  • cmorley
  • cmorley
14 Mar 2025 01:51
Replied by cmorley on topic Qtvcp Development Discussions
Category: Qtvcp
Well keep us in the loop with your updates. If you are rapidly changing things then maybe wait a bit for inclusion - unless you are interested in on going linuxcnc development?
  • vre
  • vre
14 Mar 2025 00:57 - 14 Mar 2025 09:59
Replied by vre on topic Mesa modbus and pktUart
Category: Other User Interfaces
This is the reason for crazy data readings on encoders ?
I make now a config that encoder.count and encoder.velocity goes crazy to see if it stops by setting update-hz to non zero
Yes problem of noise in encoders resolves by non zero value to update-hz
verified by different configs that produced random data to different encoders.
All random data stop to encoders if update-hz is non zero but stop and modbus device to work.
  • PCW
  • PCW's Avatar
14 Mar 2025 00:55
Replied by PCW on topic Mesa modbus and pktUart
Yes, this is a long known bug, never set the update rate to 0.
  • PCW
  • PCW's Avatar
14 Mar 2025 00:53
Replied by PCW on topic Spindle PID RPM oscillates under load
Since the units of maxerror are RPM, I would start with say 25 or 50
(.001 RPM as you found will simply operate as open loop)
Also limiting the rate of change of commanded RPM (with the limit component)
will reduce overshoot
  • vre
  • vre
14 Mar 2025 00:50 - 14 Mar 2025 00:54
Seems to be related also to this
forum.linuxcnc.org/27-driver-boards/5432...v2d-firmware?start=0
If after startup set update-hz to 0.0001 or something non zero problem seem to stops..
Is this division by zero bug?
#define MAX_MSG_LEN 16 // may be increased if necessary to max 251
#define DEBUG 2
static const hm2_modbus_chan_descriptor_t channels = {
/* {TYPE, FUNC, ADDR, COUNT, pin_name} */
{HAL_BIT, 2, 0x0000, 32, "in"},
{HAL_BIT, 15, 0x0000, 32, "out"},
// {HAL_U32, 6, 0x00FE, 1, "setbaud"},
// {HAL_U32, 3, 0x00FE, 1, "baud"},
  • PCW
  • PCW's Avatar
14 Mar 2025 00:41
Can you also include the exact .mod file that you are using?
  • royka
  • royka
13 Mar 2025 23:42
Kernel 6.12 with PREEMPT_RT patches enabled - yet POSIX non-realtime (LM22.1)
Category: Installing LinuxCNC
I don't run debian 10, but Bookworm and actually use a rk3588 sbc which works very reliable. But here is the 6.12 kernel for x86 I've used before: drive.google.com/drive/folders/16Xlry00L...SlwznPLv?usp=sharing
But you can also download some from Debian, 6.13:
packages.debian.org/experimental/amd64/l...13-rt-amd64/download
And others:
packages.debian.org/search?keywords=linux-image-rt
  • tsaG
  • tsaG
13 Mar 2025 23:22
Replied by tsaG on topic ATC Tool Rack implementation gesucht
Category: Deutsch
Thanks! That is already a great place to start! I will have a look at it. In the meantime, I came up with my own code (thanks Chatgpt). However, when executing it I get the error "Unknown word starting with f" in the GUI. However, without any hint to any line in the code. It seems I have to open linuxcnc via console and active the debug mode to see it?
This is my code for now. More work tomorrow.
(MSG, --- Start of toolchange.ngc ---)
o<toolchange> sub
    (MSG, --- Toolchange Subroutine Entry ---)
    ; A) Named parameters (populated by stdglue.py / M6 prolog):
    ;    #<selected_tool>, #<tool_in_spindle>,
    ;    #<selected_pocket>, #<current_pocket>,
    ;    #<atc_z_tool_change_height>, #<atc_z_tool_clearance_height>, etc.
    (MSG, Selected tool = #<selected_tool>)
    (MSG, Tool in spindle = #<tool_in_spindle>)
    (MSG, Selected pocket = #<selected_pocket>)
    (MSG, Current pocket = #<current_pocket>)
    ; B) Check if a tool change is actually needed
    IF [#<selected_tool> EQ #<tool_in_spindle>] THEN
        (MSG, Tool #<tool_in_spindle> is already loaded. No change needed.)
        M99
    END-IF
    ; C) Stop the spindle
    M5  ; no spindle orientation (M19) requested
    ; D) Rack coordinates (adjust as needed for your machine)
    #<rack_x>      = 1123
    #<rack_y_base> = 164
    #<rack_y_pitch> = 50
    ; We comment these out so they are NOT overwritten (assuming INI defines them):
    ; #<atc_z_tool_change_height>    = -80
    ; #<atc_z_tool_clearance_height> = 0
    ; Move Z to clearance
    G53 G0 Z[#<atc_z_tool_clearance_height>]
    ; E) Drop off the old tool (#<tool_in_spindle>) in #<current_pocket>
    IF [#<tool_in_spindle> GT 0] THEN
        ; 1) Y coordinate for the current pocket
        #<old_pocket_y> = [#<rack_y_base> + ([#<current_pocket>] - 1) * #<rack_y_pitch>]
        ; 2) Move to that pocket in machine coords (G53)
        G53 G0 X[#<rack_x>] Y[#<old_pocket_y>]
        ; 3) Lower Z to the tool-change height
        G53 G0 Z[#<atc_z_tool_change_height>]
        ; 4) Unclamp (M64 P2) to release old tool
        (MSG, Unclamping old tool with M64 P2)
        M64 P2
        G4 P1  ; dwell 1 second, adjust as needed
        ; 5) Move back up to clearance
        ; 6) Update the pocket table (#4001..#4024)
        #<pocket_index> = [4000 + #<current_pocket>]
        #[#<pocket_index>] = #<tool_in_spindle>
    END-IF
    ; F) Pick up the new tool (#<selected_tool>) from #<selected_pocket>
    IF [#<selected_tool> GT 0] THEN
        ; 1) Optional check: does pocket #<selected_pocket> hold #<selected_tool>?
        #<pocket_index> = [4000 + #<selected_pocket>]
        IF [#[#<pocket_index>] NE #<selected_tool>] THEN
            (MSG, *** WARNING: Pocket #<selected_pocket> does not match tool #<selected_tool>!)
        END-IF
        ; 2) Compute Y coordinate for the selected pocket
        #<new_pocket_y> = [#<rack_y_base> + ([#<selected_pocket>] - 1) * #<rack_y_pitch>]
        ; 3) Move to that pocket
        G53 G0 X[#<rack_x>] Y[#<new_pocket_y>]
        ; 4) Lower Z to the tool-change height
        ; 5) Clamp (M65 P2) to pick up the new tool
        (MSG, Clamping new tool with M65 P2)
        M65 P2
        ; 6) Return to clearance
        ; 7) This pocket is now empty
        #[#<pocket_index>] = 0
    END-IF
    ; G) The spindle now has the new tool
    #<tool_in_spindle> = #<selected_tool>
    ; H) Tell LinuxCNC the new tool is active & load offset
    M61 Q[#<selected_tool>]     ; set active tool to #<selected_tool>
    G43 H[#<selected_tool>]     ; load that tool's offset from table
    ; I) Return to caller
    M99
o<toolchange> endsub
M2
(MSG, --- End of toolchange.ngc ---)
13 Mar 2025 22:55
Replied by tommylight on topic ATC Tool Rack implementation gesucht
Category: Deutsch
LinuxCNC config picker from the main menu, then Sample configurations>sim>axis>remap>rack toolchange as shown in picture.
That will also copy the files to your LinuxCNC configs folder so you can edit and test as much as you like. :)
  • ihavenofish
  • ihavenofish
13 Mar 2025 22:55
  • tsaG
  • tsaG
13 Mar 2025 22:34
Category: Deutsch
Thanks! Unfortunately, most of it is just people having problems with their code without posting the working code. Okay, It seems I am on my own. Ill post my code once I am making progress or even get it working
13 Mar 2025 22:30
Replied by tommylight on topic Asus Motherboard + AMD5600gt
Category: PathPilot
Download the ISO from the downloads page, burn to a USB, boot that PC from that USB, see if you can run any of the parallel port configs included.
All that can be done without installing just in Live mode.
Also try some sims.
There is no actionable info to help so far, so need more info, errors, smoke... :)
  • LCR
  • LCR
13 Mar 2025 21:03
Problems with Lichuan Ethercat servo drive
Category: EtherCAT
I changed all the gains to see if one would have an effect on the offset error. Nothing. I've put a light integration loop in the cia402.conf file. That solves the problem. I don't like it. I would appreciate hearing from anyone running these amps. If you have this issue or not. Thanks.
  • vre
  • vre
13 Mar 2025 20:54 - 13 Mar 2025 22:05
This is dump
Also in this thread seems to have same problem(encoder reads crazy data with pktuart enabled and in working state)
forum.linuxcnc.org/24-hal-components/527...r-count-interference
Displaying 17731 - 17745 out of 18506 results.
Time to create page: 0.422 seconds
