/Shuttle Computer Alder Lake-N SPI (flash) Controller
01:00.0 Ethernet controller: Intel Corporation Ethernet Controller I226-LM (rev 04)
    Subsystem: Holco Enterprise Co, Ltd/Shuttle Computer Ethernet Controller I226-LM
    Kernel driver in use: igc
    Kernel modules: igc
02:00.0 Ethernet controller: Intel Corporation Ethernet Controller I226-LM (rev 04)
    Kernel modules: igc
03:00.0 Non-Volatile memory controller: Transcend Information, Inc. NVMe PCIe SSD 110S/112S/120S/MTE300S/MTE400S/MTE652T2 (DRAM-less) (rev 03)
    Subsystem: Transcend Information, Inc. NVMe PCIe SSD 110S/112S/120S/MTE300S/MTE400S/MTE652T2 (DRAM-less)
    Kernel driver in use: nvme
    Kernel modules: nvme
Last edit: 10 May 2025 09:23 by Roger S.
10 May 2025 09:23 #328137 by Roger S
File Name: dmesg_2025...10-7.txt
File Size:70 KB
Time to create page: 0.832 seconds
