  • Holzwurm56
  • Holzwurm56
27 Jul 2026 05:52
Replied by Holzwurm56 on topic Help Controller for a Lathe ?
Category: CNC Machines
Hi Timo,
There’s no rush on my end. I want to thoroughly research which control system to use first. The issue seems to be the two handwheels that can be used simultaneously. It worked well with Mach3 using two printer ports, but I’m looking for something more modern.
Hans
27 Jul 2026 05:12 - 30 Jul 2026 03:48
Replied by tommylight on topic Desktop help
Desktop help
Almost all of us use older desktops and no one (not even me) advise on using new or old laptops, if you bothered to read anything here.
And who is Valentina? I did have several friends named Valentina, all married by now.
  • timo
  • timo
27 Jul 2026 04:33
Replied by timo on topic Help Controller for a Lathe ?
Keep us updated what you do there :-)
Keep in mind that the hand wheel can most probably just be connected to "normal inputs" if you want to use dedicated encoder inputs for the spindle or other things, like scales.
  • nickm1969@live.com
27 Jul 2026 04:33
Desktop help was created by nickm1969@live.com
Desktop help
Any recommendations on running an older desktop as opposed to a new laptop? Also drawing in Valentina. Do they play well together?
  • ihavenofish
  • ihavenofish
26 Jul 2026 23:31
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
1. Somewhere in your ini settings kinstype=both lets you jog before homing unless you have 2 motors on an axis
This explicitely returns an error telling me i need to be homed first.... sooo. no.
  • ihavenofish
  • ihavenofish
26 Jul 2026 22:50
2. Refer to my Ethercat install sticky for the rules to start the ethercat service on startup
3. No idea
4. It may have changed but probe basic requires a 1080p monitor so I could never used it. QT dragon is the same. I had to upgrade to a 1080p monitor.
I'm at a loss to understand what any machine needs moving before homing. Are your home switches set up so they stay triggered to end of travel?
Progress so far:
1: that interesting, its not in my ini right now. ill see if it changes anything. not that axis and qtdragon both work as expected.
2: i reinstalled the whole system, were back on 2.9.8 and everything is so far fine.
3: this is actually the drives reporting zero for one frame when resetting. i remove my filter which was filtering that bad value. it is curious, and i think only the omrons do it. its not important, but perhaps there is a setting or pdo that manages this. Or i can just re-enable the filter but only to trigger on controlword changes. (this is the same basic "bug" with the drives that cause the random joint and home errors).
4: in fact probebasic requires 2077x1080 for reason unknown, i set my res to that and its fine. Lcvette has some thoughts, but after running through them nothing has changed so far. My undestanding is after their server migration something is borked. Fonts are also wrong, too larger, which i assume is related. We will revisit it another day, it is fine for now.
So really we are just needing to fix the jog. I will try what you just said and report back.
  • klopp
  • klopp
26 Jul 2026 18:48
Mill Control Panel v2 was created by klopp
Category: Show Your Stuff
Hey,I retrofitted my CNC mill a while back and since then had a more or less ugly touchscreen built into the original housing.Since the touchscreen now stopped working as well, I decided it was time to make something more modern.It features a 21" touchscreen monitor, a full keyboard, some rotary encoders for overrides and 19 custom made buttons (for on/off, homing, coolant etc.) that can be illuminated separately with a custom hal component.The angle of the keyboard can be adjusted and the back has connectors for HDMI, USB, Power and the emergency stop signals (I don't wanna send the via USB for safety reasons).The frame is made from aluminium, the front and back is matte acrylic. It can be mounted using a standard vesa mount.I already did a v1 of it when I retrofitted my lathe, so I could make some improvements.Let me know what you think :)
  • endian
  • endian's Avatar
26 Jul 2026 18:35
Replied by endian on topic EL7221-9014/15 LCEC Driver Support
Category: EtherCAT
whats the current situation?
  • endian
  • endian's Avatar
26 Jul 2026 18:33
Replied by endian on topic Xenomai RT kernel
Xenomai RT kernel
Thanks I did it with help of AI ... It was worse then Preemt-rt in default non custom stuff ... I left this idea when I saw how much custom thing I need to code alone to run something and it saves be 3us ...
great idea but much stuff around it
  • COFHAL
  • COFHAL
26 Jul 2026 18:19 - 26 Jul 2026 18:21
Replied by COFHAL on topic gearchange
gearchange
I have a lathe with a 9-speed gearbox that is manually selected. The motor is always running at its maximum speed of 1360 RPM, and the speed is manually changed using the gears. I'm using your gearchange component, which supports up to 32 speeds. I've already implemented the logic to select each speed. In each range, I'll control the speed with a VFD between the lowest value of the previous speed and the maximum, according to the original lathe's speed chart. For example, the first speed is 36 RPM, the second is 90 RPM, and the third is 155 RPM. Then, in the first speed, the spindle would rotate between 0 and 36 RPM, and the motor would rotate between 0 and 1360 RPM. In the second speed, between 36 RPM and 90 RPM, the motor would rotate in that gear between the speed that the gear provides, resulting in 36 RPM and 90 RPM at the spindle. This pattern is repeated for the other speeds. My question regarding this component is how to adjust the scale on each device; I don't know if it's always done relative to the first one or relative to the previous one.
  • GFC
  • GFC
26 Jul 2026 16:45
Integrating ethercat with QTplasmaC and Beckhoff modules
Category: EtherCAT
Thank you for the help
moved the post to there
  • GFC
  • GFC
26 Jul 2026 16:31
Category: Plasmac
Over the last year I have been building a gantry plasma table with leadshine el8 servos and Beckhoff modules for I/O, I struggle a lot with software but with help from rodw over on the ethercat forum and some guides I managed to get ethercat working and a basic QTplasmaC config.
but im still having some troubles:
I managed to get these things working:
-QtPlasmaC interface
-motion on all axis when jogging the machine
-external E-stop
-torch break detection switch
-machine enable output turning on a light
what isnt working:
- cant get a torch on output signal when I do a torch pulse
- the ohmic probe enable doesn't output any signal
-when I hit cycle start the G code pauses without moving the machine
I have a EK1100 coupler, an EL1008 digital input, an EL2008 digital output and EL3102 analog input to read the divided arc voltage.
what are the best ways to debug this situation and what should I be looking for?
all config files in a zip file below
previous post:
forum.linuxcnc.org/ethercat/59024-integr...khoff-modules#348066
Thank you all for your help
  • scsmith1451
  • scsmith1451's Avatar
26 Jul 2026 15:27
Replied by scsmith1451 on topic Machine not executing G02 instruction
The spindle-at-speed signal was the issue. The command is correct for a full circle cut. I did add P1 to insure that a full circle is cut though the documentation indicates that P1 is implied if not provided.
Thanks for you help.
  • scsmith1451
26 Jul 2026 15:24
Spindle-at-speed was the issue. I had added a near function to the spindle-at-speed signal in an attempt to get away from the extra dwell after M3. However when I examined the near function input signals the feedback rate was 0 causing spindle-at-speed to never to active.
I removed all of my near function code and put spindle control back to the original configuration and the spindle-at-speed now goes active, but at a significant delta from the commanded speed based on the VFD display and the sound of the spindle. Consequently, I'm back to the additional dwell after M3. Not a real issue since this is a hobby machine and I'm not in any hurry to make cuts.
Thanks for the insight and support.
Kind regards,
  • COFHAL
  • COFHAL
26 Jul 2026 14:21
Replied by COFHAL on topic Need help with Rotary position switch
Category: Turning
You can use the MUX16 component and assign an overall feed value to each of the 16 combinations. It's very simple: you just need to use 4 inputs on your mesa board for each rotary switch. Let me know if you need further assistance.
Displaying 2161 - 2175 out of 12539 results.
Time to create page: 0.301 seconds
